* base_mp/node1/Makefile.am: Use .$(OBJEXT) instead of .o.
* base_mp/node2/Makefile.am: Use .$(OBJEXT) instead of .o.
* base_sp/Makefile.am: Use .$(OBJEXT) instead of .o.
* cdtest/Makefile.am: Use .$(OBJEXT) instead of .o.
* hello/Makefile.am: Use .$(OBJEXT) instead of .o.
* minimum/Makefile.am: Use .$(OBJEXT) instead of .o.
* paranoia/Makefile.am: Use .$(OBJEXT) instead of .o.
* ticker/Makefile.am: Use .$(OBJEXT) instead of .o.
* unlimited/Makefile.am: Use .$(OBJEXT) instead of .o.
* base_mp/node1/Makefile.am: Remove AUTOMAKE_OPTIONS.
* base_mp/Makefile.am: Remove AUTOMAKE_OPTIONS.
* base_mp/node2/Makefile.am: Remove AUTOMAKE_OPTIONS.
* base_sp/Makefile.am: Remove AUTOMAKE_OPTIONS.
* cdtest/Makefile.am: Remove AUTOMAKE_OPTIONS.
* hello/Makefile.am: Remove AUTOMAKE_OPTIONS.
* minimum/Makefile.am: Remove AUTOMAKE_OPTIONS.
* paranoia/Makefile.am: Remove AUTOMAKE_OPTIONS.
* ticker/Makefile.am: Remove AUTOMAKE_OPTIONS.
* unlimited/Makefile.am: Remove AUTOMAKE_OPTIONS.
* unlimited/Makefile.am: include leaf.am instead of leaf.cfg.
* base_mp/node2/Makefile.am: include leaf.am instead of leaf.cfg.
* base_mp/node1/Makefile.am: include leaf.am instead of leaf.cfg.
* hello/Makefile.am: include leaf.am instead of leaf.cfg.
* base_sp/Makefile.am: include leaf.am instead of leaf.cfg.
* paranoia/Makefile.am: include leaf.am instead of leaf.cfg.
* cdtest/Makefile.am: include leaf.am instead of leaf.cfg, use
make-cxx-exe.
* ticker/Makefile.am: include leaf.am instead of leaf.cfg.
* minimum/Makefile.am: include leaf.am instead of leaf.cfg.
* base_mp/node1/Makefile.am, base_mp/node2/Makefile.am,
base_sp/Makefile.am, cdtest/Makefile.am, hello/Makefile.am,
minimum/Makefile.am, paranoia/Makefile.am, ticker/Makefile.am,
unlimited/Makefile.am: Include compile.am
cpuopts.h.
exec/configure.in, only.
quoting bugs in autoconf).
formating changes :)
which ontains all what was left over from the other patches (Primarily
minor configuration cleanups).
patch -p1 < rtems-rc-19991203-9.diff
./bootstrap
to convert the sample tests to automake.
