line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Free deferred locations before the greedy memory allocation. This test
fails on powerpc/qoriq_e6500_64 otherwise.
This test uses fprintf().
This test uses sprintf().
Delete superfluous INTERNAL_ERROR_POSIX_INIT_THREAD_ENTRY_IS_NULL.
Update #3243.
Update #3020.
Remove POSIX_API_Control::created_with_explicit_scheduler. Add
Thread_Control::was_created_with_inherited_scheduler. This fixes also
pthread_getattr_np() for Classic tasks.
Update #2514.
Use the thread CPU budget algorithm to determine the scheduler policy.
This fixes also pthread_getschedparam() for Classic tasks.
Update #2514.
Update #3170.
Update #3199.
Close #3205.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
Update #3170.
Update #3199.
Update #3182.
Updates #3170.
Update #3117.
Update #3182.
Update #3182.
call to printk.
Updates #3170.
Move sporadic server scheduler parameters to
POSIX_API_Control::Sporadic. Remove redundant scheduler priority
parameter.
Update #2514.
The thread POSIX API control must be fully initialized in
_POSIX_Threads_Create_extension(), otherwise a pthread_setschedparam()
is broken for all threads not created with pthread_create().
Set default thread processor affinity to all processors of the
pre-allocated set. This allows to constify the
_POSIX_Threads_Default_attributes.
Update #2514.
Simplify
* pthread_attr_setstack(), and
* pthread_attr_setstacksize().
Update #2514.
Update #2514.
Close #3174.
Return stack area via pthread_getattr_np().
Simplify
* pthread_attr_setaffinity_np(), and
* pthread_attr_getaffinity_np()
and let the scheduler do the more sophisticated error checks.
Make
* pthread_setaffinity_np(),
* pthread_getaffinity_np(),
available in all configurations.
Update #2514.
Close #3145.
Close #3168.
Update #3111.
POSIX mutexes are now available in all configurations and no longer
depend on --enable-posix.
Update #2514.
Update #3112.
POSIX condition variables are now available in all configurations and no
longer depend on --enable-posix.
Update #2514.
Update #3113.
POSIX rwlocks are now available in all configurations and no longer
Update #2514.
Update #3115.
POSIX barriers are now available in all configurations and no longer
Update #2514.
Update #3114.
For semaphore object pointer and object validation see
POSIX_SEMAPHORE_VALIDATE_OBJECT().
Destruction or close of a busy semaphore returns an error status. The
object is not flushed.
POSIX semaphores are now available in all configurations and no longer
Update #2514.
Update #3116.
Close #3153.
closes #3148.
Close #3137.
Close #3126.
Close #3125.
This simplifies error handling later.
Update #3132.
Since we have only one process, sharing between processes is trivial.
Close #3124.
Update #2859.
These tests directly or indirectly use fprintf(), etc. which may use the
floating point unit.
Update #3076.
Updates #2859
