* psx01/init.c, psx01/task.c, psx02/init.c, psx03/init.c,
psx04/init.c, psx05/init.c, psx06/init.c, psx07/init.c,
psx08/init.c, psx09/init.c, psx10/task.c, psx10/task2.c,
psx10/task3.c, psx11/init.c, psx12/init.c, psxalarm01/init.c,
psxbarrier01/test.c, psxkey01/init.c, psxkey01/task.c,
psxmsgq02/init.c, psxsignal01/init.c, psxualarm/init.c:
Use PRIxpthread_t to print pthread_t's.
* psxmsgq02/init.c:
Remove cast in call to fatal_posix_service_status_errno.
* psxenosys/init.c:
Add missing args in calls to execl, execlp, execle.
* psxhdrs/pthread36.c: Use HAVE_DECL_PTHREAD_ATTR_GETCPUTIME.
* psxhdrs/pthread35.c: Use HAVE_DECL_PTHREAD_ATTR_SETCPUTIME.
* psx07/init.c: Use HAVE_DECL_PTHREAD_ATTR_GETCPUTIME,
Add AC_CHECK_DECLS pthread_attr_getcputime, pthread_attr_setcputime.
* psxtimer01/psxtimer.c: Use %ld to print *.tv_nsec.
* psxsysconf/init.c: Use %ld to print *.tv_nsec.
* psxclock/init.c: Use %ld to print *.tv_nsec.
* psx06/init.c, psx06/system.h: Misc. warning fixes.
* psxsignal03/init.c: Add missing argument to printf.
* psxfile01/test.c: Use %zu instead of %d to print size_t's.
* psxclock/init.c, psxtimer01/psxtimer.c:
Use PRItime_t to print time_t's.
* configure.ac: Add AC_CHECK_HEADERS sys/mman.h.
Add AC_CHECK_DECLS pthread_atfork, adjtime, mprotect.
* psxtime/test.c: Include <sys/time.h>.
Conditionally add local prototype for adjtime()
if sys/time.h doesn't supply it.
* psx07/init.c: Include <sched.h>, <pthread.h>.
* psx05/init.c: Include <sched.h>.
* psx11/init.c, psx09/init.c: Include <sched.h>.
* psx12/init.c: Include <sched.h>.
* psxenosys/init.c: Include "pthread.h".
Conditionally add local prototype for pthread_atfork()
if pthread.h doesn't supply it.
* psxkey01/init.c: Include "test_support.h".
* configure.ac: Check for pthread_atfork in pthread.h.
* psxrwlock01/test.c: Conditionally add local prototype for
pthread_atfork() if pthread.h doesn't supply it.
Include <pthread.h>.
* configure.ac: Check for sys/mman.h.
Check for mprotect in sys/mman.h.
* psxenosys/init.c: Conditionally add local prototype for
mprotect() if sys/mman.h doesn't supply it.
* configure.ac: Check for pthread_rwlock_unlock in pthread.h.
pthread_rwlock_unlock() if pthread.h doesn't supply it.
* psx01/init.c, psxalarm01/init.c, psxbarrier01/test.c,
psxclock/init.c, psxfatal01/testcase.h, psxfatal02/testcase.h,
psxhdrs/signal12.c, psxkey01/init.c, psxkey03/init.c,
psxmsgq01/init.c, psxmsgq02/init.c, psxmsgq03/init.c,
psxreaddir/test.c, psxrwlock01/test.c, psxsignal01/init.c,
psxsignal02/init.c, psxsignal03/init.c, psxspin01/test.c,
psxspin02/test.c, psxstack01/init.c, psxstat/test.c,
psxualarm/init.c: Remove unused vars.
Add missing prototypes.
* Makefile.am: Build file IO related tests even with POSIX threading is
disabled.
* psxtimer01/psxtimer.c: It is not necessarily an error for the time
remaining to not equal the period.
* psx05/init.c, psx05/psx05.scn: Add test for bad mutex type.
* psxcleanup/system.h: Fix typo.
* Makefile.am, configure.ac: Add new test for exercising pushing
and popping a clean up handler without actually executing it.
* psxcleanup01/.cvsignore, psxcleanup01/Makefile.am,
psxcleanup01/init.c, psxcleanup01/psxcleanup01.doc,
psxcleanup01/psxcleanup01.scn: New files.
