path: root/testsuites/samples/hello (follow)
* headers updated to reflect new style copyright notice as partJoel Sherrill1997-04-223-15/+15
* tests now specify whether using posix initialization threads tableJoel Sherrill1996-05-291-0/+2
| | | | or rtems initialization table in configuration table
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-112-12/+12
* Support for variable length names added to Object Handler. This supportsJoel Sherrill1995-08-232-2/+2
* maximum number of messages removed and include statement cleanupJoel Sherrill1995-08-172-5/+5
* Initial revisionJoel Sherrill1995-05-114-0/+87
