Update #3382
maintain.
Update #3254.
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
POSIX rwlocks are now available in all configurations and no longer
depend on --enable-posix.
Update #2514.
Update #3115.
output.
for details.
PR 1589/build
* psxtmbarrier01/Makefile.am, psxtmbarrier02/Makefile.am,
psxtmbarrier03/Makefile.am, psxtmkey01/Makefile.am,
psxtmkey02/Makefile.am, psxtmmq01/Makefile.am,
psxtmmutex01/Makefile.am, psxtmmutex02/Makefile.am,
psxtmmutex03/Makefile.am, psxtmmutex04/Makefile.am,
psxtmmutex05/Makefile.am, psxtmmutex06/Makefile.am,
psxtmmutex07/Makefile.am, psxtmnanosleep01/Makefile.am,
psxtmnanosleep02/Makefile.am, psxtmrwlock01/Makefile.am,
psxtmrwlock02/Makefile.am, psxtmrwlock03/Makefile.am,
psxtmrwlock04/Makefile.am, psxtmrwlock05/Makefile.am,
psxtmrwlock06/Makefile.am, psxtmrwlock07/Makefile.am,
psxtmsem01/Makefile.am, psxtmsem02/Makefile.am,
psxtmsem03/Makefile.am, psxtmsem04/Makefile.am,
psxtmsem05/Makefile.am, psxtmsleep01/Makefile.am,
psxtmsleep02/Makefile.am, psxtmthread01/Makefile.am,
psxtmthread03/Makefile.am: Remove obsolete optional manager
capability.
* psxtmbarrier01/init.c, psxtmbarrier02/init.c, psxtmbarrier03/init.c,
psxtmkey01/init.c, psxtmkey02/init.c, psxtmmq01/init.c,
psxtmmutex01/init.c, psxtmmutex02/init.c, psxtmmutex03/init.c,
psxtmmutex04/init.c, psxtmmutex05/init.c, psxtmmutex06/init.c,
psxtmmutex07/init.c, psxtmnanosleep01/init.c, psxtmnanosleep02/init.c,
psxtmrwlock01/init.c, psxtmrwlock02/init.c, psxtmrwlock03/init.c,
psxtmrwlock04/init.c, psxtmrwlock05/init.c, psxtmrwlock06/init.c,
psxtmrwlock07/init.c, psxtmsem01/init.c, psxtmsem02/init.c,
psxtmsem03/init.c, psxtmsem04/init.c, psxtmsem05/init.c,
psxtmsleep01/init.c, psxtmsleep02/init.c, psxtmthread03/init.c:
Use benchmark_timer_t for benchmark_timer values (Avoid 64bit
arch issues).
* psxtmrwlock03/init.c: Fix abstime issue. Time is now reasonable.
PR 1878/tests
* Makefile.am, configure.ac, psxtmtests_plan.csv: Add benchmark of
pthread_rwlock_timedrdlock - not available, blocks.
* psxtmrwlock03/.cvsignore, psxtmrwlock03/Makefile.am,
psxtmrwlock03/init.c, psxtmrwlock03/psxtmrwlock03.doc: New files.
