updates #2732
The psxtmthread05 test was testing the functionality meant for
psxtmthread06. This patch copies the psxtmthread05 to psxtmthread06
and modifies psxtmthread05 to test the intended functionality.
New test psxtmthread 05 uses two tasks and times lowering
the priority of one task plus the preemption and context switch
to the other task.
Minor modifications were made to the student version to
clearify methods and to clean up test output.
Modifications were made to this submission allow the same init.c
file to be ran by three tests that were very similar using posix
pthread_cond_timedwait and pthread_cond_wait.
for details.
PR 1903/testing
* Makefile.am, configure.ac, psxtmtests_plan.csv: Add test for message
queues which covers most open, close, unlink cases as well as
send/receive which do not involve task state changes.
* psxtmmq01/.cvsignore, psxtmmq01/Makefile.am, psxtmmq01/init.c,
psxtmmq01/psxtmmq01.doc: New files.
PR 1888/tests
* Makefile.am, configure.ac, psxtmtests_plan.csv: Add benchmark of
pthread_rwlock_unlock - thread waiting, preempt.
* psxtmrwlock07/.cvsignore, psxtmrwlock07/Makefile.am,
psxtmrwlock07/init.c, psxtmrwlock07/psxtmrwlock07.doc: New files.
PR 1887/tests
pthread_rwlock_unlock - thread waiting, no preempt.
* psxtmrwlock06/.cvsignore, psxtmrwlock06/Makefile.am,
psxtmrwlock06/init.c, psxtmrwlock06/psxtmrwlock06.doc: New files.
PR 1881/tests
pthread_rwlock_timedwrlock - not available, blocks.
* psxtmrwlock05/.cvsignore, psxtmrwlock05/Makefile.am,
psxtmrwlock05/init.c, psxtmrwlock05/psxtmrwlock05.doc: New files.
PR 1880/tests
* psxtmrwlock04/.cvsignore, psxtmrwlock04/Makefile.am,
psxtmrwlock04/init.c, psxtmrwlock04/psxtmrwlock04.doc: New files.
PR 1878/tests
pthread_rwlock_timedrdlock - not available, blocks.
* psxtmrwlock03/.cvsignore, psxtmrwlock03/Makefile.am,
psxtmrwlock03/init.c, psxtmrwlock03/psxtmrwlock03.doc: New files.
PR 1875/tests
pthread_rwlock_rdlock - not available, blocks.
* psxtmrwlock02/.cvsignore, psxtmrwlock02/Makefile.am,
psxtmrwlock02/init.c, psxtmrwlock02/psxtmrwlock02.doc: New files.
PR 1874/tests
multiple pthread_rwlock operations that can be done as single shot
times.
* psxtmrwlock01/.cvsignore, psxtmrwlock01/Makefile.am,
psxtmrwlock01/init.c, psxtmrwlock01/psxtmrwlock01.doc: New files.
PR 1863/tests
pthread_barrier_wait - releasing, no preempt
* psxtmbarrier03/.cvsignore, psxtmbarrier03/Makefile.am,
psxtmbarrier03/init.c, psxtmbarrier03/psxtmbarrier03.doc: New files.
PR 1859/tests
pthread_barrier_wait - blocking
* psxtmbarrier02/.cvsignore, psxtmbarrier02/Makefile.am,
psxtmbarrier02/init.c, psxtmbarrier02/psxtmbarrier02.doc: New files.
PR 1859/tests
pthread_barrier_init and pthread_barrier_destroy.
* psxtmbarrier01/.cvsignore, psxtmbarrier01/Makefile.am,
psxtmbarrier01/init.c, psxtmbarrier01/psxtmbarrier01.doc: New files.
PR 1852/tests
sem_wait - not available, block.
* psxtmsem03/.cvsignore, psxtmsem03/Makefile.am, psxtmsem03/init.c,
psxtmsem03/psxtmsem03.doc: New files.
PR 1850/tests
sem_post - thread waiting, preempt.
* psxtmsem05/.cvsignore, psxtmsem05/Makefile.am, psxtmsem05/init.c,
psxtmsem05/psxtmsem05.doc: New files.
