path: root/testsuites/samples/base_mp/node1 (follow)
* testsuite/samples: Merged nested Makefile.am files into one Makefile.amChris Johns2018-04-103-35/+0
| | | | | | This change is part of the testsuite Makefile.am reorganization. Update #3382
* Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill2012-05-112-7/+0
* Revert: Remove CVS IdsJoel Sherrill2012-05-071-0/+4
* samples/base_mp - Makefile.am did not set LINK_OBJSJoel Sherrill2012-05-041-1/+1
| | | | | | | | LINK_OBJS = instead of LINK_OBJS = $(mp01_node1_OBJECTS)
* Remove CVS-Ids.Ralf Corsépius2012-05-041-4/+0
* Remove all .cvsignore files.Joel Sherrill2012-02-011-2/+0
* 2011-12-08 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-12-081-5/+1
| | | | | | | | | | PR 1589/build * base_mp/node1/Makefile.am, base_mp/node2/Makefile.am, base_sp/Makefile.am, capture/Makefile.am, cdtest/Makefile.am, fileio/Makefile.am, hello/Makefile.am, iostream/Makefile.am, loopback/Makefile.am, minimum/Makefile.am, nsecs/Makefile.am, paranoia/Makefile.am, pppd/Makefile.am, ticker/Makefile.am, unlimited/Makefile.am: Remove obsolete optional manager capability.
* Add -I$(top_srcdir)/../support/include.Ralf Corsepius2009-10-301-0/+1
* Eliminate _exe_/.exe.Ralf Corsepius2009-04-031-7/+7
* 2008-09-05 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-09-051-1/+1
| | | | | * base_mp/node1/Makefile.am, base_mp/node2/Makefile.am: Updating and fixing while running mptests on psim.
* Eliminate scndir, docdir. Use rtems_testsdir instead.Ralf Corsepius2006-07-111-4/+2
* Convert to using *_PROGRAMS.Ralf Corsepius2005-11-131-12/+9
* Rework.Ralf Corsepius2005-11-111-27/+7
* Cosmetics.Ralf Corsepius2005-11-111-3/+0
* Hard-code node number.Ralf Corsepius2005-11-111-8/+7
* Eliminate TEST.Ralf Corsepius2005-11-111-7/+6
* Expand sample.am.Ralf Corsepius2005-11-111-1/+20
* New.Ralf Corsepius2005-11-102-0/+17
* Remove.Ralf Corsepius2005-11-102-17/+0
* s/SAMPLE/TEST/ for improved consistency with other tests.Ralf Corsepius2005-11-101-3/+2
* s/SAMPLE/TEST/ for improved consistency with other tests.Ralf Corsepius2005-11-101-1/+1
* CleanupRalf Corsepius2005-11-071-1/+1
* Remove SRCS, PRINT_SRCS.Ralf Corsepius2005-11-071-2/+0
* Switch back to include compile.am instead of amcompile.amRalf Corsepius2005-11-071-1/+1
* Cleanup.Ralf Corsepius2005-11-071-6/+1
* Partial conversion to automake.Ralf Corsepius2005-11-071-6/+6
* 2005-01-06 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius2005-01-061-1/+1
| | | | | * base_mp/node1/Makefile.am, base_mp/node2/Makefile.am: Remove LIB_VARIANT.
* 2004-05-10 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-05-101-5/+0
| | | | | | | | | * configure.ac: Add CXX-checks. New conditionals CXXTESTS, MPTESTS, NETTESTS. Add iostream/. * Makefile.am, base_mp/node1/Makefile.am, base_mp/node2/Makefile.am cdtest/Makefile.am, loopback/Makefile.am, pppd/Makefile.am: Reflect changes above. * cdtest/main.cc: Adaptation to new C++ standards.
* 2004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-141-0/+2
| | | | | | | | | | | | | | | | * base_mp/node1/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES. Add PRE/TMPINSTALL_FILES to CLEANFILES. * base_mp/node2/Makefile.am: Ditto. * base_sp/Makefile.am: Ditto. * cdtest/Makefile.am: Ditto. * fileio/Makefile.am: Ditto. * hello/Makefile.am: Ditto. * loopback/Makefile.am: Ditto. * minimum/Makefile.am: Ditto. * paranoia/Makefile.am: Ditto. * pppd/Makefile.am: Ditto. * ticker/Makefile.am: Ditto. * unlimited/Makefile.am: Ditto.
