* pppd/Makefile.am: Add ppp.conf, pppd.options to EXTRA_DIST.
* pppd/Makefile-user: Remove.
* fileio/init.c: Avoid use of deprecated rtems_clock_get() except in
spclockget().
* fileio/Makefile.am, ticker/Makefile.am: Missed part of previous
patch.
* base_sp/apptask.c, base_sp/init.c, fileio/init.c, fileio/system.h,
nsecs/init.c, ticker/init.c, ticker/system.h, ticker/tasks.c: Remove
warnings.
* configure.ac: Add AC_CONFIG_HEADER(config.h).
* base_mp/apptask.c, base_mp/init.c, base_sp/apptask.c, base_sp/init.c,
capture/init.c, capture/test1.c, cdtest/init.c, fileio/init.c,
hello/init.c, loopback/init.c, minimum/init.c, nsecs/empty.c,
nsecs/init.c, paranoia/init.c, paranoia/paranoia.c, pppd/init.c,
pppd/pppdapp.c, ticker/init.c, ticker/tasks.c, unlimited/init.c,
unlimited/test1.c, unlimited/test2.c, unlimited/test3.c: Add
HAVE_CONFIG_H.
* pppd/system.h: Use confdefs.h to generate device driver table.
* pppd/system.h: Added missing include files.
* loopback/init.c: Loop back interface will be initialized now during
normal initialization via rtems_bsdnet_initialize_network().
* fileio/Makefile.am: Remove AM_CONDITIONAL(LIBCHIP).
* configure.ac: Remove AM_CONDITIONAL(LIBCHIP).
Force autoconf-2.67, automake-1.11.1.
* minimum/init.c: Use fatal error extension to prevent infinite
runtime.
* capture/capture.doc: Remove more ITRON references.
* iostream/init.cc: Remove the hack.
* fileio/init.c: Update to new mount API.
* iostream/init.cc: Hack to work around confdefs.h in C++.
* iostream/system.h: Add comment about base miniIMFS.
* capture/init.c: Remove unused variable "out".
* fileio/init.c: Remove deprecation warnings.
* fileio/init.c: Fix warnings for ctype methods.
* loopback/init.c: Adjust return-type of rtems_bsdnet_loopattach to
int to match with rtems/rtems_bsdnet.h.
* base_mp/apptask.c: Use PRIxrtems_id to print rtems_ids.
Include "tmacros.h".
* base_mp/node1/Makefile.am, base_mp/node2/Makefile.am:
Add -I$(top_srcdir)/../support/include.
* pppd/netconfig.h: Add UL suffix to long constants to avoid
implicit integer overflows on 16bit targets.
* fileio/init.c: Use %zd to print ssize_t.
* base_sp/apptask.c, unlimited/init.c:
Use PRIdrtems_task_argument to print rtems_task_argument's.
* base_sp/apptask.c, unlimited/init.c, unlimited/test1.c,
Include "tmacros.h". Use PRIxrtems_id to print rtems_ids.
* unlimited/Makefile.am, base_sp/Makefile.am:
* loopback/init.c : Add prototype for rtems_bsdnet_loopattach.
Remove evil type-cast.
* nsecs/rprintf.h: Remove (PRItime_t moved to tmacros.h).
* nsecs/Makefile.am: Add -I$(top_srcdir)/../support/include.
* nsecs/init.c: Include "tmacros.h" instead of "rprintf.h"
* capture/init.c: Remove setup_tasks_to_watch.
* capture/system.h: Remove test*().
Add setup_tasks_to_watch().
* capture/test1.c: Fix prototype.
* fileio/init.c: Fix broken printfs.
* minimum/init.c: Remove unused var.
* nsecs/empty.c: Add missing prototype.
* nsecs/rprintf.h: New.
* nsecs/init.c: Printf fixes.
* unlimited/system.h: Add missing prototypes.
* unlimited/init.c, unlimited/test1.c, unlimited/test2.c,
unlimited/test3.c: Various warning fixes.
* unlimited/test1.c: Spacing.
* hello/init.c: Remove call to devFS_Show() which had accidentally
gotten committed.
* capture/test1.c: Use size_t for sizes.
* hello/Makefile.am, hello/init.c: Simplify.
* hello/system.h: Removed.
* unlimited/test2.c: Fix spacing.
* cdtest/main.cc, fileio/init.c, fileio/system.h, pppd/pppdapp.c,
ticker/system.h, ticker/tasks.c: Eliminate test routines
TICKS_PER_SECOND and get_ticks_per_second() in favor of new
rtems_clock_get_ticks_per_second().
* fileio/system.h, ticker/system.h, ticker/ticker.scn: Convert calls to
legacy routine rtems_clock_get( RTEMS_CLOCK_GET_xxx, ..) to
rtems_clock_get_xxx().
* ticker/tasks.c: Convert calls to legacy routine rtems_clock_get(
RTEMS_CLOCK_GET_TOD, ..) to rtems_clock_get_tod(..).
* fileio/system.h: Switch to unified work area.
* cdtest/system.h: modified the number of max semaphores
- test was failing before
* loopback/init.c: Add missing initializers.
* iostream/system.h: Remove the Init prototype. Provide in
confdefs.h.
* fileio/init.c, fileio/system.h, iostream/init.cc,
loopback/init.c, pppd/init.c, pppd/pppdapp.c: Do not build if
BSP_SMALL_MEMORY is defined. Remove this code once a better way is
supported by the build system.
* base_mp/node1/Makefile.am, base_mp/node2/Makefile.am,
base_sp/Makefile.am, capture/Makefile.am, cdtest/Makefile.am,
fileio/Makefile.am, hello/Makefile.am, iostream/Makefile.am,
loopback/Makefile.am, minimum/Makefile.am, nsecs/Makefile.am,
paranoia/Makefile.am, pppd/Makefile.am, ticker/Makefile.am,
unlimited/Makefile.am: Eliminate _exe_/.exe.
* fileio/init.c: Change arguments to rtems_shell_init() to match
new expectations.
* cdtest/main.cc: Use printk() in global destructors since printf() no
longer works.
* capture/test1.c: Add const to eliminate warning.
* capture/test1.c: Eliminate all public use of TOD conversion routines.
