for details.
The file header was moved over one space. These two were the only
files in the testsuite which did this.
o Make sure EROFS is indicated for write operations on a read-only file
system.
o Add error indication for read-only file systems in fchmod() and
fchown() according to POSIX.
o A new data structure rtems_filesystem_global_location_t was
introduced to be used for
o the mount point location in the mount table entry,
o the file system root location in the mount table entry,
o the root directory location in the user environment, and
o the current directory location in the user environment.
During the path evaluation global start locations are obtained to
ensure that the current file system instance will be not unmounted in
the meantime.
o The user environment uses now reference counting and is protected
from concurrent access.
o The path evaluation process was completely rewritten and simplified.
The IMFS, RFS, NFS, and DOSFS use now a generic path evaluation
method. Recursive calls in the path evaluation have been replaced
with iteration to avoid stack overflows. Only the evaluation of
symbolic links is recursive. No dynamic memory allocations and
intermediate buffers are used in the high level path evaluation. No
global locks are held during the file system instance specific path
evaluation process.
o Recursive symbolic link evaluation is now limited by
RTEMS_FILESYSTEM_SYMLOOP_MAX. Applications can retrieve this value
via sysconf().
o The device file system (devFS) uses now no global variables and
allocation from the workspace. Node names are allocated from the
heap.
o The upper layer lseek() performs now some parameter checks.
o The upper layer ftruncate() performs now some parameter checks.
o unmask() is now restricted to the RWX flags and protected from
concurrent access.
o The fchmod_h and rmnod_h file system node handlers are now a file
system operation.
o The unlink_h operation has been removed. All nodes are now destroyed
with the rmnod_h operation.
o New lock_h, unlock_h, clonenod_h, and are_nodes_equal_h file system
operations.
o The path evaluation and file system operations are now protected by
per file system instance lock and unlock operations.
o Fix and test file descriptor duplicate in fcntl().
o New test fstests/fsnofs01.
Replaced Allocate_majority_of_workspace() with
rtems_workspace_allocate(). Replaced Allocate_majority_of_heap() with
rtems_heap_greedy_allocate().
* psxconfig01/init.c: Create floating point tasks.
* psxmsgq04/init.c: Fixed allocation of second message queue.
* psxconfig01/init.c: Create more objects.
* psx07/init.c: Remove unused var "clock_allowed".
* configure.ac: Check for getrusage decl.
* psxgetrusage01/init.c:
Fix header file inclusion order.
Move configuration section up.
Apply HAVE_DECL_GETRUSAGE.
* psxconfig01/init.c: Fix due to alignment issue.
* psxconfig01/.cvsignore, psxconfig01/Makefile.am, psxconfig01/init.c,
psxconfig01/psxconfig01.doc, psxconfig01/psxconfig01.scn: New files.
* Makefile.am, configure.ac: Reflect changes above.
PR 1589/build
psx13/Makefile.am, psx14/Makefile.am, psx15/Makefile.am,
psx16/Makefile.am, psxaio01/Makefile.am, psxaio02/Makefile.am,
psxaio03/Makefile.am, psxalarm01/Makefile.am,
psxautoinit01/Makefile.am, psxautoinit02/Makefile.am,
psxbarrier01/Makefile.am, psxcancel/Makefile.am,
psxcancel01/Makefile.am, psxchroot01/Makefile.am,
psxclassic01/Makefile.am, psxcleanup/Makefile.am,
psxcleanup01/Makefile.am, psxclock/Makefile.am,
psxcond01/Makefile.am, psxeintr_join/Makefile.am,
psxenosys/Makefile.am, psxfatal01/Makefile.am,
psxfatal02/Makefile.am, psxfchx01/Makefile.am, psxfile01/Makefile.am,
psxfile02/Makefile.am, psxfilelock01/Makefile.am,
psxgetrusage01/Makefile.am, psxid01/Makefile.am,
psximfs01/Makefile.am, psximfs02/Makefile.am,
psxintrcritical01/Makefile.am, psxitimer/Makefile.am,
psxkey01/Makefile.am, psxkey02/Makefile.am, psxkey03/Makefile.am,
psxmount/Makefile.am, psxmsgq01/Makefile.am, psxmsgq02/Makefile.am,
psxmsgq03/Makefile.am, psxmsgq04/Makefile.am,
psxmutexattr01/Makefile.am, psxobj01/Makefile.am,
psxpasswd01/Makefile.am, psxpasswd02/Makefile.am,
psxpipe01/Makefile.am, psxrdwrv/Makefile.am, psxreaddir/Makefile.am,
psxrwlock01/Makefile.am, psxsem01/Makefile.am,
psxsignal01/Makefile.am, psxsignal02/Makefile.am,
psxsignal03/Makefile.am, psxsignal04/Makefile.am,
psxsignal05/Makefile.am, psxsignal06/Makefile.am,
psxspin01/Makefile.am, psxspin02/Makefile.am, psxstack01/Makefile.am,
psxstack02/Makefile.am, psxstat/Makefile.am, psxsysconf/Makefile.am,
psxtime/Makefile.am, psxtimer01/Makefile.am, psxtimer02/Makefile.am,
psxtimes01/Makefile.am, psxualarm/Makefile.am, psxusleep/Makefile.am:
Remove obsolete optional manager capability.
