path: root/testsuites/samples/base_sp (unfollow)
2002-08-112002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-1/+1
* base_mp/node1/Makefile.am: Use .$(OBJEXT) instead of .o. * base_mp/node2/Makefile.am: Use .$(OBJEXT) instead of .o. * base_sp/Makefile.am: Use .$(OBJEXT) instead of .o. * cdtest/Makefile.am: Use .$(OBJEXT) instead of .o. * hello/Makefile.am: Use .$(OBJEXT) instead of .o. * minimum/Makefile.am: Use .$(OBJEXT) instead of .o. * paranoia/Makefile.am: Use .$(OBJEXT) instead of .o. * ticker/Makefile.am: Use .$(OBJEXT) instead of .o. * unlimited/Makefile.am: Use .$(OBJEXT) instead of .o.
2002-04-172002-04-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+1
* base_sp/apptask.c: Include <stdlib.h>. * hello/init.c: Ditto. * paranoia/init.c: Ditto. * ticker/tasks.c: Ditto. * unlimited/init.c: Ditto. * unlimited/test1.c: Ditto. * unlimited/test2.c: Ditto. * unlimited/test3.c: Ditto.
2002-03-282002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-1/+0
* configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * base_mp/node1/Makefile.am: Remove AUTOMAKE_OPTIONS. * base_mp/Makefile.am: Remove AUTOMAKE_OPTIONS. * base_mp/node2/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * base_sp/Makefile.am: Remove AUTOMAKE_OPTIONS. * cdtest/Makefile.am: Remove AUTOMAKE_OPTIONS. * hello/Makefile.am: Remove AUTOMAKE_OPTIONS. * minimum/Makefile.am: Remove AUTOMAKE_OPTIONS. * paranoia/Makefile.am: Remove AUTOMAKE_OPTIONS. * ticker/Makefile.am: Remove AUTOMAKE_OPTIONS. * unlimited/Makefile.am: Remove AUTOMAKE_OPTIONS.
2001-09-192001-09-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-1/+1
* unlimited/Makefile.am: include leaf.am instead of leaf.cfg. * base_mp/node2/Makefile.am: include leaf.am instead of leaf.cfg. * base_mp/node1/Makefile.am: include leaf.am instead of leaf.cfg. * hello/Makefile.am: include leaf.am instead of leaf.cfg. * base_sp/Makefile.am: include leaf.am instead of leaf.cfg. * paranoia/Makefile.am: include leaf.am instead of leaf.cfg. * cdtest/Makefile.am: include leaf.am instead of leaf.cfg, use make-cxx-exe. * ticker/Makefile.am: include leaf.am instead of leaf.cfg. * minimum/Makefile.am: include leaf.am instead of leaf.cfg.
2000-09-052000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+1
* base_mp/node1/Makefile.am, base_mp/node2/Makefile.am, base_sp/Makefile.am, cdtest/Makefile.am, hello/Makefile.am, minimum/Makefile.am, paranoia/Makefile.am, ticker/Makefile.am, unlimited/Makefile.am: Include compile.am
2000-06-12Merged from 4.5.0-beta3aJoel Sherrill3-9/+8
2000-04-13Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill1-0/+2
2000-01-31Patch rtems-rc-20000118-2.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-1/+0
that contains cosmetical changes to the Makefile.ams below tests (removes old, now invalid comments from these Makefile.ams).
1999-11-22Patch rtems-rc-19991117-8.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-1/+0
1999-11-22Patch rtems-rc-19991117-7.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+43
to convert the sample tests to automake.
1999-11-17Updated copyright notice.Joel Sherrill4-8/+4
1998-02-17updated copyright to 1998Joel Sherrill4-4/+4
1997-10-08Fixed typo in the pointer to the license terms.Joel Sherrill4-8/+8
1997-04-22headers updated to reflect new style copyright notice as partJoel Sherrill4-20/+20
1996-05-29tests now specify whether using posix initialization threads tableJoel Sherrill1-0/+2
1995-09-19Minor bug fixes to get all targets compilable and running. TheJoel Sherrill1-1/+1
single biggest changes were the expansion of the workspace size macro to include other types of objects and the increase in the minimum stack size for most CPUs.
1995-09-11The word "RTEMS" almost completely removed from the core.Joel Sherrill2-13/+21
Configuration Table Template file added and all tests modified to use this. All gvar.h and conftbl.h files removed from test directories. Configuration parameter maximum_devices added. Core semaphore and mutex handlers added and RTEMS API Semaphore Manager updated to reflect this. Initialization sequence changed to invoke API specific initialization routines. Initialization tasks table now owned by RTEMS Tasks Manager. Added user extension for post-switch. Utilized user extensions to implement API specific functionality like signal dispatching. Added extensions to the System Initialization Thread so that an API can register a function to be invoked while the system is being initialized. These are largely equivalent to the pre-driver and post-driver hooks. Added the Modules file oar-go32_p5, modified oar-go32, and modified the file make/custom/go32.cfg to look at an environment varable which determines what CPU model is being used. All BSPs updated to reflect named devices and clock driver's IOCTL used by the Shared Memory Driver. Also merged clock isr into main file and removed ckisr.c where possible. Updated spsize to reflect new and moved variables. Makefiles for the executive source and include files updated to show break down of files into Core, RTEMS API, and Neither. Header and inline files installed into subdirectory based on whether logically in the Core or a part of the RTEMS API.
1995-08-23Support for variable length names added to Object Handler. This supportsJoel Sherrill1-1/+1
both fixed length "raw" names and strings from the API's point of view. Both inline and macro implementations were tested.
1995-08-17maximum number of messages removed and include statement cleanupJoel Sherrill2-4/+4
