* | Updated to reflect a time that had previously been left out due to | Joel Sherrill | 2000-01-05 | 1 | -0/+37 | |
| | | | | an array sizing coding error. | |||||
* | Screen updated since test runs. | Joel Sherrill | 2000-01-05 | 1 | -1/+24 | |
* | Corrected so header message is printed. | Joel Sherrill | 2000-01-05 | 2 | -0/+3 | |
* | + Added tests for open, close, unlink, and send. | Jennifer Averett | 2000-01-05 | 1 | -53/+223 | |
* | Fixed warnings. | Joel Sherrill | 2000-01-04 | 6 | -4/+7 | |
* | + Tests added for mq_open, mq_close, and mq_unlink | Jennifer Averett | 1999-12-23 | 2 | -63/+219 | |
* | Corrected order of output. | Joel Sherrill | 1999-12-13 | 1 | -1/+1 | |
* | Patch rtems-rc-19991123-rc-3.diff from Ralf Corsepius | Joel Sherrill | 1999-12-03 | 1 | -0/+1 | |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | <corsepiu@faw.uni-ulm.de>: The patch below provides * automake support for score/cpu/powerpc * The hack to propagate values from *.cfg to automake configuration * A fix for librdbg/powerpc/mcp750/Makefile.am (Was completely corrupted before) * Fixes some files which apparently where missing in rtems-rc-19991123-rc-2.diff * some minor configuration related patches To apply: rm -rf ./c/src/exec/score/cpu/powerpc/wrap patch -p1 < rtems-rc-19991123-rc-3.diff Attention: c/src/exec/score/cpu/[configure.in|aclocal.m4|configure] should be removed after applying the patch. Modifications had been made to the score/cpu/powerpc directory after the snapshot this was based on. In particular, the mpc750 and other_cpu directories had been renamed to new_exception_processing and old_exception_processing. After this patch was applied, modifications were made to account for this. | |||||
* | Jennifer added initial test code. Conditional'ed out until she has | Joel Sherrill | 1999-12-02 | 1 | -0/+130 | |
| | | | | the opportunity to work with it. | |||||
* | Moved pmacros.h to include not support/include. | Joel Sherrill | 1999-11-23 | 18 | -19/+28 | |
* | Miscellaneous patches from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1999-11-23 | 1 | -1/+1 | |
| | | | | | that are part of the Makefile.am conversion effort but were missed in the previous commits. | |||||
* | Added clock06.c to the compile list. | Joel Sherrill | 1999-11-23 | 1 | -4/+2 | |
* | Files only used by psxfile01, so moved there. | Joel Sherrill | 1999-11-23 | 4 | -1/+201 | |
* | Test psxfile02 unused and removed. | Joel Sherrill | 1999-11-23 | 1 | -1/+1 | |
* | Patch rtems-rc-19991117-14.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1999-11-23 | 25 | -8/+1012 | |
| | | | | to convert the psxtests directory from Makefile.in to Makefile.am. | |||||
* | + Corrected error messages. | Jennifer Averett | 1999-11-22 | 1 | -30/+80 | |
| | | | | | | | | + Added tests for sem_open, sem_close, and sem_unlink. + Yellow lined sem_open, sem_close, sem_unlink, _POSIX_Semaphore_Delete, _POSIX_Semaphore_Name_to_id, and _POSIX_Semaphore_Create_support. Except for MP, pshared OBJECT_REMOTE, and out of memory paths. | |||||
* | Added ifndef around build_time macro so tmacros.h and pmacros.h | Joel Sherrill | 1999-11-22 | 1 | -0/+2 | |
| | | | | can be included from the same file. | |||||
* | Added test code for named semaphores and moved to use of directive_failed | Jennifer Averett | 1999-11-18 | 2 | -31/+87 | |
| | | | | family of macros to produce better checks and diagnostic messages. | |||||
* | Started to added POSIX message queue test code. | Jennifer Averett | 1999-11-18 | 1 | -0/+3 | |
* | Updated copyright notice. | Joel Sherrill | 1999-11-17 | 191 | -382/+191 | |
* | Fixed screen. | Joel Sherrill | 1999-11-16 | 1 | -1/+1 | |
* | Removed leading space from output. | Jennifer Averett | 1999-11-16 | 2 | -4/+4 | |
* | Added comment indicating that dup is known to be broken. | Jennifer Averett | 1999-11-16 | 1 | -1/+1 | |
* | Added test cases for uname(). | Joel Sherrill | 1999-11-16 | 2 | -0/+25 | |
* | Modified file to match seen output. | Jennifer Averett | 1999-11-16 | 1 | -92/+161 | |
* | Modified output file to match seen output. Added comment to all ino | Jennifer Averett | 1999-11-16 | 1 | -306/+282 | |
