path: root/testsuites/rhealstone (follow)
* testsuite: Add a common test configuration. Fix configure.ac and Makefile.am ↵Chris Johns2017-04-042-9/+10
| | | | | | | | | | | | | | | | | | | | | | | | | | errors. - Add a top level test configuration file for test states that are common to all BSPs. This saves adding a test configuration (tcfg) file for every BSP. - Add the test states 'user-input' and 'benchmark'. This lets 'rtems-test' stop the test rather than waiting for a timeout or letting a benchmark run without the user asking for it to run. - Implement rtems-test-check in Python to make it faster. The shell script had grown to a point it was noticably slowing the build down. - Fix the configure.ac and Makefile.am files for a number of the test directories. The files are difficiult to keep in sync with the number of tests and mistakes can happen such as tests being left out of the build. The test fsrofs01 is an example. Also a there was a mix of SUBDIRS and _SUBDIRS being used and only _SUBDIRS should be used. - Fix the test fsrofs01 so it compiles. Closes #2963.
* rhealstone/rhtaskpreempt/taskpreempt.c: Fix warning due to oddly placed ↵Joel Sherrill2016-01-241-2/+2
| | | | semi-colon
* Update bug report URLSebastian Huber2014-12-051-1/+1
* Use correct prototype of benchmark_timer_read()Joel Sherrill2014-09-166-6/+6
| | | | | | | | | | | | | | This change starts with removing the effectively empty file timerdrv.h. The prototypes for benchmark_timer_XXX() were in btimer.h which was not universally used. Thus every use of timerdrv.h had to be changed to btimer.h. Then the prototypes for benchmark_timer_read() had to be adjusted to return benchmark_timer_t rather than int or uint32_t. I took this opportunity to also correct the file headers to separate the copyright from the file description comments which is needed to ensure the copyright isn't propagated into Doxygen output.
* rhealstone: Produce proper begin/end messagesSebastian Huber2014-06-036-12/+25
* score: Static scheduler configurationSebastian Huber2014-04-151-1/+5
| | | | | | Do not allocate the scheduler control structures from the workspace. This is a preparation step for configuration of clustered/partitioned schedulers on SMP.
* rhealstone/rhmlatency: Fix configurationSebastian Huber2014-04-041-0/+2
* score: Delete _Thread_Dispatch_set_disable_level()Sebastian Huber2014-03-061-1/+0
| | | | | This function was only used in some tests and can be replaced with other functions.
* rhealstone: Add start end and messagesJoel Sherrill2014-01-076-0/+18
* rhealstone: Add rh prefix to all test namesJoel Sherrill2014-01-0526-152/+159
| | | | This makes them easier to spot as a group in wildcard searches.
* rhealstone/*.c: Add Print_Warning() call to indicate debug enabledJoel Sherrill2014-01-056-1/+11
* rhealstone/README: FormattingJoel Sherrill2014-01-051-4/+5
* Added Rhealstone benchmark to testsuitesDaniel Ramirez2014-01-0521-0/+1232
The Rhealstone benchmarks six operations that are critical components of a real-time system. It allows for an objective analysis to be performed, and allows for comparisons between systems. See rhealstone/README for more information.
