Move sporadic server scheduler parameters to
POSIX_API_Control::Sporadic. Remove redundant scheduler priority
parameter.
Update #2514.
The thread POSIX API control must be fully initialized in
_POSIX_Threads_Create_extension(), otherwise a pthread_setschedparam()
is broken for all threads not created with pthread_create().
Set default thread processor affinity to all processors of the
pre-allocated set. This allows to constify the
_POSIX_Threads_Default_attributes.
Update #2514.
Simplify
* pthread_attr_setstack(), and
* pthread_attr_setstacksize().
Update #2514.
Update #2514.
Close #3174.
Return stack area via pthread_getattr_np().
Simplify
* pthread_attr_setaffinity_np(), and
* pthread_attr_getaffinity_np()
and let the scheduler do the more sophisticated error checks.
Make
* pthread_setaffinity_np(),
* pthread_getaffinity_np(),
available in all configurations.
Update #2514.
Close #3145.
Close #3168.
Update #3111.
POSIX mutexes are now available in all configurations and no longer
depend on --enable-posix.
Update #2514.
Update #3112.
POSIX condition variables are now available in all configurations and no
longer depend on --enable-posix.
Update #2514.
Update #3113.
POSIX rwlocks are now available in all configurations and no longer
Update #2514.
Update #3115.
POSIX barriers are now available in all configurations and no longer
Update #2514.
Update #3114.
For semaphore object pointer and object validation see
POSIX_SEMAPHORE_VALIDATE_OBJECT().
Destruction or close of a busy semaphore returns an error status. The
object is not flushed.
POSIX semaphores are now available in all configurations and no longer
Update #2514.
Update #3116.
Close #3153.
closes #3148.
Close #3137.
Close #3126.
Close #3125.
This simplifies error handling later.
Update #3132.
Since we have only one process, sharing between processes is trivial.
Close #3124.
Update #2859.
These tests directly or indirectly use fprintf(), etc. which may use the
floating point unit.
Update #3076.
Updates #2859
Enable the SMP configuration by default in case SMP is enabled. Add
configuration option CONFIGURE_DISABLE_SMP_CONFIGURATION to disable it
explicitly.
Add CONFIGURE_DISABLE_SMP_CONFIGURATION to all test which would fail
otherwise.
Update #3001.
Update #2859.
disabled
errors.
- Add a top level test configuration file for test states that are common
to all BSPs. This saves adding a test configuration (tcfg) file for
every BSP.
- Add the test states 'user-input' and 'benchmark'. This
lets 'rtems-test' stop the test rather than waiting for a timeout or
letting a benchmark run without the user asking for it to run.
- Implement rtems-test-check in Python to make it faster. The shell script
had grown to a point it was noticably slowing the build down.
- Fix the configure.ac and Makefile.am files for a number of the
test directories. The files are difficiult to keep in sync with the
number of tests and mistakes can happen such as tests being left
out of the build. The test fsrofs01 is an example. Also a there was
a mix of SUBDIRS and _SUBDIRS being used and only _SUBDIRS should be
used.
- Fix the test fsrofs01 so it compiles.
Closes #2963.
Close #2895.
There is currently no proper mmap() implementation.
Update #2859.
Add POSIX shared memory manager (Shm). Includes a hook-based
approach for the backing memory storage that defaults to the
Workspace, and a test is provided using the heap. A test is
also provided for the basic use of mmap'ing a shared memory
object. This test currently fails at the mmap stage due to
no support for mmap.
Add pthread_getname_np() and pthread_setname_np().
Update #2858.
Update #2825.
Update #2825.
The fatal is internal indicator is redundant since the fatal source and
error code uniquely identify a fatal error. Keep the fatal user
extension is internal parameter for backward compatibility and set it to
false always.
Update #2825.
Turn pthread_spinlock_t into a self-contained object. On uni-processor
configurations, interrupts are disabled in the lock/trylock operations
and the previous interrupt status is restored in the corresponding
unlock operations. On SMP configurations, a ticket lock is a acquired
and released in addition.
The self-contained pthread_spinlock_t object is defined by Newlib in
<sys/_pthreadtypes.h>.
typedef struct {
struct _Ticket_lock_Control _lock;
__uint32_t _interrupt_state;
} pthread_spinlock_t;
This implementation is simple and efficient. However, this test case of
the Linux Test Project would fail due to call of printf() and sleep()
during spin lock ownership:
https://github.com/linux-test-project/ltp/blob/master/testcases/open_posix_testsuite/conformance/interfaces/pthread_spin_lock/1-2.c
There is only limited support for profiling on SMP configurations.
Delete CORE spinlock implementation.
Update #2674.
Avoid rtems_semaphore_flush() to reduce the maximum thread dispatch
disabled time of this test. Remove superfluous yield and malloc().
Ensure that no resource leak occurs.
