path: root/testsuites/rhealstone/Makefile.am (follow)
* testsuite: Add a common test configuration. Fix configure.ac and Makefile.am ↵Chris Johns2017-04-041-6/+7
| | | | | | | | | | | | | | | | | | | | | | | | | | errors. - Add a top level test configuration file for test states that are common to all BSPs. This saves adding a test configuration (tcfg) file for every BSP. - Add the test states 'user-input' and 'benchmark'. This lets 'rtems-test' stop the test rather than waiting for a timeout or letting a benchmark run without the user asking for it to run. - Implement rtems-test-check in Python to make it faster. The shell script had grown to a point it was noticably slowing the build down. - Fix the configure.ac and Makefile.am files for a number of the test directories. The files are difficiult to keep in sync with the number of tests and mistakes can happen such as tests being left out of the build. The test fsrofs01 is an example. Also a there was a mix of SUBDIRS and _SUBDIRS being used and only _SUBDIRS should be used. - Fix the test fsrofs01 so it compiles. Closes #2963.
* rhealstone: Add rh prefix to all test namesJoel Sherrill2014-01-051-1/+6
| | | | This makes them easier to spot as a group in wildcard searches.
* Added Rhealstone benchmark to testsuitesDaniel Ramirez2014-01-051-0/+6
The Rhealstone benchmarks six operations that are critical components of a real-time system. It allows for an objective analysis to be performed, and allows for comparisons between systems. See rhealstone/README for more information.
