Commit e22554535796fc29a7ed7c5e2338128e324a621d changed the error status
from ENOMEM to EAGAIN.
Update #3857.
The FACE Technical Standard, Edition 3.0 and later require the definition
of the subcommand SOCKCLOSE in <devctl.h>.
Reference: https://www.opengroup.org/face
closes #3856.
Update #3753.
Obsolete undocumented configuration options CONFIGURE_MAXIMUM_FIFOS and
CONFIGURE_MAXIMUM_PIPES. Replace these options with the new
CONFIGURE_IMFS_ENABLE_MKFIFO configuration option.
Update #3840.
Use separator character '_' for all test states.
This allows to use header includes in "config.h" to reduce the build
configuration checks.
Update #3818.
The functions expect a valid string as input according to POSIX. On
systems with a NULL pointer protection the test cases ended up in
exceptions.
Update #3818.
Move system.h to shared init.c.
Update #3818.
Update #3818.
Update #3794.
+ Modify POSIX thread create extension to ensure expected
initial signal mask is provided to system threads, initial
tasks and threads, and inheritied by tasks and threads.
+ Adds psxsignal07 to verify functionality when using a POSIX
Initialization thread and POSIX threads.
+ Adds psxsignal08 to verify functionality when using a Classic API
Initialization task and Classic API tasks.
Closes #3794.
Note that this test requires a functional fenv implementation. Some
targets have multilib variants where the fenv implementation is not
100% passing.
Joel Sherrill <joel@rtems.org> modified the patch to
add autoconf logic to avoid building this new test
unless the tool chain include <ndbm.h>. The ensures
that git bisect continues to work and that the addition
of this test does not immediately force the entire
community to update their tools.
Update #3732.
- Add a small memory test config file.
- Update the small memory PowerPC BSPs to use the new test config.
Update #3334.
Recursive usage of the same pthread_once_t results now in a deadlock.
Previously, an error of EINVAL was returned. This usage scenario is
invalid according to the POSIX pthread_once() specification.
Close #3334.
This file is unused and makes trouble on Windows.
Updates #3638.
Do not rely on compiler optimizations to throw away empty loops.
Close #3673.
Checking of atime in psxfile01 (line 713) can fail since a delay for
rtems_clock_get_ticks_per_second (line 699) gives a delay of less than
one second, depending on when the last tick occurred. atime is measured
in whole seconds, and a fast processor might read the file before a new
second occurs. Add one tick to the delay will solve the problem.
Updated licenses of the files I wrote to the 2-Clause BSD License.
This work was part of GCI 2018.
Statically allocate the objects information together with the initial
set of objects either via <rtems/confdefs.h>. Provide default object
informations with zero objects via librtemscpu.a. This greatly
simplifies the workspace size estimate. RTEMS applications which do not
use the unlimited objects option are easier to debug since all objects
reside now in statically allocated objects of the right types.
Close #3621.
The Copyright clause has been changed to BSD-2-Clause for all the tests in the
header files math.h , utime.h , fmtmsg.h and sys/ipc.h .
The Google Code-In finished before I could submit this, so I thought I would submit this instead of letting it go to waste.
poll.h implements poll() which is not supported by RTEMS according
to the RTEMS POSIX 1003.1 Compliance Guide. See #3657.
