Update #3170.
Update #3199.
Update #3170.
Update #3199.
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
Use rtems_print_printer_fprintf_putc() instead of
rtems_print_printer_printf() to output via rtems_putc().
Update #3170.
Update #3199.
Statically initialize it to use printk().
Update #3170.
Update #3199.
call to printk.
Updates #3170.
These tests directly or indirectly use fprintf(), etc. which may use the
floating point unit.
Update #3076.
of this patch set.
for details.
PR 1589/build
* base_mp/node1/Makefile.am, base_mp/node2/Makefile.am,
base_sp/Makefile.am, capture/Makefile.am, cdtest/Makefile.am,
fileio/Makefile.am, hello/Makefile.am, iostream/Makefile.am,
loopback/Makefile.am, minimum/Makefile.am, nsecs/Makefile.am,
paranoia/Makefile.am, pppd/Makefile.am, ticker/Makefile.am,
unlimited/Makefile.am: Remove obsolete optional manager capability.
* capture/init.c: Declare notification only if being used.
* fileio/fileio.scn: New file.
* capture/init.c, fileio/init.c: Use rtems_shell_wait_for_input().
* capture/capture.doc: Remove more ITRON references.
Add setup_tasks_to_watch().
* capture/test1.c: Use size_t for sizes.
* capture/test1.c: Add const to eliminate warning.
* capture/test1.c: Eliminate all public use of TOD conversion routines.
* capture/Makefile.am: Use all managers.
* capture/Makefile.am: Fix typo -- not unlimited.
* capture/init.c, capture/system.h, capture/test1.c: Removed CRs
from files. Committed incorrectly.
* Makefile.am, README, configure.ac, capture/.cvsignore,
capture/Makefile.am, capture/capture.doc, capture/capture.scn,
capture/init.c, capture/system.h, capture/test1.c: Add a sample
test for the capture engine.
