path: root/testsuites/samples/base_mp/init.c (follow)
* Minor bug fixes to get all targets compilable and running. TheJoel Sherrill1995-09-191-1/+1
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-111-6/+6
* Initial revisionJoel Sherrill1995-05-111-0/+46
