Update #3382
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
output.
expectations
The psxtmthread05 test was testing the functionality meant for
psxtmthread06. This patch copies the psxtmthread05 to psxtmthread06
and modifies psxtmthread05 to test the intended functionality.
New test psxtmthread 05 uses two tasks and times lowering
the priority of one task plus the preemption and context switch
to the other task.
