* README, base_mp/apptask.c, base_mp/init.c, base_mp/system.h,
base_mp/node1/base_mp.doc, base_mp/node2/base_mp.doc,
base_sp/apptask.c, base_sp/base_sp.doc, base_sp/init.c,
base_sp/system.h, cdtest/init.c, cdtest/main.cc, cdtest/system.h,
fileio/fileio.doc, fileio/init.c, fileio/system.h, hello/hello.doc,
hello/init.c, hello/system.h, minimum/init.c, minimum/minimum.doc,
paranoia/init.c, paranoia/paranoia.doc, paranoia/system.h,
ticker/init.c, ticker/system.h, ticker/tasks.c, ticker/ticker.doc,
unlimited/init.c, unlimited/system.h, unlimited/test1.c,
unlimited/test2.c, unlimited/test3.c, unlimited/unlimited.doc: URL
for license changed.
base_mp/Makefile.am: Reflect having moved automake.
base_mp/node1/Makefile.am: Reflect having moved automake.
base_mp/node2/Makefile.am: Reflect having moved automake.
base_sp/Makefile.am: Reflect having moved automake.
cdtest/Makefile.am: Reflect having moved automake.
fileio/Makefile.am: Reflect having moved automake.
hello/Makefile.am: Reflect having moved automake.
loopback/Makefile.am: Reflect having moved automake.
minimum/Makefile.am: Reflect having moved automake.
paranoia/Makefile.am: Reflect having moved automake.
pppd/Makefile.am: Reflect having moved automake.
ticker/Makefile.am: Reflect having moved automake.
unlimited/Makefile.am: Reflect having moved automake.
* base_mp/apptask.c: Removed warning.
* base_mp/apptask.c: Add include of <unistd.h> to eliminate warning.
* base_mp/node1/Makefile.am: Use .$(OBJEXT) instead of .o.
* base_mp/node2/Makefile.am: Use .$(OBJEXT) instead of .o.
* base_sp/Makefile.am: Use .$(OBJEXT) instead of .o.
* cdtest/Makefile.am: Use .$(OBJEXT) instead of .o.
* hello/Makefile.am: Use .$(OBJEXT) instead of .o.
* minimum/Makefile.am: Use .$(OBJEXT) instead of .o.
* paranoia/Makefile.am: Use .$(OBJEXT) instead of .o.
* ticker/Makefile.am: Use .$(OBJEXT) instead of .o.
* unlimited/Makefile.am: Use .$(OBJEXT) instead of .o.
* base_mp/node1/Makefile.am: Remove AUTOMAKE_OPTIONS.
* base_mp/Makefile.am: Remove AUTOMAKE_OPTIONS.
* base_mp/node2/Makefile.am: Remove AUTOMAKE_OPTIONS.
* base_sp/Makefile.am: Remove AUTOMAKE_OPTIONS.
* cdtest/Makefile.am: Remove AUTOMAKE_OPTIONS.
* hello/Makefile.am: Remove AUTOMAKE_OPTIONS.
* minimum/Makefile.am: Remove AUTOMAKE_OPTIONS.
* paranoia/Makefile.am: Remove AUTOMAKE_OPTIONS.
* ticker/Makefile.am: Remove AUTOMAKE_OPTIONS.
* unlimited/Makefile.am: Remove AUTOMAKE_OPTIONS.
* unlimited/Makefile.am: include leaf.am instead of leaf.cfg.
* base_mp/node2/Makefile.am: include leaf.am instead of leaf.cfg.
* base_mp/node1/Makefile.am: include leaf.am instead of leaf.cfg.
* hello/Makefile.am: include leaf.am instead of leaf.cfg.
* base_sp/Makefile.am: include leaf.am instead of leaf.cfg.
* paranoia/Makefile.am: include leaf.am instead of leaf.cfg.
* cdtest/Makefile.am: include leaf.am instead of leaf.cfg, use
make-cxx-exe.
* ticker/Makefile.am: include leaf.am instead of leaf.cfg.
* minimum/Makefile.am: include leaf.am instead of leaf.cfg.
* base_mp/node1/Makefile.am, base_mp/node2/Makefile.am,
base_sp/Makefile.am, cdtest/Makefile.am, hello/Makefile.am,
minimum/Makefile.am, paranoia/Makefile.am, ticker/Makefile.am,
unlimited/Makefile.am: Include compile.am
cpuopts.h.
exec/configure.in, only.
quoting bugs in autoconf).
formating changes :)
which ontains all what was left over from the other patches (Primarily
minor configuration cleanups).
patch -p1 < rtems-rc-19991203-9.diff
./bootstrap
to convert the sample tests to automake.
like signal dispatching.
