* Makefile.am, configure.ac: Add test to exercise interrupt
synchronization logic in _POSIX_Timer_Insert_helper that supports
POSIX timers.
* psxintrcritical01/.cvsignore, psxintrcritical01/Makefile.am,
psxintrcritical01/init.c, psxintrcritical01/psxintrcritical01.doc,
psxintrcritical01/psxintrcritical01.scn: New files.
* psxcancel/Makefile.am, psxcancel/init.c, psxcancel/psxcancel.scn: Add
multiple cases which complete coverage of thread cancellation.
* psxcancel/psxcancel.doc: New file.
* psxsem01/Makefile.am, psxsem01/init.c: Much clean up.
* psxsem01/system.h: Removed.
* psxsem01/init.c: Eliminate warning.
* psxcancel/init.c: Clean up.
* psxmutexattr01/init.c: Make test optional if tools do not support
posix mutex type attribute.
* Makefile.am, configure.ac: Add new test to exercise error case for
when a task is blocked on a condition variable with one mutex and
another task attempts to block on the same condition variable with
another mutex.
* psxcond01/.cvsignore, psxcond01/Makefile.am, psxcond01/init.c,
psxcond01/psxcond01.doc, psxcond01/psxcond01.scn: New files.
* Makefile.am, configure.ac: Add psxspin02 to exercise case where
trylock is unable to obtain the spinlock and that attempting to
unlock a spinlock from a thread which did not lock it works as
expected.
* psxspin02/.cvsignore, psxspin02/Makefile.am, psxspin02/main.c,
psxspin02/psxspin02.doc, psxspin02/psxspin02.scn, psxspin02/test.c:
New files.
* psxspin01/test.c: Remove unnecessary defines.
* psx11/init.c: Use explicit scheduler.
pthread_mutexattr_gettype and pthread_mutexattr_settype now that the
toolset enables the feature.
* psxmutexattr01/.cvsignore, psxmutexattr01/Makefile.am,
psxmutexattr01/init.c, psxmutexattr01/psxmutexattr01.doc,
psxmutexattr01/psxmutexattr01.scn: New files.
* Makefile.am, configure.ac: Add test for auto initialization of
message queues.
* psxautoinit02/.cvsignore, psxautoinit02/Makefile.am,
psxautoinit02/init.c, psxautoinit02/psxautoinit02.doc,
psxautoinit02/psxautoinit02.scn: New files.
* Makefile.am, configure.ac: Add test of pthread mutex auto
intialization.
* psxautoinit01/.cvsignore, psxautoinit01/Makefile.am,
psxautoinit01/init.c, psxautoinit01/psxautoinit01.scn: New files.
* psx05/init.c, psx05/psx05.scn: Add a couple of invalid Id cases.
* psxsignal01/init.c: Tune code to really hit POSIX signal from ISR
code.
* psx07/init.c: Slight test fix to ensure state of sched_param
structure.
* psxrwlock01/psxrwlock01.scn, psxrwlock01/test.c: Add test case for
obtaining an rwlock and then releasing it twice.
* psxenosys/init.c, psxenosys/psxenosys.scn: Add test of vfork stub.
* psx04/init.c, psx04/psx04.scn: Test error cases in sigwait() and
sigtimedwait(). Update screen file.
obtaining rwlock for write with a timed lock operation when the
abstime timeout is in the past.
obtaining rwlock for read with a timed lock operation when the
* psx05/init.c, psx05/psx05.scn: Add test case for process scope now
that the assert has been removed in the source.
* psxstat/psxstat.scn, psxstat/test.c: Disable test for error on wrong
mode bits being set. This behavior was not POSIX compliant and has
been corrected in the filesystem code.
* psx04/task3.c: Declare unions volatile to workaround the H8300
gcc bug.
currently only used by POSIX semaphores and message queues.
* Makefile.am, configure.ac: Add mq_send to full queue from ISR case.
* psxmsgq03/.cvsignore, psxmsgq03/Makefile.am, psxmsgq03/init.c,
psxmsgq03/psxmsgq03.doc, psxmsgq03/psxmsgq03.scn, psxmsgq03/system.h: New files.
NULL attribute pointer on init.
* psxsem01/Makefile.am, psxsem01/init.c, psxsem01/psxsem01.scn,
psxtimer01/psxtimer.c, psxtimer01/system.h, psxtimer02/psxtimer.c:
Improved so coverage is better.
* psx04/init.c: Correct errors introduced by using different variable
for return type when correcting typing warnings.
