path: root/testsuites/psxtmtests (follow)
* psxtmtests: Use timeout in more distant futureAlexander Krutwig2015-03-311-2/+3
| | | | Adds future compatibility with strict monontonic software timestamps.
* Update bug report URLSebastian Huber2014-12-051-1/+1
* Use correct prototype of benchmark_timer_read()Joel Sherrill2014-09-1643-43/+43
| | | | | | | | | | | | | | This change starts with removing the effectively empty file timerdrv.h. The prototypes for benchmark_timer_XXX() were in btimer.h which was not universally used. Thus every use of timerdrv.h had to be changed to btimer.h. Then the prototypes for benchmark_timer_read() had to be adjusted to return benchmark_timer_t rather than int or uint32_t. I took this opportunity to also correct the file headers to separate the copyright from the file description comments which is needed to ensure the copyright isn't propagated into Doxygen output.
* Misc psxtmtests: Use uint32_t not long for end_time to match printf() format ↵Joel Sherrill2014-09-0411-26/+27
| | | | expectations
* psxtmtests: Add test.h supportbjorn larsson2014-03-2544-88/+176
* Change all references of rtems.com to rtems.org.Chris Johns2014-03-2188-88/+88
* psxtmtests: added psxtmcond07 testDaniel Ramirez2013-12-096-1/+183
* psxtmtests_plan.csv: Update messagesJoel Sherrill2013-12-071-120/+120
* psxtmtests: Make output more uniformJoel Sherrill2013-12-0743-125/+125
* psxtmtests: added new psxtmthread04 testDaniel Ramirez2013-12-026-2/+153
* pstmtests_plan.csv: Update to reflect psxtmcond 09 and 10 exitDaniel Ramirez2013-12-011-2/+2
* psxtmtests: added psxtmcond06 testDaniel Ramirez2013-12-016-1/+187
* psxtmtests: added new psxtmcond04 test, fixed psxtmcond03Daniel Ramirez2013-11-307-8/+179
* psxtmbarrier04/init.c: Fix warningsJoel Sherrill2013-11-301-0/+3
* psxtmthread02/init.c: Fix warningsJoel Sherrill2013-11-301-4/+12
* fixed psxtmthread02 test, updated .csv to be in sync and added test .docsDaniel Ramirez2013-11-308-41/+105
* psxtmtests_plan.csv: Replace comma with colonJoel Sherrill2013-11-301-8/+8
| | | | This makes it easier for scripts to parse correctly.
* psxtmtests: Added in new psxtmbarrier04 test, release, preemptDaniel Ramirez2013-11-306-1/+148
* psxtmtests_plan.csv: Avoid comma in descriptionsJoel Sherrill2013-11-281-20/+21
* psxtmthread05: delete spurious .cvsignore fileGedare Bloom2013-11-271-2/+0
* psxtmtests: copy psxtmthread05 to psxtmthread06, fix psxtmthread05Daniel Ramirez2013-11-279-11/+162
| | | | | | The psxtmthread05 test was testing the functionality meant for psxtmthread06. This patch copies the psxtmthread05 to psxtmthread06 and modifies psxtmthread05 to test the intended functionality.
* psxtmtests_plan.csv: Add explicit No statusJoel Sherrill2013-11-271-30/+30
* Indicate that test psxtmthread05 has been implementedChirayu Desai2013-11-271-1/+1
| | | | | | * update psxtmtests_plan.csv to reflect that the test has been implemented. * Test implemented in db08c3897f86f99d5a4259506d4463b0ec440762
* psxtmtests: Add psxtmthread05 for pthread_setschedparamChirayu Desai2013-11-275-0/+153
| | | | | | New test psxtmthread 05 uses two tasks and times lowering the priority of one task plus the preemption and context switch to the other task.
* testsuites: Fix warningsSebastian Huber2013-04-113-5/+6
* RTEMS: Delete ChangeLog files.Gedare Bloom2013-03-081-386/+0
| | | | | | | | | This commit deletes all RTEMS ChangeLog files. These files have been abandoned since converting to git version control. The historical data may be recovered by checking out any commit before this one. Most of the contents of these ChangeLog files can also be found in the git log. Two external ChangeLog files, ChangeLog.slac and ChangeLog.zlib, remain.
* psxtmtests: Generating .scn (Screen Shots) #8Alex Ivanov2013-01-157-0/+30
* Create POSIX Timing Test psxtmthread02Christopher Kerl2013-01-145-0/+120
| | | | | Minor modifications were made to the student version to clearify methods and to clean up test output.
* Generating .scn (Screen Shots) #7Alex Ivanov2013-01-145-0/+27
* Create POSIX Timing Test psxtmcond09Christopher Kerl2013-01-119-0/+290
| | | | | | Modifications were made to this submission allow the same init.c file to be ran by three tests that were very similar using posix pthread_cond_timedwait and pthread_cond_wait.
* Create POSIX Timing Test psxtmcond03Christopher Kerl2013-01-115-0/+144
* Added more condition variable timing tests.Jennifer Averett2013-01-111-2/+4
* Create POSIX Timing Test psxtmcond05Christopher Kerl2013-01-095-0/+111
* Create POSIX Timing Test psxtmcond02Christopher Kerl2013-01-095-0/+113
* GCI: Create POSIX Timing Test psxtmcond01Christopher Kerl2013-01-095-0/+130
* psxtmtests_plan.csv: Identify Conditional Variable CasesJoel Sherrill2012-11-251-10/+10
* Revert "Add config.h.in."Gedare Bloom2012-08-061-99/+0
| | | | This reverts commit cf42a6ea9dbb6ebee498ae8db319d3e475bcd6be.
