* cdtest/main.cc, fileio/init.c, fileio/system.h, pppd/pppdapp.c,
ticker/system.h, ticker/tasks.c: Eliminate test routines
TICKS_PER_SECOND and get_ticks_per_second() in favor of new
rtems_clock_get_ticks_per_second().
* fileio/system.h, ticker/system.h, ticker/ticker.scn: Convert calls to
legacy routine rtems_clock_get( RTEMS_CLOCK_GET_xxx, ..) to
rtems_clock_get_xxx().
* fileio/system.h: Switch to unified work area.
* fileio/init.c, fileio/system.h, iostream/init.cc,
loopback/init.c, pppd/init.c, pppd/pppdapp.c: Do not build if
BSP_SMALL_MEMORY is defined. Remove this code once a better way is
supported by the build system.
* fileio/init.c: Change arguments to rtems_shell_init() to match
new expectations.
* fileio/init.c: Add explicit creation of /etc/passwd and /etc/group so
we have a test case for real password checking.
* fileio/init.c: When USE_SHELL not defined, do not attempt to
configure shell.
* fileio/system.h: Rename STACK_CHECKER_ON to more appropriate
CONFIGURE_STACK_CHECKER_ENABLED.
* fileio/init.c: New argument sequence for rtems_shell_init(). Also
split on multiple lines and document each parameter.
* fileio/init.c, hello/system.h, minimum/init.c, unlimited/system.h:
Use CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER where needed.
* fileio/system.h, ticker/system.h: Add new Object Services collection.
This changed the name of a few previously public but undocumented
services and added a some new services.
* fileio/init.c, fileio/system.h, hello/init.c: Enable malloc
statistics so shell output can be interesting.
* testsuites/samples/fileio/init.c: Change shell_* to
rtems_shell_*. Add the mount file-system type of msdos.
* fileio/init.c, fileio/system.h: Increase stack requested for shell
task. Turn on stack checking so the report is interesting.
* fileio/init.c: Add RTEMS Shell configuration and static configuration
of user commands.
fixed synchronization bug between ata.c and bdbuf.c
* base_sp/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* cdtest/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* fileio/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* hello/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* loopback/init.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* minimum/init.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* paranoia/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* pppd/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* ticker/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* unlimited/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* fileio/init.c: Include <rtems/dosfs.h> instead of <dosfs.h>.
* fileio/init.c, fileio/system.h, ticker/system.h, ticker/tasks.c,
unlimited/init.c, unlimited/test1.c, unlimited/test2.c,
unlimited/test3.c: Convert to using c99 fixed size types.
* base_mp/node1/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES.
* base_mp/node2/Makefile.am: Ditto.
* base_sp/Makefile.am: Ditto.
* cdtest/Makefile.am: Ditto.
* fileio/Makefile.am: Ditto.
* hello/Makefile.am: Ditto.
* loopback/Makefile.am: Ditto.
* minimum/Makefile.am: Ditto.
* paranoia/Makefile.am: Ditto.
* pppd/Makefile.am: Ditto.
* ticker/Makefile.am: Ditto.
* unlimited/Makefile.am: Ditto.
* base_mp/Makefile.am: Reformat.
* base_mp/node1/Makefile.am: Remove all-local: $(ARCH).
* base_mp/node2/Makefile.am: Remove all-local: $(ARCH).
* base_sp/Makefile.am: Remove all-local: $(ARCH).
* cdtest/Makefile.am: Remove all-local: $(ARCH).
* fileio/Makefile.am: Remove all-local: $(ARCH).
* hello/Makefile.am: Remove all-local: $(ARCH).
* loopback/Makefile.am: Remove all-local: $(ARCH).
* minimum/Makefile.am: Remove all-local: $(ARCH).
* paranoia/Makefile.am: Remove all-local: $(ARCH).
* pppd/Makefile.am: Remove all-local: $(ARCH).
* ticker/Makefile.am: Remove all-local: $(ARCH).
* unlimited/Makefile.am: Remove all-local: $(ARCH).
* configure.ac: Add AM_CONDITIONAL(LIBCHIP).
* fileio/Makefile.am: Only build if LIBCHIP is available.
* fileio/init.c: Unconditionally define MIN (We *do want* to see
error messages if it conflicts).
* README, base_mp/apptask.c, base_mp/init.c, base_mp/system.h,
base_mp/node1/base_mp.doc, base_mp/node2/base_mp.doc,
base_sp/apptask.c, base_sp/base_sp.doc, base_sp/init.c,
base_sp/system.h, cdtest/init.c, cdtest/main.cc, cdtest/system.h,
fileio/fileio.doc, fileio/init.c, fileio/system.h, hello/hello.doc,
hello/init.c, hello/system.h, minimum/init.c, minimum/minimum.doc,
paranoia/init.c, paranoia/paranoia.doc, paranoia/system.h,
ticker/init.c, ticker/system.h, ticker/tasks.c, ticker/ticker.doc,
unlimited/init.c, unlimited/system.h, unlimited/test1.c,
unlimited/test2.c, unlimited/test3.c, unlimited/unlimited.doc: URL
for license changed.
base_mp/Makefile.am: Reflect having moved automake.
base_mp/node1/Makefile.am: Reflect having moved automake.
base_mp/node2/Makefile.am: Reflect having moved automake.
base_sp/Makefile.am: Reflect having moved automake.
cdtest/Makefile.am: Reflect having moved automake.
fileio/Makefile.am: Reflect having moved automake.
hello/Makefile.am: Reflect having moved automake.
loopback/Makefile.am: Reflect having moved automake.
minimum/Makefile.am: Reflect having moved automake.
paranoia/Makefile.am: Reflect having moved automake.
pppd/Makefile.am: Reflect having moved automake.
ticker/Makefile.am: Reflect having moved automake.
unlimited/Makefile.am: Reflect having moved automake.
* fileio/.cvsignore: New file.
* fileio/Makefile.am: Remove references to *.scn (Doesn't exist).
* pppd/Makefile.am: Remove references to DOC* (Don't exist).
PR 369/filesystem
* Makefile.am, configure.ac: sample application to show the use of the
DOSFS functions
* fileio/Makefile.am, fileio/fileio.doc, fileio/init.c,
fileio/system.h: New files.
