1999-11-16 | Fixed screen. | Joel Sherrill | 1 | -1/+1 | |
1999-11-16 | Removed leading space from output. | Jennifer Averett | 2 | -4/+4 | |
1999-11-16 | Added comment indicating that dup is known to be broken. | Jennifer Averett | 1 | -1/+1 | |
1999-11-16 | Added test cases for uname(). | Joel Sherrill | 2 | -0/+25 | |
1999-11-16 | Modified file to match seen output. | Jennifer Averett | 1 | -92/+161 | |
1999-11-16 | Modified output file to match seen output. Added comment to all ino | Jennifer Averett | 1 | -306/+282 | |
values that they may change slightly on a processor basis. | |||||
1999-11-16 | Removed compiler warning. | Jennifer Averett | 1 | -1/+1 | |
1999-11-09 | New test for POSIX Message Queues added. | Joel Sherrill | 4 | -1/+88 | |
1999-11-09 | New files. | Joel Sherrill | 3 | -0/+222 | |
1999-11-05 | This is another pass at making sure that nothing outside the BSP | Joel Sherrill | 1 | -3/+1 | |
unnecessarily uses any variables defined by the BSP. On this sweep, use of BSP_Configuration and Cpu_table was eliminated. A significant part of this modification was the addition of macros to access fields in the RTEMS configuration structures. This is necessary to strengthen the division between the BSP independent parts of RTEMS and the BSPs themselves. This started after comments and analysis by Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | |||||
1999-11-04 | The files in libcpu should not be directly dependent on any BSP. In | Joel Sherrill | 1 | -0/+2 | |
particular, using bsp.h, or getting information from the BSP which should properly be obtained from RTEMS is forbidden. This is necessary to strengthen the division between the BSP independent parts of RTEMS and the BSPs themselves. This started after comments and analysis by Ralf Corsepius <corsepiu@faw.uni-ulm.de>. The changes primarily eliminated the need to include bsp.h and peeking at BSP_Configuration. The use of Cpu_table in each BSP needs to be eliminated. | |||||
1999-11-02 | Minor changes to make the screen match a bit better. | Joel Sherrill | 2 | -4/+4 | |
1999-11-02 | Minor fixes to make screen match a bit better. | Joel Sherrill | 2 | -11/+15 | |
1999-11-02 | Added more proper checking of F_GETFL and F_SETFL. | Joel Sherrill | 1 | -5/+17 | |
Disabled test of F_DUPFD since it does not work. Added comment to indicate that seekdir(NULL) was being called. | |||||
1999-10-28 | New test added - psxcancel. This is just a shell for now. | Joel Sherrill | 3 | -1/+32 | |
1999-10-25 | Modified to ease comparison of screen to target output. | Joel Sherrill | 4 | -1092/+1092 | |
1999-10-25 | Modified to reflect test change where reinitialize mutex test case was | Joel Sherrill | 1 | -1/+1 | |
removed. | |||||
1999-10-25 | Removed reinitialize mutex test case to reflect earlier code change in | Joel Sherrill | 1 | -1/+8 | |
the executive. | |||||
1999-10-21 | Increased stack size of initialization thread. | Joel Sherrill | 1 | -0/+2 | |
1999-10-04 | Modifications necessary to support testing of exitting a pthread from | Joel Sherrill | 6 | -41/+156 | |
Charles-Antione Gauthier <charles.gauthier@iit.nrc.ca>. | |||||
1999-10-04 | Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to make fix bug | Joel Sherrill | 1 | -3/+3 | |
where wrapup left pieces out of the librtemsall.a. | |||||
1999-08-10 | New configuration files added by patch from | Joel Sherrill | 1 | -0/+24 | |
Ralf Corsepius <corsepiu@faw.uni-ulm.de>". | |||||
1999-07-01 | Modified to reflect change in calling sequence of mount(). | Joel Sherrill | 1 | -1/+1 | |
1999-07-01 | Test modified to reflect change in calling sequence of mount(). | Joel Sherrill | 1 | -10/+10 | |
1999-04-06 | Corrections by Jennifer. | Joel Sherrill | 1 | -41/+57 | |
1999-03-31 | Added prints for calls into the file system. Added O_EXCL for an open that | Jennifer Averett | 1 | -5/+28 | |
tested that the same file could not be created twice. | |||||
1999-03-31 | Modified file to match output. | Jennifer Averett | 1 | -11/+38 | |
1999-03-29 | Correctd name length to account for new IMFS max name length of 32. | Jennifer Averett | 1 | -1/+3 | |
1999-03-16 | Commented out test case that no long works since addition of POSIX timers. | Joel Sherrill | 1 | -5/+10 | |
1999-02-03 | New files from Juan Zamorano Flores <jzamora@avellano.datsi.fi.upm.es> | Joel Sherrill | 3 | -0/+445 | |
that are part of the addition of POSIX timers. | |||||
1999-01-31 | Removed unneeded include of libio_.h. | Joel Sherrill | 1 | -2/+0 | |
1998-12-03 | Removed spaces. | Joel Sherrill | 3 | -14/+0 | |
1998-12-03 | Changed to account for ownership only being tracked when a priority | Joel Sherrill | 1 | -0/+8 | |
blocking protocol is used. | |||||
1998-12-03 | Removed all ^M from the file. | Jennifer Averett | 1 | -156/+156 | |
1998-12-03 | Removed all ^M from the scn file. | Jennifer Averett | 1 | -1253/+1253 | |
1998-12-03 | Cleaned up test. | Jennifer Averett | 7 | -320/+480 | |
Updated scn files to match present expected test output. | |||||
1998-12-03 | Added Comment that a result is valid at 4 or 5 seconds. | Jennifer Averett | 1 | -13/+1 | |
1998-12-03 | Updated scn files to match present expected test output. | Jennifer Averett | 4 | -11/+267 | |
1998-11-23 | Added new tests in support of the file system infrastructure. | Joel Sherrill | 3 | -0/+155 | |
1998-11-23 | Added tests in support of the file system infrastructure. | Joel Sherrill | 15 | -0/+4577 | |
1998-06-09 | Fixed comment block at the beginning of the file for a copyright date | Joel Sherrill | 135 | -271/+270 | |
problem and an English problem. | |||||
1998-04-27 | Fixed screen to match actual output. | Joel Sherrill | 1 | -3/+2 | |
1998-04-27 | Reset the pthread attributes structure so the proper error would be | Joel Sherrill | 1 | -1/+5 | |
generated. | |||||
1998-02-17 | updated copyright to 1998 | Joel Sherrill | 177 | -177/+177 | |
1997-10-08 | Fixed typo in the pointer to the license terms. | Joel Sherrill | 177 | -354/+354 | |
1997-04-22 | headers updated to reflect new style copyright notice as part | Joel Sherrill | 177 | -885/+885 | |
of switching to the modified GNU GPL. | |||||
1997-04-18 | Modified to reflect change from 255 posix priority levels to 254. | Joel Sherrill | 3 | -6/+6 | |
1997-04-07 | corrected printf specifications and added casts as necessary to eliminate | Joel Sherrill | 3 | -3/+3 | |
warnings. | |||||
1997-04-02 | corrected printf format to avoid warning | Joel Sherrill | 4 | -4/+4 | |
1997-04-02 | initialized variables or removed unused variables to remove warnings | Joel Sherrill | 3 | -4/+3 | |
