These files had no file header, copyright, or license. Based on git
history, added appropriate copyrights and licenses.
Updates #3053.
Updates #3053.
Updates #3053.
Updates #3053.
Updates #3053.
Updates #3053.
Updates #3053.
Updates #3053.
Updates #3053.
Updates #3053.
Updates #3053.
Updates #3053.
Updates #3053.
Currently the following sequence causes a endless loop when extending an
IMFS file:
- Create a file with zero length and close it.
- Make sure nearly no allocatable memory is left.
- Open the file and write enough data into it that more than the
remaining memory will be used.
In that case when extending the IMFS file, the file currently need zero
blocks. If allocating enough new blocks fails, the already allocated new
blocks will be freed again.
The comparison of block>=old_blocks that has been used prior to this
patch compared two unsigned numbers. If old_blocks was zero, the
comparison of these two numbers always evaluated to true.
This patch frees the last block in a separate step to avoid this
problem.
Fixes #4639
Updates #4625.
Remove previous adjtime() implementation.
Update #2348.
Add a test to verify that mapping of machine exceptions to POSIX signals
operates properly when the application requests it.
Do not use a direct thread dispatch in
_Thread_queue_Surrender_priority_ceiling() since it may be used in condition
variables using POSIX mutexes.
Close #4526.
Close #3250.
Close #4081.
psxdevctl is supposed to return the value in errno. Before, it was
returning -1 and setting errno. Changed the tests to reflect these
changes. Added code from RRADE's posix_devctl.c.
Closes #4506
Limit the CLOCK_REALTIME setting to ensure that the CLOCK_REALTIME is defined
for a system uptime of at least 114 years.
Update #3373.
Closes #3373
confstr() style update
Signed-off-by: Eshan Dhawan <eshandhawan51@gmail.com>
the timer_create() method can use CLOCK_MONOTONIC
but there was no test for this.
Also it implements the functionality to
create a CLOCK_MONOTONIC timer and gettime() .
Closes #3888
Cloning under Cygwin turned off executable permission on these
files. This shows them as modified even though they have not
explicitly been touched. Executable permission should not have
been on for these files so this is just a minor clean up.
GCC originally needed this 20 years ago. No longer needed, so it
is being removed.
Closes #4391
Improved tests for utime() and utimes() and update license.
Close #4399
Close #4413.
Added conditionals to ensure that long double function tests were only
built when newlib has long double math functions.
Changed the way the tests were structured, added rtems_test_assert()'s,
updated psx13.scn and the license.
Update #3899
Do not adjust the stack area begin address since this may confuse the
stack allocator and result in failed stack frees.
Account for the alignment overhead in the stack space size estimate.
Check that the stack size is in the expected interval.
This fixes the following compiler warning:
testsuites/psxtests/psxndbm01/init.c:221:3: warning: 'strncpy' output truncated
before terminating nul copying 5 bytes from a string of the same length
221 | strncpy( test_strings, "Hello", 5 );
In addition, the comments from Sebastian Huber on an old version of
such a patch have been taken into account:
1) The use of `sizeof()` in `key.dsize = sizeof( test_strings );` is wrong.
2) There is no need to allocate the string. One can simply use a string
constant.
(See https://lists.rtems.org/pipermail/devel/2020-August/061418.html)
Update #4105.
Key_ID array must have the right size, it shall have a value greater
than zero.
Note: In Standard C and C++, zero-size array is not
allowed..
Since we need to test the strncpy function, using a character array with
a fixed array size in this case in place of character pointer can avoid
the string turncation warning.
Rename this header file to later move <t.h> to <rtems/test.h>. The main
feature provided by <rtems/test-info.h> is the output of standard test
information which is consumed by the RTEMS Tester.
Update #3199.
added tests for fesetexeptflag(), fegetexeptflag(),
fegetround(), fesetround().
In the test fegetround() does not return any flag
other then FE_TONEAREST in tests.
This is probably due to soft float.
The test complies successfully and returns assert
at fegetround()
Other tests run without any errors
tested on RISCV/rv32imac
The test prints nothing if runs successfully.
updates #2971
Signed-off-by: Eshan dhawan <eshandhawan51@gmail.com>
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
Close #3949.
This configuration option is obsolete since 2014.
Update #1367.
The IO library used a POSIX key to store an optional POSIX user
environment pointer. This pulled in the POSIX keys support in every
application configuration. Add a user environment pointer to the thread
control block (TCB) instead. Applications which do not need the POSIX
user environment will just get an overhead of one pointer per thread.
Close #3882.
The CONFIGURE_HAS_OWN_INIT_TASK_TABLE and
CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE are the last *_HAS_OWN_*
configuration options. These two options are probably unused, see also:
* https://lists.rtems.org/pipermail/users/2019-April/033129.html
* https://lists.rtems.org/pipermail/users/2019-April/033130.html
Removing them simplifies the configuration. If there is a real user need
which shows up after the removal, we can resurrect them on demand.
Using CONFIGURE_POSIX_HAS_OWN_INIT_THREAD_TABLE would have required the
use of the undocumented CONFIGURE_POSIX_INIT_THREAD_TABLE_NAME and
CONFIGURE_POSIX_INIT_THREAD_TABLE_SIZE configuration options.
Update #3874.