| | | | | values that they may change slightly on a processor basis. | |||||
* | Removed compiler warning. | Jennifer Averett | 1999-11-16 | 1 | -1/+1 | |
* | New test for POSIX Message Queues added. | Joel Sherrill | 1999-11-09 | 4 | -1/+88 | |
* | New files. | Joel Sherrill | 1999-11-09 | 3 | -0/+222 | |
* | This is another pass at making sure that nothing outside the BSP | Joel Sherrill | 1999-11-05 | 1 | -3/+1 | |
| | | | | | | | | | | | | unnecessarily uses any variables defined by the BSP. On this sweep, use of BSP_Configuration and Cpu_table was eliminated. A significant part of this modification was the addition of macros to access fields in the RTEMS configuration structures. This is necessary to strengthen the division between the BSP independent parts of RTEMS and the BSPs themselves. This started after comments and analysis by Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | |||||
* | The files in libcpu should not be directly dependent on any BSP. In | Joel Sherrill | 1999-11-04 | 1 | -0/+2 | |
| | | | | | | | | | | | particular, using bsp.h, or getting information from the BSP which should properly be obtained from RTEMS is forbidden. This is necessary to strengthen the division between the BSP independent parts of RTEMS and the BSPs themselves. This started after comments and analysis by Ralf Corsepius <corsepiu@faw.uni-ulm.de>. The changes primarily eliminated the need to include bsp.h and peeking at BSP_Configuration. The use of Cpu_table in each BSP needs to be eliminated. | |||||
* | Minor changes to make the screen match a bit better. | Joel Sherrill | 1999-11-02 | 2 | -4/+4 | |
* | Minor fixes to make screen match a bit better. | Joel Sherrill | 1999-11-02 | 2 | -11/+15 | |
* | Added more proper checking of F_GETFL and F_SETFL. | Joel Sherrill | 1999-11-02 | 1 | -5/+17 | |
| | | | | | | Disabled test of F_DUPFD since it does not work. Added comment to indicate that seekdir(NULL) was being called. | |||||
* | New test added - psxcancel. This is just a shell for now. | Joel Sherrill | 1999-10-28 | 3 | -1/+32 | |
* | Modified to ease comparison of screen to target output. | Joel Sherrill | 1999-10-25 | 4 | -1092/+1092 | |
* | Modified to reflect test change where reinitialize mutex test case was | Joel Sherrill | 1999-10-25 | 1 | -1/+1 | |
| | | | | removed. | |||||
* | Removed reinitialize mutex test case to reflect earlier code change in | Joel Sherrill | 1999-10-25 | 1 | -1/+8 | |
| | | | | the executive. | |||||
* | Increased stack size of initialization thread. | Joel Sherrill | 1999-10-21 | 1 | -0/+2 | |
* | Modifications necessary to support testing of exitting a pthread from | Joel Sherrill | 1999-10-04 | 6 | -41/+156 | |
| | | | | Charles-Antione Gauthier <charles.gauthier@iit.nrc.ca>. | |||||
* | Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to make fix bug | Joel Sherrill | 1999-10-04 | 1 | -3/+3 | |
| | | | | where wrapup left pieces out of the librtemsall.a. | |||||
* | New configuration files added by patch from | Joel Sherrill | 1999-08-10 | 1 | -0/+24 | |
| | | | | Ralf Corsepius <corsepiu@faw.uni-ulm.de>". | |||||
* | Modified to reflect change in calling sequence of mount(). | Joel Sherrill | 1999-07-01 | 1 | -1/+1 | |
* | Test modified to reflect change in calling sequence of mount(). | Joel Sherrill | 1999-07-01 | 1 | -10/+10 | |
* | Corrections by Jennifer. | Joel Sherrill | 1999-04-06 | 1 | -41/+57 | |
* | Added prints for calls into the file system. Added O_EXCL for an open that | Jennifer Averett | 1999-03-31 | 1 | -5/+28 | |
| | | | | tested that the same file could not be created twice. | |||||
* | Modified file to match output. | Jennifer Averett | 1999-03-31 | 1 | -11/+38 | |
* | Correctd name length to account for new IMFS max name length of 32. | Jennifer Averett | 1999-03-29 | 1 | -1/+3 | |
* | Commented out test case that no long works since addition of POSIX timers. | Joel Sherrill | 1999-03-16 | 1 | -5/+10 | |
* | New files from Juan Zamorano Flores <jzamora@avellano.datsi.fi.upm.es> | Joel Sherrill | 1999-02-03 | 3 | -0/+445 | |
| | | | | that are part of the addition of POSIX timers. |
