* loopback/init.c: Loop back interface will be initialized now during
normal initialization via rtems_bsdnet_initialize_network().
* fileio/Makefile.am: Remove AM_CONDITIONAL(LIBCHIP).
* configure.ac: Remove AM_CONDITIONAL(LIBCHIP).
Force autoconf-2.67, automake-1.11.1.
* minimum/init.c: Use fatal error extension to prevent infinite
runtime.
* capture/capture.doc: Remove more ITRON references.
* iostream/init.cc: Remove the hack.
* fileio/init.c: Update to new mount API.
* iostream/init.cc: Hack to work around confdefs.h in C++.
* iostream/system.h: Add comment about base miniIMFS.
* capture/init.c: Remove unused variable "out".
* fileio/init.c: Remove deprecation warnings.
* fileio/init.c: Fix warnings for ctype methods.
* loopback/init.c: Adjust return-type of rtems_bsdnet_loopattach to
int to match with rtems/rtems_bsdnet.h.
* base_mp/apptask.c: Use PRIxrtems_id to print rtems_ids.
Include "tmacros.h".
* base_mp/node1/Makefile.am, base_mp/node2/Makefile.am:
Add -I$(top_srcdir)/../support/include.
* pppd/netconfig.h: Add UL suffix to long constants to avoid
implicit integer overflows on 16bit targets.
* fileio/init.c: Use %zd to print ssize_t.
* base_sp/apptask.c, unlimited/init.c:
Use PRIdrtems_task_argument to print rtems_task_argument's.
* base_sp/apptask.c, unlimited/init.c, unlimited/test1.c,
unlimited/test2.c, unlimited/test3.c:
Include "tmacros.h". Use PRIxrtems_id to print rtems_ids.
* unlimited/Makefile.am, base_sp/Makefile.am:
* loopback/init.c : Add prototype for rtems_bsdnet_loopattach.
Remove evil type-cast.
* nsecs/rprintf.h: Remove (PRItime_t moved to tmacros.h).
* nsecs/Makefile.am: Add -I$(top_srcdir)/../support/include.
* nsecs/init.c: Include "tmacros.h" instead of "rprintf.h"
* capture/init.c: Remove setup_tasks_to_watch.
* capture/system.h: Remove test*().
Add setup_tasks_to_watch().
* capture/test1.c: Fix prototype.
* fileio/init.c: Fix broken printfs.
* minimum/init.c: Remove unused var.
* nsecs/empty.c: Add missing prototype.
* nsecs/rprintf.h: New.
* nsecs/init.c: Printf fixes.
* unlimited/system.h: Add missing prototypes.
* unlimited/init.c, unlimited/test1.c, unlimited/test2.c,
unlimited/test3.c: Various warning fixes.
* unlimited/test1.c: Spacing.
* hello/init.c: Remove call to devFS_Show() which had accidentally
gotten committed.
* capture/test1.c: Use size_t for sizes.
* hello/Makefile.am, hello/init.c: Simplify.
* hello/system.h: Removed.
* unlimited/test2.c: Fix spacing.
* cdtest/main.cc, fileio/init.c, fileio/system.h, pppd/pppdapp.c,
ticker/system.h, ticker/tasks.c: Eliminate test routines
TICKS_PER_SECOND and get_ticks_per_second() in favor of new
rtems_clock_get_ticks_per_second().
* fileio/system.h, ticker/system.h, ticker/ticker.scn: Convert calls to
legacy routine rtems_clock_get( RTEMS_CLOCK_GET_xxx, ..) to
rtems_clock_get_xxx().
* ticker/tasks.c: Convert calls to legacy routine rtems_clock_get(
RTEMS_CLOCK_GET_TOD, ..) to rtems_clock_get_tod(..).
* fileio/system.h: Switch to unified work area.
* cdtest/system.h: modified the number of max semaphores
- test was failing before
* loopback/init.c: Add missing initializers.
* iostream/system.h: Remove the Init prototype. Provide in
confdefs.h.
* fileio/init.c, fileio/system.h, iostream/init.cc,
loopback/init.c, pppd/init.c, pppd/pppdapp.c: Do not build if
BSP_SMALL_MEMORY is defined. Remove this code once a better way is
supported by the build system.
* base_mp/node1/Makefile.am, base_mp/node2/Makefile.am,
base_sp/Makefile.am, capture/Makefile.am, cdtest/Makefile.am,
fileio/Makefile.am, hello/Makefile.am, iostream/Makefile.am,
loopback/Makefile.am, minimum/Makefile.am, nsecs/Makefile.am,
paranoia/Makefile.am, pppd/Makefile.am, ticker/Makefile.am,
unlimited/Makefile.am: Eliminate _exe_/.exe.
* fileio/init.c: Change arguments to rtems_shell_init() to match
new expectations.
* cdtest/main.cc: Use printk() in global destructors since printf() no
longer works.
* capture/test1.c: Add const to eliminate warning.
* capture/test1.c: Eliminate all public use of TOD conversion routines.
* unlimited/init.c: Run all tests successfully with maxixum number of
priorities as 16 instead of 256. This was done by temporarily
modifying the score priority.h maximum. This allowed testing of all
API code to ensure that it worked properly with a reduced number of
priorities. Most modifications were to switch from hard-coded maximum
to using the API provided methods to determine maximum number of
priority levels.
* fileio/init.c: Add explicit creation of /etc/passwd and /etc/group so
we have a test case for real password checking.
* paranoia/paranoia.c: Add missing prototypes.
* unlimited/system.h: Tighten configuration for stack space.
* fileio/init.c: When USE_SHELL not defined, do not attempt to
configure shell.
* unlimited/system.h: 10000 task ids is too many for some targets.
* unlimited/system.h: Support up to 10K tasks in loop. With 64MB on
pc386 and configured for unified workspace, you can get close to
this.
* fileio/system.h: Rename STACK_CHECKER_ON to more appropriate
CONFIGURE_STACK_CHECKER_ENABLED.
