* psxrwlock01/main.c, psxrwlock01/test.c: Improve rwlock test to
include normal blocking and unblocking on timeout.
* psxsem01/init.c: Account for change in POSIX semaphore time handling.
Previously the timeout was not absolute time and checked BEFORE
attempting to lock semaphore.
* psxbarrier01/main.c: New file.
* psxrwlock01/.cvsignore, psxrwlock01/Makefile.am, psxrwlock01/main.c,
psxrwlock01/psxrwlock01.scn, psxrwlock01/test.c,
psxspin01/.cvsignore, psxspin01/Makefile.am, psxspin01/main.c,
psxspin01/psxspin01.scn, psxspin01/test.c: New files.
* Makefile.am, configure.ac: Adding POSIX barriers, POSIX spinlocks,
and partial implementation of POSIX rwlocks.
* psxbarrier01/.cvsignore, psxbarrier01/Makefile.am,
psxbarrier01/psxbarrier01.scn, psxbarrier01/test.c: New files.
PR 841/rtems
* psxsem01/init.c: Make sem_timedwait more conformant to Open Group
specification.
psx13/Makefile.am, psxcancel/Makefile.am, psxchroot01/Makefile.am,
psxfile01/Makefile.am, psxmount/Makefile.am, psxmsgq01/Makefile.am,
psxreaddir/Makefile.am, psxsem01/Makefile.am, psxstat/Makefile.am,
psxtime/Makefile.am, psxtimer/Makefile.am: Eliminate scndir, docdir.
Use rtems_testsdir instead.
* configure.ac: Remove RTEMS_ENABLE_BARE,
BARE_CPU_CFLAGS, BARE_CPU_MODEL.
psxfile01/Makefile.am, psxhdrs/Makefile.am, psxmount/Makefile.am,
psxmsgq01/Makefile.am, psxreaddir/Makefile.am, psxsem01/Makefile.am,
psxstat/Makefile.am, psxtime/Makefile.am, psxtimer/Makefile.am:
Convert to using *_PROGRAMS.
* psx02/Makefile.am: Rework.
* psx03/Makefile.am: Rework.
* psx04/Makefile.am: Rework.
* psx05/Makefile.am: Rework.
* psx06/Makefile.am: Rework.
* psx07/Makefile.am: Rework.
* psx08/Makefile.am: Rework.
* psx09/Makefile.am: Rework.
* psx10/Makefile.am: Rework.
* psx11/Makefile.am: Rework.
* psx12/Makefile.am: Rework.
* psx13/Makefile.am: Rework.
* psxcancel/Makefile.am: Rework.
* psxchroot01/Makefile.am: Rework.
* psxfile01/Makefile.am: Rework.
* psxmount/Makefile.am: Rework.
* psxmsgq01/Makefile.am: Rework.
* psxreaddir/Makefile.am: Rework.
* psxsem01/Makefile.am: Rework.
* psxstat/Makefile.am: Rework.
* psxtime/Makefile.am: Rework.
* psxtimer/Makefile.am: Rework.
psxtime/Makefile.am, psxtimer/Makefile.am: Expand psxtests.am.
* psxtests.am: Remove.
AM_CPPFLAGS += -I..../support/include.
* psxtests.am: Set project_bspdir=$(PROJECT_ROOT)
* Makefile.am: Remove noinst_HEADERS. Remove POSIX_FILES_DIRS,
POSIX_FILES_DIRS.
* psx13/Makefile.am, psxcancel/Makefile.am, psxchroot01/Makefile.am,
psxfile01/Makefile.am, psxmount/Makefile.am, psxreaddir/Makefile.am,
psxstat/Makefile.am: Add ../include/pmacros.h
POSIX_FILES_DIRS.
* psxtests.am: Remove LIB_VARIANT.
Remove SRC, PRINT_SRC.
* Makefile.am: Cleanup.
* psxtests.am: Add $(PGM): ${ARCH}/$(dirstamp).
Partial conversion to automake.
PR 628/rtems
* psx04/init.c, psx04/psx04.scn: Update tests to reflect a signal of 0
being an error.
* psxreaddir/test.c: Eliminate warnings.
