Updates #3053.
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
output.
expectations
* psxtmbarrier01/init.c: Make benchmark_pthread_barrier_init,
benchmark_pthread_barrier_destroy static.
* psxtmkey01/init.c: Make benchmark_pthread_key_create,
benchmark_pthread_key_delete static.
* psxtmrwlock01/init.c: Make benchmark_pthread_rwlock_init,
benchmark_pthread_rwlock_rdlock, benchmark_pthread_rwlock_unlock,
benchmark_pthread_rwlock_tryrdlock,
benchmark_pthread_rwlock_timedrdlock,
benchmark_pthread_rwlock_wrlock,
benchmark_pthread_rwlock_trywrlock,
benchmark_pthread_rwlock_timedwrlock,
benchmark_pthread_rwlock_destroy static.
* psxtmsem01/init.c: Make benchmark_sem_init,
benchmark_sem_destroy, benchmark_sem_open, benchmark_sem_close,
benchmark_sem_unlink, benchmark_sem_open_second,
benchmark_sem_close_second static.
* psxtmthread01/init.c: Make benchmark_pthread_create static.
* psxtmbarrier01/init.c, psxtmbarrier02/init.c, psxtmbarrier03/init.c,
psxtmkey01/init.c, psxtmkey02/init.c, psxtmmq01/init.c,
psxtmmutex01/init.c, psxtmmutex02/init.c, psxtmmutex03/init.c,
psxtmmutex04/init.c, psxtmmutex05/init.c, psxtmmutex06/init.c,
psxtmmutex07/init.c, psxtmnanosleep01/init.c, psxtmnanosleep02/init.c,
psxtmrwlock01/init.c, psxtmrwlock02/init.c, psxtmrwlock03/init.c,
psxtmrwlock04/init.c, psxtmrwlock05/init.c, psxtmrwlock06/init.c,
psxtmrwlock07/init.c, psxtmsem01/init.c, psxtmsem02/init.c,
psxtmsem03/init.c, psxtmsem04/init.c, psxtmsem05/init.c,
psxtmsleep01/init.c, psxtmsleep02/init.c, psxtmthread03/init.c:
Use benchmark_timer_t for benchmark_timer values (Avoid 64bit
arch issues).
PR 1859/tests
* Makefile.am, configure.ac, psxtmtests_plan.csv: Add benchmark of
pthread_barrier_init and pthread_barrier_destroy.
* psxtmbarrier01/.cvsignore, psxtmbarrier01/Makefile.am,
psxtmbarrier01/init.c, psxtmbarrier01/psxtmbarrier01.doc: New files.
PR 1835/tests
mutex set and get priority ceiling.
* psxtmmutex07/.cvsignore, psxtmmutex07/Makefile.am,
psxtmmutex07/init.c, psxtmmutex07/psxtmmutex07.doc: New files.
PR 1831/tests
mutex init and destroy.
* psxtmmutex01/.cvsignore, psxtmmutex01/Makefile.am,
psxtmmutex01/init.c, psxtmmutex01/psxtmmutex01.doc: New files.
* psxtmnanosleep01/init.c, psxtmsleep01/init.c: Do not divide by
OPERATION_COUNT on single shot times.
* Makefile.am, configure.ac, psxtmtests_plan.csv: Add psxtmsleep01.
* psxtmsleep01/.cvsignore, psxtmsleep01/Makefile.am,
psxtmsleep01/Makefile.in, psxtmsleep01/init.c,
psxtmsleep01/psxtmsleep01.doc: New files.
* .cvsignore, ChangeLog, Makefile.am, README, configure.ac,
psxtmtests_plan.csv, psxtmmutex02/.cvsignore,
psxtmmutex02/Makefile.am, psxtmmutex02/init.c,
psxtmmutex02/psxtmmutex02.doc, psxtmthread01/.cvsignore,
psxtmthread01/Makefile.am, psxtmthread01/init.c,
psxtmthread01/psxtmthread01.doc, psxtmthread03/.cvsignore,
psxtmthread03/Makefile.am, psxtmthread03/init.c,
psxtmthread03/psxtmthread03.doc: New files.
