* | 2003-09-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-09-04 | 3 | -3/+3 |
| | | | | | | | | | | | | | | * README, base_mp/apptask.c, base_mp/init.c, base_mp/system.h, base_mp/node1/base_mp.doc, base_mp/node2/base_mp.doc, base_sp/apptask.c, base_sp/base_sp.doc, base_sp/init.c, base_sp/system.h, cdtest/init.c, cdtest/main.cc, cdtest/system.h, fileio/fileio.doc, fileio/init.c, fileio/system.h, hello/hello.doc, hello/init.c, hello/system.h, minimum/init.c, minimum/minimum.doc, paranoia/init.c, paranoia/paranoia.doc, paranoia/system.h, ticker/init.c, ticker/system.h, ticker/tasks.c, ticker/ticker.doc, unlimited/init.c, unlimited/system.h, unlimited/test1.c, unlimited/test2.c, unlimited/test3.c, unlimited/unlimited.doc: URL for license changed. | ||||
* | 2003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-16 | 1 | -3/+3 |
| | | | | | | | | | | | | | | | | | Makefile.am: Reflect having moved automake. base_mp/Makefile.am: Reflect having moved automake. base_mp/node1/Makefile.am: Reflect having moved automake. base_mp/node2/Makefile.am: Reflect having moved automake. base_sp/Makefile.am: Reflect having moved automake. cdtest/Makefile.am: Reflect having moved automake. fileio/Makefile.am: Reflect having moved automake. hello/Makefile.am: Reflect having moved automake. loopback/Makefile.am: Reflect having moved automake. minimum/Makefile.am: Reflect having moved automake. paranoia/Makefile.am: Reflect having moved automake. pppd/Makefile.am: Reflect having moved automake. ticker/Makefile.am: Reflect having moved automake. unlimited/Makefile.am: Reflect having moved automake. | ||||
* | 2003-08-13 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-08-13 | 1 | -0/+2 |
| | | | | * fileio/.cvsignore: New file. | ||||
* | 2003-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-11 | 1 | -1/+1 |
| | | | | | * fileio/Makefile.am: Remove references to *.scn (Doesn't exist). * pppd/Makefile.am: Remove references to DOC* (Don't exist). | ||||
* | 2003-08-06 Thomas Doerfler<Thomas.Doerfler@imd-systems.de> | Jennifer Averett | 2003-08-06 | 4 | -0/+823 |
PR 369/filesystem * Makefile.am, configure.ac: sample application to show the use of the DOSFS functions * fileio/Makefile.am, fileio/fileio.doc, fileio/init.c, fileio/system.h: New files. |
