The mq_open() function returns a descriptor to a POSIX message queue
object identified by a name. This is similar to sem_open(). In
contrast to the POSIX semaphore the POSIX message queues use a separate
object for the descriptor. This extra object is superfluous, since the
object identifier can be used directly for this purpose, just like for
the semaphores.
Update #2702.
Update #2555.
Adds future compatibility with strict monontonic software timestamps.
output.
expectations
This makes it easier for scripts to parse correctly.
The psxtmthread05 test was testing the functionality meant for
psxtmthread06. This patch copies the psxtmthread05 to psxtmthread06
and modifies psxtmthread05 to test the intended functionality.
* update psxtmtests_plan.csv to reflect that the test has been
implemented.
* Test implemented in db08c3897f86f99d5a4259506d4463b0ec440762
New test psxtmthread 05 uses two tasks and times lowering
the priority of one task plus the preemption and context switch
to the other task.
Minor modifications were made to the student version to
clearify methods and to clean up test output.
Modifications were made to this submission allow the same init.c
file to be ran by three tests that were very similar using posix
pthread_cond_timedwait and pthread_cond_wait.
This reverts commit cf42a6ea9dbb6ebee498ae8db319d3e475bcd6be.
for details.
* psxtmmq01/init.c: Make benchmark_mq_open,
benchmark_mq_open_second, benchmark_mq_close,
benchmark_mq_close_second, benchmark_mq_unlink, benchmark_mq_notify,
benchmark_mq_send, benchmark_mq_receive, benchmark_mq_timedsend,
benchmark_mq_timedreceive static.
* psxtmmutex01/init.c: Make test_mutex_create, test_mutex_destroy
static.
* psxtmsem02/init.c: benchmark_sem_getvalue, benchmark_sem_wait,
benchmark_sem_post, benchmark_sem_trywait_available,
benchmark_sem_trywait_not_available static.
* psxtmbarrier01/init.c: Make benchmark_pthread_barrier_init,
benchmark_pthread_barrier_destroy static.
* psxtmkey01/init.c: Make benchmark_pthread_key_create,
benchmark_pthread_key_delete static.
* psxtmrwlock01/init.c: Make benchmark_pthread_rwlock_init,
benchmark_pthread_rwlock_rdlock, benchmark_pthread_rwlock_unlock,
benchmark_pthread_rwlock_tryrdlock,
benchmark_pthread_rwlock_timedrdlock,
benchmark_pthread_rwlock_wrlock,
benchmark_pthread_rwlock_trywrlock,
benchmark_pthread_rwlock_timedwrlock,
benchmark_pthread_rwlock_destroy static.
* psxtmsem01/init.c: Make benchmark_sem_init,
benchmark_sem_destroy, benchmark_sem_open, benchmark_sem_close,
benchmark_sem_unlink, benchmark_sem_open_second,
benchmark_sem_close_second static.
* psxtmthread01/init.c: Make benchmark_pthread_create static.
PR 1589/build
* psxtmbarrier01/Makefile.am, psxtmbarrier02/Makefile.am,
psxtmbarrier03/Makefile.am, psxtmkey01/Makefile.am,
psxtmkey02/Makefile.am, psxtmmq01/Makefile.am,
psxtmmutex01/Makefile.am, psxtmmutex02/Makefile.am,
psxtmmutex03/Makefile.am, psxtmmutex04/Makefile.am,
psxtmmutex05/Makefile.am, psxtmmutex06/Makefile.am,
psxtmmutex07/Makefile.am, psxtmnanosleep01/Makefile.am,
psxtmnanosleep02/Makefile.am, psxtmrwlock01/Makefile.am,
psxtmrwlock02/Makefile.am, psxtmrwlock03/Makefile.am,
psxtmrwlock04/Makefile.am, psxtmrwlock05/Makefile.am,
psxtmrwlock06/Makefile.am, psxtmrwlock07/Makefile.am,
psxtmsem01/Makefile.am, psxtmsem02/Makefile.am,
psxtmsem03/Makefile.am, psxtmsem04/Makefile.am,
psxtmsem05/Makefile.am, psxtmsleep01/Makefile.am,
psxtmsleep02/Makefile.am, psxtmthread01/Makefile.am,
psxtmthread03/Makefile.am: Remove obsolete optional manager
capability.
