* configure.ac: Add CXX-checks. New conditionals CXXTESTS, MPTESTS,
NETTESTS. Add iostream/.
* Makefile.am, base_mp/node1/Makefile.am, base_mp/node2/Makefile.am
cdtest/Makefile.am, loopback/Makefile.am, pppd/Makefile.am:
Reflect changes above.
* cdtest/main.cc: Adaptation to new C++ standards.
* base_sp/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* cdtest/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* fileio/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* hello/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* loopback/init.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* minimum/init.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* paranoia/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* pppd/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* ticker/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* unlimited/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* base_mp/node1/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES.
* base_mp/node2/Makefile.am: Ditto.
* base_sp/Makefile.am: Ditto.
* cdtest/Makefile.am: Ditto.
* fileio/Makefile.am: Ditto.
* hello/Makefile.am: Ditto.
* loopback/Makefile.am: Ditto.
* minimum/Makefile.am: Ditto.
* paranoia/Makefile.am: Ditto.
* pppd/Makefile.am: Ditto.
* ticker/Makefile.am: Ditto.
* unlimited/Makefile.am: Ditto.
* base_mp/Makefile.am: Reformat.
* base_mp/node1/Makefile.am: Remove all-local: $(ARCH).
* base_mp/node2/Makefile.am: Remove all-local: $(ARCH).
* base_sp/Makefile.am: Remove all-local: $(ARCH).
* cdtest/Makefile.am: Remove all-local: $(ARCH).
* fileio/Makefile.am: Remove all-local: $(ARCH).
* hello/Makefile.am: Remove all-local: $(ARCH).
* loopback/Makefile.am: Remove all-local: $(ARCH).
* minimum/Makefile.am: Remove all-local: $(ARCH).
* paranoia/Makefile.am: Remove all-local: $(ARCH).
* pppd/Makefile.am: Remove all-local: $(ARCH).
* ticker/Makefile.am: Remove all-local: $(ARCH).
* unlimited/Makefile.am: Remove all-local: $(ARCH).
* README, base_mp/apptask.c, base_mp/init.c, base_mp/system.h,
base_mp/node1/base_mp.doc, base_mp/node2/base_mp.doc,
base_sp/apptask.c, base_sp/base_sp.doc, base_sp/init.c,
base_sp/system.h, cdtest/init.c, cdtest/main.cc, cdtest/system.h,
fileio/fileio.doc, fileio/init.c, fileio/system.h, hello/hello.doc,
hello/init.c, hello/system.h, minimum/init.c, minimum/minimum.doc,
paranoia/init.c, paranoia/paranoia.doc, paranoia/system.h,
ticker/init.c, ticker/system.h, ticker/tasks.c, ticker/ticker.doc,
unlimited/init.c, unlimited/system.h, unlimited/test1.c,
unlimited/test2.c, unlimited/test3.c, unlimited/unlimited.doc: URL
for license changed.
base_mp/Makefile.am: Reflect having moved automake.
base_mp/node1/Makefile.am: Reflect having moved automake.
base_mp/node2/Makefile.am: Reflect having moved automake.
base_sp/Makefile.am: Reflect having moved automake.
cdtest/Makefile.am: Reflect having moved automake.
fileio/Makefile.am: Reflect having moved automake.
hello/Makefile.am: Reflect having moved automake.
loopback/Makefile.am: Reflect having moved automake.
minimum/Makefile.am: Reflect having moved automake.
paranoia/Makefile.am: Reflect having moved automake.
pppd/Makefile.am: Reflect having moved automake.
ticker/Makefile.am: Reflect having moved automake.
unlimited/Makefile.am: Reflect having moved automake.
* base_mp/node1/Makefile.am: Use .$(OBJEXT) instead of .o.
* base_mp/node2/Makefile.am: Use .$(OBJEXT) instead of .o.
* base_sp/Makefile.am: Use .$(OBJEXT) instead of .o.
* cdtest/Makefile.am: Use .$(OBJEXT) instead of .o.
* hello/Makefile.am: Use .$(OBJEXT) instead of .o.
* minimum/Makefile.am: Use .$(OBJEXT) instead of .o.
* paranoia/Makefile.am: Use .$(OBJEXT) instead of .o.
* ticker/Makefile.am: Use .$(OBJEXT) instead of .o.
* unlimited/Makefile.am: Use .$(OBJEXT) instead of .o.
enable this support.
* cdtest/init.c: Modified.
* base_mp/node1/Makefile.am: Remove AUTOMAKE_OPTIONS.
* base_mp/Makefile.am: Remove AUTOMAKE_OPTIONS.
* base_mp/node2/Makefile.am: Remove AUTOMAKE_OPTIONS.
* base_sp/Makefile.am: Remove AUTOMAKE_OPTIONS.
* cdtest/Makefile.am: Remove AUTOMAKE_OPTIONS.
* hello/Makefile.am: Remove AUTOMAKE_OPTIONS.
* minimum/Makefile.am: Remove AUTOMAKE_OPTIONS.
* paranoia/Makefile.am: Remove AUTOMAKE_OPTIONS.
* ticker/Makefile.am: Remove AUTOMAKE_OPTIONS.
* unlimited/Makefile.am: Remove AUTOMAKE_OPTIONS.
* cdtest/main.cc: Remove RTEMS_TEST_IO_STREAM.
* cdtest/system.h: Configure 1 semaphore. This probably covers
up not defining one for the GCC C++ Run-Time Libraries.
* minimum/Makefile.am: Fix comments to make automake-1.5 happy.
* sample.am: Use TMPINSTALL_FILES = to make automake-1.5 happy.
* cdtest/Makefile.am: Remove LD_LIBS.
* unlimited/Makefile.am: include leaf.am instead of leaf.cfg.
* base_mp/node2/Makefile.am: include leaf.am instead of leaf.cfg.
* base_mp/node1/Makefile.am: include leaf.am instead of leaf.cfg.
* hello/Makefile.am: include leaf.am instead of leaf.cfg.
* base_sp/Makefile.am: include leaf.am instead of leaf.cfg.
* paranoia/Makefile.am: include leaf.am instead of leaf.cfg.
* cdtest/Makefile.am: include leaf.am instead of leaf.cfg, use
make-cxx-exe.
* ticker/Makefile.am: include leaf.am instead of leaf.cfg.
* minimum/Makefile.am: include leaf.am instead of leaf.cfg.
* cdtest/system.h: Removed configure of POSIX mutexes since
there do not appear to be any used in this test.
* base_mp/node1/Makefile.am, base_mp/node2/Makefile.am,
base_sp/Makefile.am, cdtest/Makefile.am, hello/Makefile.am,
minimum/Makefile.am, paranoia/Makefile.am, ticker/Makefile.am,
unlimited/Makefile.am: Include compile.am
significant things:
and PowerPC
same code base.
to convert the sample tests to automake.
<rdasilva@connecttel.com>.
the CPU family name constants.
like signal dispatching.