* 2003-12-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-171-4/+5
| | | | | * base_mp/node1/Makefile.am, base_mp/node2/Makefile.am: Eliminate VPATH.
* 2003-12-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-011-2/+1
| | | | | | | | | | | | | | | | * base_mp/Makefile.am: Reformat. * base_mp/node1/Makefile.am: Remove all-local: $(ARCH). * base_mp/node2/Makefile.am: Remove all-local: $(ARCH). * base_sp/Makefile.am: Remove all-local: $(ARCH). * cdtest/Makefile.am: Remove all-local: $(ARCH). * fileio/Makefile.am: Remove all-local: $(ARCH). * hello/Makefile.am: Remove all-local: $(ARCH). * loopback/Makefile.am: Remove all-local: $(ARCH). * minimum/Makefile.am: Remove all-local: $(ARCH). * paranoia/Makefile.am: Remove all-local: $(ARCH). * pppd/Makefile.am: Remove all-local: $(ARCH). * ticker/Makefile.am: Remove all-local: $(ARCH). * unlimited/Makefile.am: Remove all-local: $(ARCH).
* 2003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-041-1/+1
| | | | | | | | | | | | | | * README, base_mp/apptask.c, base_mp/init.c, base_mp/system.h, base_mp/node1/base_mp.doc, base_mp/node2/base_mp.doc, base_sp/apptask.c, base_sp/base_sp.doc, base_sp/init.c, base_sp/system.h, cdtest/init.c, cdtest/main.cc, cdtest/system.h, fileio/fileio.doc, fileio/init.c, fileio/system.h, hello/hello.doc, hello/init.c, hello/system.h, minimum/init.c, minimum/minimum.doc, paranoia/init.c, paranoia/paranoia.doc, paranoia/system.h, ticker/init.c, ticker/system.h, ticker/tasks.c, ticker/ticker.doc, unlimited/init.c, unlimited/system.h, unlimited/test1.c, unlimited/test2.c, unlimited/test3.c, unlimited/unlimited.doc: URL for license changed.
* 2003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-161-3/+3
| | | | | | | | | | | | | | | | | Makefile.am: Reflect having moved automake. base_mp/Makefile.am: Reflect having moved automake. base_mp/node1/Makefile.am: Reflect having moved automake. base_mp/node2/Makefile.am: Reflect having moved automake. base_sp/Makefile.am: Reflect having moved automake. cdtest/Makefile.am: Reflect having moved automake. fileio/Makefile.am: Reflect having moved automake. hello/Makefile.am: Reflect having moved automake. loopback/Makefile.am: Reflect having moved automake. minimum/Makefile.am: Reflect having moved automake. paranoia/Makefile.am: Reflect having moved automake. pppd/Makefile.am: Reflect having moved automake. ticker/Makefile.am: Reflect having moved automake. unlimited/Makefile.am: Reflect having moved automake.
* 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-111-1/+1
| | | | | | | | | | | | * base_mp/node1/Makefile.am: Use .$(OBJEXT) instead of .o. * base_mp/node2/Makefile.am: Use .$(OBJEXT) instead of .o. * base_sp/Makefile.am: Use .$(OBJEXT) instead of .o. * cdtest/Makefile.am: Use .$(OBJEXT) instead of .o. * hello/Makefile.am: Use .$(OBJEXT) instead of .o. * minimum/Makefile.am: Use .$(OBJEXT) instead of .o. * paranoia/Makefile.am: Use .$(OBJEXT) instead of .o. * ticker/Makefile.am: Use .$(OBJEXT) instead of .o. * unlimited/Makefile.am: Use .$(OBJEXT) instead of .o.
| | | | | | | | | | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * base_mp/node1/Makefile.am: Remove AUTOMAKE_OPTIONS. * base_mp/Makefile.am: Remove AUTOMAKE_OPTIONS. * base_mp/node2/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * base_sp/Makefile.am: Remove AUTOMAKE_OPTIONS. * cdtest/Makefile.am: Remove AUTOMAKE_OPTIONS. * hello/Makefile.am: Remove AUTOMAKE_OPTIONS. * minimum/Makefile.am: Remove AUTOMAKE_OPTIONS. * paranoia/Makefile.am: Remove AUTOMAKE_OPTIONS. * ticker/Makefile.am: Remove AUTOMAKE_OPTIONS. * unlimited/Makefile.am: Remove AUTOMAKE_OPTIONS.