* Makefile.am, configure.ac: Add new test to provide coverage analysis
of the current implementation of getitimer() and setitimer().
* psxitimer/.cvsignore, psxitimer/Makefile.am, psxitimer/init.c,
psxitimer/psxitimer.scn: New files.
* psxsysconf/init.c, psxsysconf/psxsysconf.scn: Add missing error test
case to improve coverage analysis.
* psx01/init.c, psx01/task.c, psx02/init.c, psx02/task.c, psx03/init.c,
psx04/init.c, psx04/task1.c, psx04/task3.c, psx05/init.c,
psx06/init.c, psx07/init.c, psx08/init.c, psx09/init.c, psx11/task.c,
psx12/init.c, psx13/main.c, psx13/test.c, psxbarrier01/test.c,
psxcancel/init.c, psxcleanup/psxcleanup.c, psxenosys/init.c,
psxmsgq02/init.c, psxtime/main.c, psxtime/test.c,
psxtimer01/psxtimer.c, psxtimer02/psxtimer.c: Fix warnings.
* psxhdrs/clock01.c, psxhdrs/clock02.c, psxhdrs/clock03.c,
psxhdrs/clock04.c, psxhdrs/clock05.c, psxhdrs/clock06.c,
psxhdrs/cond01.c, psxhdrs/cond02.c, psxhdrs/cond03.c,
psxhdrs/cond04.c, psxhdrs/cond05.c, psxhdrs/cond06.c,
psxhdrs/cond07.c, psxhdrs/cond08.c, psxhdrs/cond09.c,
psxhdrs/cond10.c, psxhdrs/key01.c, psxhdrs/key02.c, psxhdrs/key03.c,
psxhdrs/key04.c, psxhdrs/mutex01.c, psxhdrs/mutex02.c,
psxhdrs/mutex03.c, psxhdrs/mutex04.c, psxhdrs/mutex05.c,
psxhdrs/mutex06.c, psxhdrs/mutex07.c, psxhdrs/mutex08.c,
psxhdrs/mutex09.c, psxhdrs/mutex10.c, psxhdrs/mutex11.c,
psxhdrs/mutex12.c, psxhdrs/mutex13.c, psxhdrs/mutex14.c,
psxhdrs/mutex15.c, psxhdrs/mutex16.c, psxhdrs/proc01.c,
psxhdrs/proc02.c, psxhdrs/proc03.c, psxhdrs/proc04.c,
psxhdrs/proc05.c, psxhdrs/proc06.c, psxhdrs/proc07.c,
psxhdrs/proc08.c, psxhdrs/proc09.c, psxhdrs/proc10.c,
psxhdrs/proc11.c, psxhdrs/proc12.c, psxhdrs/proc13.c,
psxhdrs/proc14.c, psxhdrs/pthread01.c, psxhdrs/pthread02.c,
psxhdrs/pthread03.c, psxhdrs/pthread04.c, psxhdrs/pthread05.c,
psxhdrs/pthread06.c, psxhdrs/pthread07.c, psxhdrs/pthread08.c,
psxhdrs/pthread09.c, psxhdrs/pthread10.c, psxhdrs/pthread11.c,
psxhdrs/pthread12.c, psxhdrs/pthread13.c, psxhdrs/pthread14.c,
psxhdrs/pthread15.c, psxhdrs/pthread16.c, psxhdrs/pthread17.c,
psxhdrs/pthread18.c, psxhdrs/pthread19.c, psxhdrs/pthread20.c,
psxhdrs/pthread21.c, psxhdrs/pthread22.c, psxhdrs/pthread23.c,
psxhdrs/pthread24.c, psxhdrs/pthread25.c, psxhdrs/pthread26.c,
psxhdrs/pthread27.c, psxhdrs/pthread28.c, psxhdrs/pthread29.c,
psxhdrs/pthread30.c, psxhdrs/pthread31.c, psxhdrs/pthread32.c,
psxhdrs/pthread33.c, psxhdrs/pthread34.c, psxhdrs/pthread35.c,
psxhdrs/pthread36.c, psxhdrs/sched01.c, psxhdrs/sched02.c,
psxhdrs/sched03.c, psxhdrs/sched04.c, psxhdrs/sched05.c,
psxhdrs/sched06.c, psxhdrs/sched07.c, psxhdrs/sched08.c,
psxhdrs/signal01.c, psxhdrs/signal02.c, psxhdrs/signal03.c,
psxhdrs/signal04.c, psxhdrs/signal05.c, psxhdrs/signal06.c,
psxhdrs/signal07.c, psxhdrs/signal08.c, psxhdrs/signal09.c,
psxhdrs/signal10.c, psxhdrs/signal11.c, psxhdrs/signal12.c,
psxhdrs/signal13.c, psxhdrs/signal14.c, psxhdrs/signal15.c,
psxhdrs/signal16.c, psxhdrs/signal17.c, psxhdrs/signal18.c,
psxhdrs/signal19.c, psxhdrs/signal20.c, psxhdrs/signal21.c,
