path: root/testsuites/psxtmtests/psxtmcond06 (follow)
* testsuite/psxtmtests: Merged nested Makefile.am files into one Makefile.amChris Johns2018-04-101-27/+0
| | | | | | This change is part of the testsuite Makefile.am reorganization. Update #3382
* Remove coverhd.hSebastian Huber2017-11-241-1/+0
| | | | | | | This header file contained timing overhead values which are hard to maintain. Update #3254.
* tests: Use simple console driverSebastian Huber2017-11-061-1/+1
| | | | | Update #3170. Update #3199.
* tests: Remove TEST_INITSebastian Huber2017-10-281-2/+0
| | | | | | | | The TEST_EXTERN is a used only by the system.h style tests and they use CONFIGURE_INIT appropriately. Update #3170. Update #3199.
* testsuite: Use printk for all test output where possible.Chris Johns2017-10-231-0/+2
| | | | | | | | | | - Remove the printf support leaving the direct printk support configured with TESTS_USE_PRINTK and all other output goes via a buffered vsniprintf call to printk. - Control the test's single init for functions and global data with TEST_INIT and not CONFIGURE_INIT. They are now separate. Updates #3170.
* posix: Implement self-contained POSIX mutexSebastian Huber2017-10-051-1/+0
| | | | | | | | POSIX mutexes are now available in all configurations and no longer depend on --enable-posix. Update #2514. Update #3112.
* posix: Implement self-contained POSIX condvarSebastian Huber2017-10-051-1/+0
| | | | | | | | POSIX condition variables are now available in all configurations and no longer depend on --enable-posix. Update #2514. Update #3113.
* Use correct prototype of benchmark_timer_read()Joel Sherrill2014-09-161-1/+1
| | | | | | | | | | | | | | This change starts with removing the effectively empty file timerdrv.h. The prototypes for benchmark_timer_XXX() were in btimer.h which was not universally used. Thus every use of timerdrv.h had to be changed to btimer.h. Then the prototypes for benchmark_timer_read() had to be adjusted to return benchmark_timer_t rather than int or uint32_t. I took this opportunity to also correct the file headers to separate the copyright from the file description comments which is needed to ensure the copyright isn't propagated into Doxygen output.
* Misc psxtmtests: Use uint32_t not long for end_time to match printf() format ↵Joel Sherrill2014-09-041-1/+1
| | | | expectations
* psxtmtests: Add test.h supportbjorn larsson2014-03-251-2/+4
* Change all references of rtems.com to rtems.org.Chris Johns2014-03-212-2/+2
* psxtmtests: Make output more uniformJoel Sherrill2013-12-071-2/+2
* psxtmtests: added psxtmcond06 testDaniel Ramirez2013-12-013-0/+184