* 2001-09-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-191-1/+1
| | | | | | | | | | | | | * unlimited/Makefile.am: include leaf.am instead of leaf.cfg. * base_mp/node2/Makefile.am: include leaf.am instead of leaf.cfg. * base_mp/node1/Makefile.am: include leaf.am instead of leaf.cfg. * hello/Makefile.am: include leaf.am instead of leaf.cfg. * base_sp/Makefile.am: include leaf.am instead of leaf.cfg. * paranoia/Makefile.am: include leaf.am instead of leaf.cfg. * cdtest/Makefile.am: include leaf.am instead of leaf.cfg, use make-cxx-exe. * ticker/Makefile.am: include leaf.am instead of leaf.cfg. * minimum/Makefile.am: include leaf.am instead of leaf.cfg.
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-051-0/+1
| | | | | | | * base_mp/node1/Makefile.am, base_mp/node2/Makefile.am, base_sp/Makefile.am, cdtest/Makefile.am, hello/Makefile.am, minimum/Makefile.am, paranoia/Makefile.am, ticker/Makefile.am, unlimited/Makefile.am: Include compile.am
* Patch rtems-rc-20000713-1-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-07-131-2/+2
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | that is yet another multilib-related structual cleanup patch: Changes: * Make RTEMS_TEST_NO_PAUSE a tests/ subpackage specific option. - Remove RTEMS_TEST_NO_PAUSE from custom/*.cfg, targopts.h and cpuopts.h. - Add autoconf macros RTEMS_*_RTEMS_TEST_NO_PAUSE (aclocal/rtems-test-no-pause.m4). - Add RTEMS_*_RTEMS_TEST_NO_PAUSE support to sptests/configure.ins and tmtests/configure.in. These are the only subdirectories which currently apply RTEMS_TEST_NO_PAUSE. - Add autoconf-DEFS support to all test subpackages' configure.ins below tests/. I.e. AC_DEFINES now get explicitly propagated as preprocessor defines into Makefiles, cf. AM_CPPFLAGS in tests/*/*.am, instead of using a global config-files. - Remove NDEBUG from custom/*.cfg. * AC_DEFINE POSIX_API, ITRON_API and MULTIPROCESSING in exec/configure.in, only. - All other sources now should relay on the values from cpuopts.h and should not define them themselves. - Several related changes to many configure.ins * Bug-fixes to RTEMS_*_RTEMS_DEBUG macros (Actually workarounds to quoting bugs in autoconf). Notes: * This patch is rather immature and only tested for a small subset of BSPs (requires the tests to be enabled and therefore takes an tremendous amount of disc space and time.) * The patches to *cfg were generated by a script. Expect file formating changes :)
* Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill2000-04-131-0/+2
| | | | adds .cvsignore.
* Patch rtems-rc-20000118-2.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-01-311-1/+0
| | | | | that contains cosmetical changes to the Makefile.ams below tests (removes old, now invalid comments from these Makefile.ams).
* Patch rtems-rc-19991203-9.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-12-211-7/+0
| | | | | | | | | which ontains all what was left over from the other patches (Primarily minor configuration cleanups). To apply: patch -p1 < rtems-rc-19991203-9.diff ./bootstrap
* Patch rtems-rc-19991117-8.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-11-221-1/+0
| | | | to fix some minor bugs in the conversion to automake.
* Patch rtems-rc-19991117-7.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-11-221-0/+59
| | | | to convert the sample tests to automake.
* Initial revisionJoel Sherrill1995-05-112-0/+18
