* | score: Delete _Thread_Dispatch_set_disable_level() | Sebastian Huber | 2014-03-06 | 1 | -1/+0 |
| | | | | | This function was only used in some tests and can be replaced with other functions. | ||||
* | rhealstone: Add start end and messages | Joel Sherrill | 2014-01-07 | 6 | -0/+18 |
* | rhealstone: Add rh prefix to all test names | Joel Sherrill | 2014-01-05 | 26 | -152/+159 |
| | | | | This makes them easier to spot as a group in wildcard searches. | ||||
* | rhealstone/*.c: Add Print_Warning() call to indicate debug enabled | Joel Sherrill | 2014-01-05 | 6 | -1/+11 |
* | rhealstone/README: Formatting | Joel Sherrill | 2014-01-05 | 1 | -4/+5 |
* | Added Rhealstone benchmark to testsuites | Daniel Ramirez | 2014-01-05 | 21 | -0/+1232 |
The Rhealstone benchmarks six operations that are critical components of a real-time system. It allows for an objective analysis to be performed, and allows for comparisons between systems. See rhealstone/README for more information. |
