* | Fix prototype. | Ralf Corsepius | 2009-10-24 | 1 | -1/+1 |
* | Remove test*(). | Ralf Corsepius | 2009-10-24 | 1 | -3/+1 |
| | | | | Add setup_tasks_to_watch(). | ||||
* | Remove setup_tasks_to_watch. | Ralf Corsepius | 2009-10-24 | 1 | -2/+0 |
* | 2009-09-14 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2009-09-14 | 1 | -1/+1 |
| | | | | * capture/test1.c: Use size_t for sizes. | ||||
* | Eliminate _exe_/.exe. | Ralf Corsepius | 2009-04-03 | 1 | -7/+7 |
* | 2008-12-18 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-12-18 | 1 | -4/+4 |
| | | | | * capture/test1.c: Add const to eliminate warning. | ||||
* | 2008-12-16 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-12-16 | 1 | -1/+1 |
| | | | | * capture/test1.c: Eliminate all public use of TOD conversion routines. | ||||
* | Convert to "bool". | Ralf Corsepius | 2008-09-06 | 2 | -2/+2 |
* | 2007-09-10 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-09-10 | 1 | -1/+1 |
| | | | | * capture/Makefile.am: Use all managers. | ||||
* | 2007-08-31 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-08-31 | 1 | -1/+1 |
| | | | | * capture/Makefile.am: Fix typo -- not unlimited. | ||||
* | 2007-08-21 Chris Johns <chrisj@rtems.org> | Chris Johns | 2007-08-21 | 3 | -435/+435 |
| | | | | | * capture/init.c, capture/system.h, capture/test1.c: Removed CRs from files. Committed incorrectly. | ||||
* | 2007-08-17 Chris Johns <chrisj@rtems.org> | Chris Johns | 2007-08-17 | 7 | -0/+1108 |
* Makefile.am, README, configure.ac, capture/.cvsignore, capture/Makefile.am, capture/capture.doc, capture/capture.scn, capture/init.c, capture/system.h, capture/test1.c: Add a sample test for the capture engine. |
