path: root/testsuites/psxtmtests/psxtmbarrier04 (follow)
* Use correct prototype of benchmark_timer_read()Joel Sherrill2014-09-161-1/+1
| | | | | | | | | | | | | | This change starts with removing the effectively empty file timerdrv.h. The prototypes for benchmark_timer_XXX() were in btimer.h which was not universally used. Thus every use of timerdrv.h had to be changed to btimer.h. Then the prototypes for benchmark_timer_read() had to be adjusted to return benchmark_timer_t rather than int or uint32_t. I took this opportunity to also correct the file headers to separate the copyright from the file description comments which is needed to ensure the copyright isn't propagated into Doxygen output.
* psxtmtests: Add test.h supportbjorn larsson2014-03-251-2/+4
* Change all references of rtems.com to rtems.org.Chris Johns2014-03-212-2/+2
* psxtmtests: Make output more uniformJoel Sherrill2013-12-071-1/+1
* psxtmbarrier04/init.c: Fix warningsJoel Sherrill2013-11-301-0/+3
* psxtmtests: Added in new psxtmbarrier04 test, release, preemptDaniel Ramirez2013-11-303-0/+145
