The dummy for setgroups() allows applications using it to build (for example
civetweb webserver).
Increase the invalid priority values to support test runs with
alternative schedulers offering a significant higher maximum priority
value, e.g. EDF.
Introduce map/unmap priority scheduler operations to map thread priority
values from/to the user domain to/from the scheduler domain. Use the
map priority operation to validate the thread priority. The EDF
schedulers use this new operation to distinguish between normal
priorities and priorities obtain through a job release.
Update #2173.
Update #2556.
Accept all priority values in pthread_mutexattr_setprioceiling(). This
is in line with POSIX and FreeBSD. The priority is validated in
pthread_mutex_init(). Validate the priority only for priority ceiling
mutexes.
updates #2608.
Update #2738.
Update #2738.
Close #2734.
Close #2735.
Return the unmodified thread priority value according to POSIX.
Close #2736.
Close #2721.
Close #2720.
Close #2719.
of this patch set.
Close #2718.
Update #2714.
Avoid output in signal handler to not disturb the timings which are
checked in this test. Use asserts to ensure proper signal handler
invocations.
POSIX mandates that an error code is returned and not -1 plus errno.
Close #2715.
Update #2714.
POSIX recommends ESRCH in case no thread exists for the specified
identifier.
Close #2713.
Update #2494.
Update #2555.
Account for the terminating null character. Use _POSIX_PATH_MAX instead
of NAME_MAX according to _POSIX_Semaphore_Manager_initialization() and
_POSIX_Message_queue_Manager_initialization().
The mq_open() function returns a descriptor to a POSIX message queue
object identified by a name. This is similar to sem_open(). In
contrast to the POSIX semaphore the POSIX message queues use a separate
object for the descriptor. This extra object is superfluous, since the
object identifier can be used directly for this purpose, just like for
the semaphores.
Update #2702.
Update #2555.
Remove unused supports_global parameter. Convert
_Objects_Initialize_information() to a macro to avoid use of
RTEMS_MULTIPROCESSING define for each caller.
Delete _POSIX_Mutex_Get(). Use _POSIX_Mutex_Get_interrupt_disable()
instead.
Update #2555.
Use proper CORE_semaphore_Status for _CORE_semaphore_Flush() and
_CORE_semaphore_Destroy() operations.
Close #2696.
This is the very simple implementation specified by the Open Group
for implementations with 1:1 kernel thread to user thread mappings.
http://pubs.opengroup.org/onlinepubs/9699919799/functions/pthread_getconcurrency.html
updates #2680.
POSIX key destructors must be called during thread restart. Just like
the POSIX cleanup handlers. This ensures that the TLS object
destructors are called during thread restart for example. It is
important for the global construction, which uses a thread restart to
run the Init task in a clean environment.
Close #2689.
Replace _Objects_Name_to_id_string() with _Objects_Get_by_name() since
all users of this function are interested in the object itself and not
the identifier.
Use the object allocator lock to protect the search.
Update #2555.
Use a red-black tree instead of delta chains.
Close #2344.
Update #2554.
Update #2555.
Close #2606.
Update #2344.
Update #2606.
Fix link-time errors introduced by
e39cdb875ce7458787b0be173f2f7893a774a673.
Update #2531.
This simplifies the global construction.
Update #2514.
The permission is check by the upper layer.
updates #2452.
closes #2431.
Update #2402.
Increase the ualarm timer interval to avoid endless signal handling.
The Allocator Mutex should not be locked outside a tested
service call. In an SMP test or heavily multithreaded test,
this is possible since another thread could have the lock
for an extended period of time but this is not the norm
for the tests.
updates 2319.
