2022-06-14 | psxtmtests/*/*.doc: Change license to BSD-2 | Joel Sherrill | 1 | -3/+22 | |
Updates #3053. | |||||
2014-03-21 | Change all references of rtems.com to rtems.org. | Chris Johns | 1 | -1/+1 | |
2012-05-11 | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 1 | -3/+0 | |
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed. | |||||
2011-08-04 | 2011-08-04 Ricardo Aguirre <el.mastin@ymail.com> | Joel Sherrill | 1 | -3/+4 | |
* psxtmrwlock01/init.c, psxtmrwlock01/psxtmrwlock01.doc: Update. | |||||
2011-08-02 | 2011-08-02 Ricardo Aguirre <el.mastin@ymail.com> | Joel Sherrill | 1 | -0/+23 | |
PR 1874/tests * Makefile.am, configure.ac, psxtmtests_plan.csv: Add benchmark of multiple pthread_rwlock operations that can be done as single shot times. * psxtmrwlock01/.cvsignore, psxtmrwlock01/Makefile.am, psxtmrwlock01/init.c, psxtmrwlock01/psxtmrwlock01.doc: New files. |
