Update #3382
for details.
PR 1589/build
* psxtmbarrier01/Makefile.am, psxtmbarrier02/Makefile.am,
psxtmbarrier03/Makefile.am, psxtmkey01/Makefile.am,
psxtmkey02/Makefile.am, psxtmmq01/Makefile.am,
psxtmmutex01/Makefile.am, psxtmmutex02/Makefile.am,
psxtmmutex03/Makefile.am, psxtmmutex04/Makefile.am,
psxtmmutex05/Makefile.am, psxtmmutex06/Makefile.am,
psxtmmutex07/Makefile.am, psxtmnanosleep01/Makefile.am,
psxtmnanosleep02/Makefile.am, psxtmrwlock01/Makefile.am,
psxtmrwlock02/Makefile.am, psxtmrwlock03/Makefile.am,
psxtmrwlock04/Makefile.am, psxtmrwlock05/Makefile.am,
psxtmrwlock06/Makefile.am, psxtmrwlock07/Makefile.am,
psxtmsem01/Makefile.am, psxtmsem02/Makefile.am,
psxtmsem03/Makefile.am, psxtmsem04/Makefile.am,
psxtmsem05/Makefile.am, psxtmsleep01/Makefile.am,
psxtmsleep02/Makefile.am, psxtmthread01/Makefile.am,
psxtmthread03/Makefile.am: Remove obsolete optional manager
capability.
PR 1880/tests
* Makefile.am, configure.ac, psxtmtests_plan.csv: Add benchmark of
pthread_rwlock_timedwrlock - not available, blocks.
* psxtmrwlock04/.cvsignore, psxtmrwlock04/Makefile.am,
psxtmrwlock04/init.c, psxtmrwlock04/psxtmrwlock04.doc: New files.
PR 1874/tests
multiple pthread_rwlock operations that can be done as single shot
times.
* psxtmrwlock01/.cvsignore, psxtmrwlock01/Makefile.am,
psxtmrwlock01/init.c, psxtmrwlock01/psxtmrwlock01.doc: New files.
* .cvsignore, ChangeLog, Makefile.am, README, configure.ac,
psxtmtests_plan.csv, psxtmmutex02/.cvsignore,
psxtmmutex02/Makefile.am, psxtmmutex02/init.c,
psxtmmutex02/psxtmmutex02.doc, psxtmthread01/.cvsignore,
psxtmthread01/Makefile.am, psxtmthread01/init.c,
psxtmthread01/psxtmthread01.doc, psxtmthread03/.cvsignore,
psxtmthread03/Makefile.am, psxtmthread03/init.c,
psxtmthread03/psxtmthread03.doc: New files.
