psx13/Makefile.am, psxcancel/Makefile.am, psxchroot01/Makefile.am,
psxfile01/Makefile.am, psxhdrs/Makefile.am, psxmount/Makefile.am,
psxmsgq01/Makefile.am, psxreaddir/Makefile.am, psxsem01/Makefile.am,
psxstat/Makefile.am, psxtime/Makefile.am, psxtimer/Makefile.am:
Convert to using *_PROGRAMS.
* psx02/Makefile.am: Rework.
* psx03/Makefile.am: Rework.
* psx04/Makefile.am: Rework.
* psx05/Makefile.am: Rework.
* psx06/Makefile.am: Rework.
* psx07/Makefile.am: Rework.
* psx08/Makefile.am: Rework.
* psx09/Makefile.am: Rework.
* psx10/Makefile.am: Rework.
* psx11/Makefile.am: Rework.
* psx12/Makefile.am: Rework.
* psx13/Makefile.am: Rework.
* psxcancel/Makefile.am: Rework.
* psxchroot01/Makefile.am: Rework.
* psxfile01/Makefile.am: Rework.
* psxmount/Makefile.am: Rework.
* psxmsgq01/Makefile.am: Rework.
* psxreaddir/Makefile.am: Rework.
* psxsem01/Makefile.am: Rework.
* psxstat/Makefile.am: Rework.
* psxtime/Makefile.am: Rework.
* psxtimer/Makefile.am: Rework.
psxfile01/Makefile.am, psxmount/Makefile.am, psxmsgq01/Makefile.am,
psxreaddir/Makefile.am, psxsem01/Makefile.am, psxstat/Makefile.am,
psxtime/Makefile.am, psxtimer/Makefile.am: Expand psxtests.am.
* psxtests.am: Remove.
AM_CPPFLAGS += -I..../support/include.
* psxtests.am: Set project_bspdir=$(PROJECT_ROOT)
* Makefile.am: Remove noinst_HEADERS. Remove POSIX_FILES_DIRS,
POSIX_FILES_DIRS.
* psx13/Makefile.am, psxcancel/Makefile.am, psxchroot01/Makefile.am,
psxfile01/Makefile.am, psxmount/Makefile.am, psxreaddir/Makefile.am,
psxstat/Makefile.am: Add ../include/pmacros.h
POSIX_FILES_DIRS.
* psxtests.am: Remove LIB_VARIANT.
Remove SRC, PRINT_SRC.
* Makefile.am: Cleanup.
* psxtests.am: Add $(PGM): ${ARCH}/$(dirstamp).
Partial conversion to automake.
PR 628/rtems
* psx04/init.c, psx04/psx04.scn: Update tests to reflect a signal of 0
being an error.
* psxreaddir/test.c: Eliminate warnings.
* psx02/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psx03/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psx04/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psx05/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psx06/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psx07/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psx08/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psx09/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psx10/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psx11/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psx12/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psx13/main.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psxcancel/init.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psxchroot01/main.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psxfile01/main.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psxmount/main.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psxmsgq01/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psxreaddir/main.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psxsem01/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psxstat/main.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psxtime/main.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psxtimer/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psxcancel/init.c: Include <rtems/console.h> instead of <console.h>.
* psxmount/test.c: Include <rtems/imfs.h> instead of <imfs.h>.
* psxreaddir/test.c: Include <rtems/imfs.h> instead of <imfs.h>.
* psxstat/test.c: Include <rtems/imfs.h> instead of <imfs.h>.
* psx06/init.c, psx06/system.h, psx06/task.c, psx06/task2.c: Convert
to using c99 fixed size types.
* Makefile.am: Remove include from SUBDIRS.
* configure.ac: Add 2nd arg to RTEMS_TOP.
* psxfile01/test.c, psxmsgq01/init.c, psxstat/test.c,
psxtimer/psxtimer.c: Eliminate warnings and typos.
PR 582/core
* psxmsgq01/init.c, psxmsgq01/psxmsgq01.scn: Fix the POSIX message
queue test so more of it runs now.
* psx01/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES.
* psx02/Makefile.am: Ditto.
* psx03/Makefile.am: Ditto.
* psx04/Makefile.am: Ditto.
* psx05/Makefile.am: Ditto.
* psx06/Makefile.am: Ditto.
* psx07/Makefile.am: Ditto.
* psx08/Makefile.am: Ditto.
* psx09/Makefile.am: Ditto.
* psx10/Makefile.am: Ditto.
* psx11/Makefile.am: Ditto.
* psx12/Makefile.am: Ditto.
* psx13/Makefile.am: Ditto.
* psxcancel/Makefile.am: Ditto.
* psxchroot01/Makefile.am: Ditto.
* psxfile01/Makefile.am: Ditto.
* psxmount/Makefile.am: Ditto.
* psxmsgq01/Makefile.am: Ditto.
* psxreaddir/Makefile.am: Ditto.
* psxsem01/Makefile.am: Ditto.
* psxstat/Makefile.am: Ditto.
* psxtime/Makefile.am: Ditto.
* psxtimer/Makefile.am: Ditto.
* psxtests.am: Add dirstamp support.
* psxtests.am: Use $(mkdir_p) instead of $(mkinstalldirs).
* psxcancel/Makefile.am: Remove used H_FILES.
* include/Makefile.am: Reformat.
* psx01/Makefile.am: Remove all-local: $(ARCH).
* psx02/Makefile.am: Remove all-local: $(ARCH).
* psx03/Makefile.am: Remove all-local: $(ARCH).
* psx04/Makefile.am: Remove all-local: $(ARCH).
* psx05/Makefile.am: Remove all-local: $(ARCH).
* psx06/Makefile.am: Remove all-local: $(ARCH).
* psx07/Makefile.am: Remove all-local: $(ARCH).
* psx08/Makefile.am: Remove all-local: $(ARCH).
* psx09/Makefile.am: Remove all-local: $(ARCH).
* psx10/Makefile.am: Remove all-local: $(ARCH).
* psx11/Makefile.am: Remove all-local: $(ARCH).
* psx12/Makefile.am: Remove all-local: $(ARCH).
* psx13/Makefile.am: Remove all-local: $(ARCH).
* psxcancel/Makefile.am: Remove all-local: $(ARCH).
* psxchroot01/Makefile.am: Remove all-local: $(ARCH).
* psxfile01/Makefile.am: Remove all-local: $(ARCH).
* psxhdrs/Makefile.am: Remove all-local: $(ARCH).
* psxmount/Makefile.am: Remove all-local: $(ARCH).
* psxmsgq01/Makefile.am: Remove all-local: $(ARCH).
* psxreaddir/Makefile.am: Remove all-local: $(ARCH).
* psxsem01/Makefile.am: Remove all-local: $(ARCH).
* psxstat/Makefile.am: Remove all-local: $(ARCH).
* psxtime/Makefile.am: Remove all-local: $(ARCH).
* psxtimer/Makefile.am: Remove all-local: $(ARCH).
* configure.ac: Reflect having moved to testsuites/.
* configure.ac: Remove RTEMS_CANONICAL_HOST.
