_Timespec_Equal_to() does not set errno, hence avoid using perror(),
instead use fprintf() to stderr, and extend the error message to provide
information about what the error is (measured timer value after
re-arming is not equal to the configured interval), and how large of a
difference was measured.
Signed-off-by: Martin Erik Werner <martin.werner@aacmicrotec.com>
Update #3409.
upgrade to that version.
Close #3387.
Update #3382
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Free deferred locations before the greedy memory allocation. This test
fails on powerpc/qoriq_e6500_64 otherwise.
This test uses fprintf().
This test uses sprintf().
Delete superfluous INTERNAL_ERROR_POSIX_INIT_THREAD_ENTRY_IS_NULL.
Update #3243.
Update #3020.
Remove POSIX_API_Control::created_with_explicit_scheduler. Add
Thread_Control::was_created_with_inherited_scheduler. This fixes also
pthread_getattr_np() for Classic tasks.
Update #2514.
Use the thread CPU budget algorithm to determine the scheduler policy.
This fixes also pthread_getschedparam() for Classic tasks.
Update #2514.
Update #3170.
Update #3199.
Close #3205.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
Update #3170.
Update #3199.
Update #3182.
Updates #3170.
Update #3117.
Update #3182.
Update #3182.
call to printk.
Updates #3170.
Move sporadic server scheduler parameters to
POSIX_API_Control::Sporadic. Remove redundant scheduler priority
parameter.
Update #2514.
The thread POSIX API control must be fully initialized in
_POSIX_Threads_Create_extension(), otherwise a pthread_setschedparam()
is broken for all threads not created with pthread_create().
Set default thread processor affinity to all processors of the
pre-allocated set. This allows to constify the
_POSIX_Threads_Default_attributes.
Update #2514.
Simplify
* pthread_attr_setstack(), and
* pthread_attr_setstacksize().
Update #2514.
Update #2514.
Close #3174.
Return stack area via pthread_getattr_np().
Simplify
* pthread_attr_setaffinity_np(), and
* pthread_attr_getaffinity_np()
and let the scheduler do the more sophisticated error checks.
Make
* pthread_setaffinity_np(),
* pthread_getaffinity_np(),
available in all configurations.
Update #2514.
Close #3145.
Close #3168.
Update #3111.
POSIX mutexes are now available in all configurations and no longer
depend on --enable-posix.
Update #2514.
Update #3112.
POSIX condition variables are now available in all configurations and no
longer depend on --enable-posix.
Update #2514.
Update #3113.
POSIX rwlocks are now available in all configurations and no longer
Update #2514.
Update #3115.
POSIX barriers are now available in all configurations and no longer
Update #2514.
Update #3114.
For semaphore object pointer and object validation see
POSIX_SEMAPHORE_VALIDATE_OBJECT().
Destruction or close of a busy semaphore returns an error status. The
object is not flushed.
POSIX semaphores are now available in all configurations and no longer
Update #2514.
Update #3116.
Close #3153.
closes #3148.
Close #3137.
Close #3126.
Close #3125.
This simplifies error handling later.
Update #3132.
Since we have only one process, sharing between processes is trivial.
Close #3124.
Update #2859.