PR 1981/cpukit
* configure.ac: Remove checks for pthread_attr_getcputime,
pthread_attr_setcputime.
* psx07/init.c: Remove references to pthread_attr_getcputime,
* psxmsgq01/init.c: Introduce fatal_posix_mqd.
Replace fatal_posix_service_pointer_minus_one with fatal_posix_mqd.
* psxsem01/init.c: Introduce fatal_posix_sem.
Replace fatal_posix_service_pointer_minus_one with fatal_posix_sem.
* psxreaddir/test.c: Remove bogus casts.
Fix fprintf format strings.
* psxfile01/test.c: Remove local redeclaration of IMFS_dump.
* psxhdrs/pthread01.c, psxhdrs/pthread02.c, psxhdrs/pthread03.c,
psxhdrs/pthread04.c, psxhdrs/pthread05.c, psxhdrs/pthread06.c,
psxhdrs/pthread07.c, psxhdrs/pthread09.c, psxhdrs/pthread10.c,
psxhdrs/pthread11.c, psxhdrs/pthread12.c, psxhdrs/pthread13.c,
psxhdrs/pthread14.c, psxhdrs/pthread15.c, psxhdrs/pthread16.c,
psxhdrs/pthread17.c, psxhdrs/pthread18.c, psxhdrs/pthread19.c,
psxhdrs/pthread20.c, psxhdrs/pthread21.c, psxhdrs/pthread22.c,
psxhdrs/pthread23.c, psxhdrs/pthread24.c, psxhdrs/pthread25.c,
psxhdrs/pthread26.c, psxhdrs/pthread27.c, psxhdrs/pthread28.c,
psxhdrs/pthread29.c, psxhdrs/pthread30.c, psxhdrs/pthread34.c,
psxhdrs/pthread35.c, psxhdrs/pthread36.c, psxhdrs/pthread37.c,
psxhdrs/pthread38.c, psxhdrs/pthread39.c, psxhdrs/pthread40.c:
Let test() return values (avoid warnings).
* psxhdrs/cond01.c, psxhdrs/cond02.c, psxhdrs/cond03.c,
psxhdrs/cond04.c, psxhdrs/cond05.c, psxhdrs/cond06.c,
psxhdrs/cond07.c, psxhdrs/cond08.c, psxhdrs/cond09.c,
psxhdrs/cond10.c: Let test() return values (avoid warnings).
* psxhdrs/mutex01.c, psxhdrs/mutex02.c, psxhdrs/mutex03.c,
psxhdrs/mutex04.c, psxhdrs/mutex05.c, psxhdrs/mutex06.c,
psxhdrs/mutex07.c, psxhdrs/mutex08.c, psxhdrs/mutex09.c,
psxhdrs/mutex10.c, psxhdrs/mutex11.c, psxhdrs/mutex12.c,
psxhdrs/mutex13.c, psxhdrs/mutex14.c, psxhdrs/mutex15.c,
psxhdrs/mutex16.c: Let test() return values (avoid warnings).