* Require automake-1.12.2.Ralf Corsépius2012-07-191-1/+1
* Require autoconf-2.69.Ralf Corsépius2012-07-191-1/+1
* Add config.h.in.Ralf Corsépius2012-05-241-0/+99
* psxtmtests - Eliminate missing prototype warningsJoel Sherrill2012-05-1131-32/+167
* Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill2012-05-1196-289/+0
* Revert: Remove CVS IdsJoel Sherrill2012-05-0733-0/+161
* Remove CVS-Ids.Ralf Corsépius2012-05-0433-161/+0
* 2011-03-02 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsépius2012-03-024-17/+30
| | | | | | | | | | | | | * psxtmmq01/init.c: Make benchmark_mq_open, benchmark_mq_open_second, benchmark_mq_close, benchmark_mq_close_second, benchmark_mq_unlink, benchmark_mq_notify, benchmark_mq_send, benchmark_mq_receive, benchmark_mq_timedsend, benchmark_mq_timedreceive static. * psxtmmutex01/init.c: Make test_mutex_create, test_mutex_destroy static. * psxtmsem02/init.c: benchmark_sem_getvalue, benchmark_sem_wait, benchmark_sem_post, benchmark_sem_trywait_available, benchmark_sem_trywait_not_available static.
* Remove all .cvsignore files.Joel Sherrill2012-02-0132-77/+0
* 2011-12-13 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-12-136-21/+41
| | | | | | | | | | | | | | | | | | | | * psxtmbarrier01/init.c: Make benchmark_pthread_barrier_init, benchmark_pthread_barrier_destroy static. * psxtmkey01/init.c: Make benchmark_pthread_key_create, benchmark_pthread_key_delete static. * psxtmrwlock01/init.c: Make benchmark_pthread_rwlock_init, benchmark_pthread_rwlock_rdlock, benchmark_pthread_rwlock_unlock, benchmark_pthread_rwlock_tryrdlock, benchmark_pthread_rwlock_timedrdlock, benchmark_pthread_rwlock_wrlock, benchmark_pthread_rwlock_trywrlock, benchmark_pthread_rwlock_timedwrlock, benchmark_pthread_rwlock_destroy static. * psxtmsem01/init.c: Make benchmark_sem_init, benchmark_sem_destroy, benchmark_sem_open, benchmark_sem_close, benchmark_sem_unlink, benchmark_sem_open_second, benchmark_sem_close_second static. * psxtmthread01/init.c: Make benchmark_pthread_create static.
* 2011-12-08 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-12-0832-62/+52
| | | | | | | | | | | | | | | | | | | | | PR 1589/build * psxtmbarrier01/Makefile.am, psxtmbarrier02/Makefile.am, psxtmbarrier03/Makefile.am, psxtmkey01/Makefile.am, psxtmkey02/Makefile.am, psxtmmq01/Makefile.am, psxtmmutex01/Makefile.am, psxtmmutex02/Makefile.am, psxtmmutex03/Makefile.am, psxtmmutex04/Makefile.am, psxtmmutex05/Makefile.am, psxtmmutex06/Makefile.am, psxtmmutex07/Makefile.am, psxtmnanosleep01/Makefile.am, psxtmnanosleep02/Makefile.am, psxtmrwlock01/Makefile.am, psxtmrwlock02/Makefile.am, psxtmrwlock03/Makefile.am, psxtmrwlock04/Makefile.am, psxtmrwlock05/Makefile.am, psxtmrwlock06/Makefile.am, psxtmrwlock07/Makefile.am, psxtmsem01/Makefile.am, psxtmsem02/Makefile.am, psxtmsem03/Makefile.am, psxtmsem04/Makefile.am, psxtmsem05/Makefile.am, psxtmsleep01/Makefile.am, psxtmsleep02/Makefile.am, psxtmthread01/Makefile.am, psxtmthread03/Makefile.am: Remove obsolete optional manager capability.
* 2011-12-07 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-12-072-15/+19
| | | | * psxtmtests_plan.csv: Add more test cases.
* 2011-10-19 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-10-1931-66/+81
| | | | | | | | | | | | | | | * psxtmbarrier01/init.c, psxtmbarrier02/init.c, psxtmbarrier03/init.c, psxtmkey01/init.c, psxtmkey02/init.c, psxtmmq01/init.c, psxtmmutex01/init.c, psxtmmutex02/init.c, psxtmmutex03/init.c, psxtmmutex04/init.c, psxtmmutex05/init.c, psxtmmutex06/init.c, psxtmmutex07/init.c, psxtmnanosleep01/init.c, psxtmnanosleep02/init.c, psxtmrwlock01/init.c, psxtmrwlock02/init.c, psxtmrwlock03/init.c, psxtmrwlock04/init.c, psxtmrwlock05/init.c, psxtmrwlock06/init.c, psxtmrwlock07/init.c, psxtmsem01/init.c, psxtmsem02/init.c, psxtmsem03/init.c, psxtmsem04/init.c, psxtmsem05/init.c, psxtmsleep01/init.c, psxtmsleep02/init.c, psxtmthread03/init.c: Use benchmark_timer_t for benchmark_timer values (Avoid 64bit arch issues).