psxhdrs/signal22.c, psxhdrs/signal23.c, psxhdrs/sync01.c,
psxhdrs/sync02.c, psxhdrs/sync03.c, psxhdrs/time01.c,
psxhdrs/time02.c, psxhdrs/time03.c, psxhdrs/time04.c,
psxhdrs/time05.c, psxhdrs/time06.c, psxhdrs/time07.c,
psxhdrs/time08.c, psxhdrs/time09.c, psxhdrs/time10.c,
psxhdrs/time11.c, psxhdrs/time12.c, psxhdrs/time13.c,
psxhdrs/timer01.c, psxhdrs/timer02.c, psxhdrs/timer03.c,
psxhdrs/timer04.c, psxhdrs/timer05.c, psxhdrs/timer06.c,
psxhdrs/timer07.c: Fix warnings.
* psxfile01/test.c: Change from int to size_t.
psx13/Makefile.am, psx14/Makefile.am, psxbarrier01/Makefile.am,
psxcancel/Makefile.am, psxchroot01/Makefile.am,
psxcleanup/Makefile.am, psxenosys/Makefile.am,
psxfatal01/Makefile.am, psxfatal02/Makefile.am,
psxfile01/Makefile.am, psxkey01/Makefile.am,
psxmount/Makefile.am, psxmsgq01/Makefile.am,
psxmsgq02/Makefile.am, psxrdwrv/Makefile.am,
psxreaddir/Makefile.am, psxrwlock01/Makefile.am,
psxsem01/Makefile.am, psxsignal01/Makefile.am,
psxspin01/Makefile.am, psxstat/Makefile.am, psxsysconf/Makefile.am,
psxtime/Makefile.am, psxtimer01/Makefile.am, psxtimer02/Makefile.am,
psxualarm/Makefile.am: Eliminate _exe_/.exe.
* psxmsgq02/init.c, psxmsgq02/psxmsgq02.scn: Open the message queue
with create option so we are sure it will get a control block and
proceed to allocate other memory. Clean up screen output.
* psx05/init.c: Add parameter to call to sched_get_priority_max().
* psx05/init.c, psx07/init.c, psx09/init.c, psx11/init.c, psx12/init.c:
Run all tests successfully with maxixum number of priorities as 16
instead of 256. This was done by temporarily modifying the score
priority.h maximum. This allowed testing of all API code to ensure
that it worked properly with a reduced number of priorities. Most
modifications were to switch from hard-coded maximum to using the API
provided methods to determine maximum number of priority levels.
* psxtimer01/psxtimer.c, psxtimer02/psxtimer.c: Obtain TOD with
clock_gettime() NOT by reaching into the SuperCore.
* psx01/psx01.scn: Bump version to 4.9.99.0
* psxcleanup/psxcleanup.c, psxfatal_support/init.c,
psxfatal_support/system.h: Convert to "bool".
PR 1296/cpukit.
* psxtimer01/psxtimer.c, psxtimer01/psxtimer01.scn: POSIX timers use
incorrect repeat interval. This patch fixes the following problems in
the test.
(1) Adds test for value of it_interval.tv_nsec.
(2) Corrects test for absolute timer in past.
(3) Modifies test to use different initial and repeat periods.
(4) Updates psxtimer01.scn to match results.
PR 1297/cpukit
* psxrwlock01/psxrwlock01.scn, psxrwlock01/test.c: Fix NULL attribute
pointer handling.
* psxsem01/init.c: Spacing.
PR 1293/tests
* psx10/init.c: Make sure we do not let tv_nsec go to -1.
PR 1291/cpukit
* psx05/init.c, psxmsgq01/init.c: As part of addressing timeouts and
POSIX services taking relative instead of absolute time for timeouts,
these tests were updated.
* psxfile01/test.c: truncate on /dev/console now works.
* psxrwlock01/main.c, psxspin01/main.c: Now accounts for extra stack
requested for initialization task.