PR 1849/tests
sem_post - thread waiting, no preempt.
* psxtmsem04/.cvsignore, psxtmsem04/Makefile.am, psxtmsem04/init.c,
psxtmsem04/psxtmsem04.doc: New files.
PR 1847/tests
various non-blocking semaphore operations.
* psxtmsem02/.cvsignore, psxtmsem02/Makefile.am, psxtmsem02/init.c,
psxtmsem02/psxtmsem02.doc: New files.
PR 1846/tests
various sem_open(), sem_close(), sem_unlink(), sem_init(), and
sem_destroy() cases.
* psxtmsem01/.cvsignore, psxtmsem01/Makefile.am, psxtmsem01/init.c,
psxtmsem01/psxtmsem01.doc: New files.
PR 1835/tests
* Makefile.am, configure.ac: Add benchmark of pthread_mutex_timedlock -
* psxtmmutex04/.cvsignore, psxtmmutex04/Makefile.am,
psxtmmutex04/init.c, psxtmmutex04/psxtmmutex04.doc: New files.
pthread_mutex_unlock where it is unblocking threads with preemption.
* psxtmmutex06/.cvsignore, psxtmmutex06/Makefile.am,
psxtmmutex06/init.c, psxtmmutex06/psxtmmutex06.doc: New files.
* Makefile.am, configure.ac: Add benchmark of pthread_mutex_unlock
where it is unblocking threads without preemption.
* psxtmmutex05/.cvsignore, psxtmmutex05/Makefile.am,
psxtmmutex05/init.c, psxtmmutex05/psxtmmutex05.doc: New files.
PR 1843/tests
* Makefile.am, configure.ac, psxtmtests_plan.csv: Add benchmark of key
create and delete.
* psxtmkey01/.cvsignore, psxtmkey01/Makefile.am, psxtmkey01/init.c,
psxtmkey01/psxtmkey01.doc: New files.
PR 1840/tests
set and get.
* psxtmkey02/.cvsignore, psxtmkey02/Makefile.am, psxtmkey02/init.c,
psxtmkey02/psxtmkey02.doc: New files.
* configure.ac: Remove psxtmmutex04 until PR 1836 is processed.
PR 1835/tests
mutex set and get priority ceiling.
* psxtmmutex07/.cvsignore, psxtmmutex07/Makefile.am,
psxtmmutex07/init.c, psxtmmutex07/psxtmmutex07.doc: New files.
PR 1831/tests
mutex init and destroy.
* psxtmmutex01/.cvsignore, psxtmmutex01/Makefile.am,
psxtmmutex01/init.c, psxtmmutex01/psxtmmutex01.doc: New files.
* Makefile.am, configure.ac, psxtmtests_plan.csv: Add psxtmmutex03.
* psxtmmutex03/.cvsignore, psxtmmutex03/Makefile.am,
psxtmmutex03/init.c, psxtmmutex03/psxtmmutex03.doc: New files.
* psxtmtests/Makefile.am, psxtmtests/configure.ac,
psxtmtests/psxtmtests_plan.csv: Added nanosleep tests.
* psxtmtests/psxtmnanosleep01/Makefile.am,
psxtmtests/psxtmnanosleep01/init.c,
psxtmtests/psxtmnanosleep01/psxtmnanosleep01.doc,
psxtmtests/psxtmnanosleep02/Makefile.am,
psxtmtests/psxtmnanosleep02/init.c,
psxtmtests/psxtmnanosleep02/psxtmnanosleep02.doc: New files.
* Makefile.am, configure.ac: Add test case for sleep - blocking.
* psxtmsleep02/.cvsignore, psxtmsleep02/Makefile.am,
psxtmsleep02/init.c, psxtmsleep02/psxtmsleep02.doc: New files.
* Makefile.am, configure.ac, psxtmtests_plan.csv: Add psxtmsleep01.
* psxtmsleep01/.cvsignore, psxtmsleep01/Makefile.am,
psxtmsleep01/Makefile.in, psxtmsleep01/init.c,
psxtmsleep01/psxtmsleep01.doc: New files.
* configure.ac: Add AC_CONFIG_HEADER(config.h).
