* | Use correct prototype of benchmark_timer_read() | Joel Sherrill | 2014-09-16 | 1 | -1/+1 |
| | | | | | | | | | | | | | | This change starts with removing the effectively empty file timerdrv.h. The prototypes for benchmark_timer_XXX() were in btimer.h which was not universally used. Thus every use of timerdrv.h had to be changed to btimer.h. Then the prototypes for benchmark_timer_read() had to be adjusted to return benchmark_timer_t rather than int or uint32_t. I took this opportunity to also correct the file headers to separate the copyright from the file description comments which is needed to ensure the copyright isn't propagated into Doxygen output. | ||||
* | Misc psxtmtests: Use uint32_t not long for end_time to match printf() format ↵ | Joel Sherrill | 2014-09-04 | 1 | -2/+2 |
| | | | | expectations | ||||
* | psxtmtests: Add test.h support | bjorn larsson | 2014-03-25 | 1 | -2/+4 |
* | Change all references of rtems.com to rtems.org. | Chris Johns | 2014-03-21 | 2 | -2/+2 |
* | psxtmtests: Make output more uniform | Joel Sherrill | 2013-12-07 | 1 | -2/+2 |
* | fixed psxtmthread02 test, updated .csv to be in sync and added test .docs | Daniel Ramirez | 2013-11-30 | 1 | -2/+12 |
* | testsuites: Fix warnings | Sebastian Huber | 2013-04-11 | 1 | -0/+1 |
* | Create POSIX Timing Test psxtmcond05 | Christopher Kerl | 2013-01-09 | 3 | -0/+109 |
