output.
for details.
* psxtmbarrier01/init.c: Make benchmark_pthread_barrier_init,
benchmark_pthread_barrier_destroy static.
* psxtmkey01/init.c: Make benchmark_pthread_key_create,
benchmark_pthread_key_delete static.
* psxtmrwlock01/init.c: Make benchmark_pthread_rwlock_init,
benchmark_pthread_rwlock_rdlock, benchmark_pthread_rwlock_unlock,
benchmark_pthread_rwlock_tryrdlock,
benchmark_pthread_rwlock_timedrdlock,
benchmark_pthread_rwlock_wrlock,
benchmark_pthread_rwlock_trywrlock,
benchmark_pthread_rwlock_timedwrlock,
benchmark_pthread_rwlock_destroy static.
* psxtmsem01/init.c: Make benchmark_sem_init,
benchmark_sem_destroy, benchmark_sem_open, benchmark_sem_close,
benchmark_sem_unlink, benchmark_sem_open_second,
benchmark_sem_close_second static.
* psxtmthread01/init.c: Make benchmark_pthread_create static.
PR 1589/build
* psxtmbarrier01/Makefile.am, psxtmbarrier02/Makefile.am,
psxtmbarrier03/Makefile.am, psxtmkey01/Makefile.am,
psxtmkey02/Makefile.am, psxtmmq01/Makefile.am,
psxtmmutex01/Makefile.am, psxtmmutex02/Makefile.am,
psxtmmutex03/Makefile.am, psxtmmutex04/Makefile.am,
psxtmmutex05/Makefile.am, psxtmmutex06/Makefile.am,
psxtmmutex07/Makefile.am, psxtmnanosleep01/Makefile.am,
psxtmnanosleep02/Makefile.am, psxtmrwlock01/Makefile.am,
psxtmrwlock02/Makefile.am, psxtmrwlock03/Makefile.am,
psxtmrwlock04/Makefile.am, psxtmrwlock05/Makefile.am,
psxtmrwlock06/Makefile.am, psxtmrwlock07/Makefile.am,
psxtmsem01/Makefile.am, psxtmsem02/Makefile.am,
psxtmsem03/Makefile.am, psxtmsem04/Makefile.am,
psxtmsem05/Makefile.am, psxtmsleep01/Makefile.am,
psxtmsleep02/Makefile.am, psxtmthread01/Makefile.am,
psxtmthread03/Makefile.am: Remove obsolete optional manager
capability.
* psxtmbarrier01/init.c, psxtmbarrier02/init.c, psxtmbarrier03/init.c,
psxtmkey01/init.c, psxtmkey02/init.c, psxtmmq01/init.c,
psxtmmutex01/init.c, psxtmmutex02/init.c, psxtmmutex03/init.c,
psxtmmutex04/init.c, psxtmmutex05/init.c, psxtmmutex06/init.c,
psxtmmutex07/init.c, psxtmnanosleep01/init.c, psxtmnanosleep02/init.c,
psxtmrwlock01/init.c, psxtmrwlock02/init.c, psxtmrwlock03/init.c,
psxtmrwlock04/init.c, psxtmrwlock05/init.c, psxtmrwlock06/init.c,
psxtmrwlock07/init.c, psxtmsem01/init.c, psxtmsem02/init.c,
psxtmsem03/init.c, psxtmsem04/init.c, psxtmsem05/init.c,
psxtmsleep01/init.c, psxtmsleep02/init.c, psxtmthread03/init.c:
Use benchmark_timer_t for benchmark_timer values (Avoid 64bit
arch issues).
PR 1843/tests
* Makefile.am, configure.ac, psxtmtests_plan.csv: Add benchmark of key
create and delete.
* psxtmkey01/.cvsignore, psxtmkey01/Makefile.am, psxtmkey01/init.c,
psxtmkey01/psxtmkey01.doc: New files.