* psxhdrs/proc01.c, psxhdrs/proc02.c, psxhdrs/proc03.c,
psxhdrs/proc04.c, psxhdrs/proc05.c, psxhdrs/proc06.c,
psxhdrs/proc07.c, psxhdrs/proc08.c, psxhdrs/proc09.c,
psxhdrs/proc10.c, psxhdrs/proc11.c, psxhdrs/proc12.c,
psxhdrs/proc13.c, psxhdrs/proc14.c:
* psxhdrs/sched01.c, psxhdrs/sched02.c, psxhdrs/sched03.c,
psxhdrs/sched04.c, psxhdrs/sched05.c, psxhdrs/sched06.c,
psxhdrs/sched07.c, psxhdrs/sched08.c:
* psxhdrs/signal01.c, psxhdrs/signal02.c, psxhdrs/signal03.c,
psxhdrs/signal04.c, psxhdrs/signal05.c, psxhdrs/signal06.c,
psxhdrs/signal07.c, psxhdrs/signal08.c, psxhdrs/signal09.c,
psxhdrs/signal10.c, psxhdrs/signal11.c, psxhdrs/signal12.c,
psxhdrs/signal13.c, psxhdrs/signal14.c, psxhdrs/signal15.c,
psxhdrs/signal16.c, psxhdrs/signal17.c, psxhdrs/signal18.c,
psxhdrs/signal19.c, psxhdrs/signal20.c, psxhdrs/signal21.c,
psxhdrs/signal22.c, psxhdrs/signal23.c:
* psxhdrs/key01.c, psxhdrs/key02.c, psxhdrs/key03.c,
psxhdrs/key04.c: Let test() return values (avoid warnings).
* psxhdrs/clock01.c, psxhdrs/clock02.c, psxhdrs/clock03.c,
psxhdrs/clock04.c, psxhdrs/clock05.c, psxhdrs/clock06.c:
* psxhdrs/signal23.c: Add comment to denote test as obsolete.
* configure.ac: Check for size of mode_t.
* psxfile01/test.c, psxstat/test.c: Include "primode.h".
Use PRIomode_t to print mode_t.
* psxaio01/system.h, psxaio02/system.h, psxaio03/system.h: Do not use
the stack checker.
* psxhdrs/sync01.c, psxhdrs/sync02.c: Let test() return values
(avoid warnings).
* psxhdrs/time01.c, psxhdrs/time02.c, psxhdrs/time03.c,
psxhdrs/time04.c, psxhdrs/time05.c, psxhdrs/time06.c,
psxhdrs/time07.c, psxhdrs/time08.c, psxhdrs/time09.c,
psxhdrs/time10.c, psxhdrs/time11.c, psxhdrs/time12.c,
psxhdrs/time13.c: Let test() return values (avoid warnings).
* psxhdrs/timer01.c, psxhdrs/timer02.c, psxhdrs/timer03.c,
psxhdrs/timer04.c, psxhdrs/timer05.c, psxhdrs/timer06.c,
psxhdrs/timer07.c: Let test() return values (avoid warnings).
* psx01/init.c, psx07/init.c, psx09/init.c, psx12/init.c,
psxclock/init.c, psxtimer01/psxtimer.c: Include "pritime.h".
Use PRIdtime_t to print time_t.
* configure.ac: Check for size of time_t.
* psx16/init.c, psxclassic01/init.c, psxeintr_join/init.c:
Add HAVE_CONFIG_H.
* psxfatal01/psxfatal01.scn, psxfatal01/testcase.h,
psxfatal02/psxfatal02.scn, psxfatal02/testcase.h,
psxfatal_support/init.c: Print proper begin and end message.
PR 1890/cpukit
* psxmsgq01/init.c: POSIX says msg_prio is allowed to be NULL.
* psxfatal_support/init.c: Ensure that _Thread_BSP_context is
initialized.
* psx16/Makefile.am: New file.
* psx16/.cvsignore, psx16/init.c, psx16/psx16.doc, psx16/psx16.scn: New
files. Accidentally missed in previous commit.
PR 1855/cpukit
* Makefile.am, configure.ac: Correct signal processing during
pthread_join. We are supposed to unblock the thread waiting on a
pthread_join(), dispatch the signal handler, account for it
potentially overwriting errno, and then have the thread return to
blocking within pthread_join().
* psxeintr_join/.cvsignore, psxeintr_join/Makefile.am,
psxeintr_join/init.c, psxeintr_join/psxeintr_join.doc,
psxeintr_join/psxeintr_join.scn: New files.
PR 1867/cpukit
* Makefile.am, configure.ac, psx12/task.c, psxkey03/init.c,
psxrwlock01/test.c: Correct implementation of pthread_exit() and
pthread_join() to support the case where a thread is joinable but
calls pthread_exit() before a thread has attempted to join.
PR 1839/filesystem
* psxfchx01/init.c, psxfchx01/psxfchx01.scn, psxfile01/psxfile01.scn,
psxfile01/test.c: Update test to reflect new status codes.
* psxhdrs/Makefile.am: Remove -Wno-unused-but-set-variable
(Non-portable).
PR 1838/filesystem
* psxfchx01/init.c, psxfchx01/psxfchx01.scn: fchmod() does not need a
writeable file descriptor.
