PR 369/filesystem
* Makefile.am, configure.ac: sample application to show the use of the
DOSFS functions
* fileio/Makefile.am, fileio/fileio.doc, fileio/init.c,
fileio/system.h: New files.
* configure.ac: Add pppd.
* Makefile.am: Add pppd.
* Makefile.am, configure.ac: Added new test loopback which shows how to
use the loopback interface. Thank you Eric Norum for a portable
target independent test which exercises the TCP/IP. This should
prevent massive failures in the TCP/IP stack from reaching the
street.
* loopback/.cvsignore, loopback/Makefile.am, loopback/README,
loopback/init.c, loopback/loopback.scn: New files.
* base_mp/node1/Makefile.am: Remove AUTOMAKE_OPTIONS.
* base_mp/Makefile.am: Remove AUTOMAKE_OPTIONS.
* base_mp/node2/Makefile.am: Remove AUTOMAKE_OPTIONS.
* base_sp/Makefile.am: Remove AUTOMAKE_OPTIONS.
* cdtest/Makefile.am: Remove AUTOMAKE_OPTIONS.
* hello/Makefile.am: Remove AUTOMAKE_OPTIONS.
* minimum/Makefile.am: Remove AUTOMAKE_OPTIONS.
* paranoia/Makefile.am: Remove AUTOMAKE_OPTIONS.
* ticker/Makefile.am: Remove AUTOMAKE_OPTIONS.
* unlimited/Makefile.am: Remove AUTOMAKE_OPTIONS.
* sample.am: Remove DEFS.
to convert the sample tests to automake.
