* psx01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx02/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx03/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx04/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx05/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx06/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx07/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx08/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx09/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx10/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx11/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx12/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx13/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psxcancel/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psxchroot01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psxfile01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psxhdrs/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psxmount/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psxmsgq01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psxreaddir/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psxsem01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psxstat/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psxtime/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psxtimer/Makefile.am: Remove AUTOMAKE_OPTIONS.
Reported by Ibragimov Ilya <ibr@oktet.ru> and tracked as PR63.
* psxstat/test.c: Fix test ENOTDIR to correspond to chdir() change.
Since we check permissions before evaluating enough to see if it
a regular file or directory, this hack is needed to make the regular
file executable.
* configure.in: Remove.
* psxtests.am: Use TMPINSTALL_FILES = to make automake-1.5 happy.
* psx01/Makefile.am: include leaf.am instead of leaf.cfg.
* psx11/Makefile.am: include leaf.am instead of leaf.cfg.
* psxcancel/Makefile.am: include leaf.am instead of leaf.cfg.
* psx02/Makefile.am: include leaf.am instead of leaf.cfg.
* psx13/Makefile.am: include leaf.am instead of leaf.cfg.
* psxtime/Makefile.am: include leaf.am instead of leaf.cfg.
* psxchroot01/Makefile.am: include leaf.am instead of leaf.cfg.
* psx07/Makefile.am: include leaf.am instead of leaf.cfg.
* psxmsgq01/Makefile.am: include leaf.am instead of leaf.cfg.
* psxtimer/Makefile.am: include leaf.am instead of leaf.cfg.
* psx10/Makefile.am: include leaf.am instead of leaf.cfg.
* psx08/Makefile.am: include leaf.am instead of leaf.cfg.
* psxhdrs/Makefile.am: include leaf.am instead of leaf.cfg.
* psxfile01/Makefile.am: include leaf.am instead of leaf.cfg.
* psx05/Makefile.am: include leaf.am instead of leaf.cfg.
* psx09/Makefile.am: include leaf.am instead of leaf.cfg.
* psxmount/Makefile.am: include leaf.am instead of leaf.cfg.
* psxstat/Makefile.am: include leaf.am instead of leaf.cfg.
* psx12/Makefile.am: include leaf.am instead of leaf.cfg.
* psxreaddir/Makefile.am: include leaf.am instead of leaf.cfg.
* psxsem01/Makefile.am: include leaf.am instead of leaf.cfg.
* psx03/Makefile.am: include leaf.am instead of leaf.cfg.
* psx04/Makefile.am: include leaf.am instead of leaf.cfg.
* psx06/Makefile.am: include leaf.am instead of leaf.cfg.
* psxchroot01/.cvsignore, psxchroot01/Makefile.am, psxchroot01/main.c,
psxchroot01/psxchroot01.scn, psxchroot01/test.c: Implemented the
psxchroot01 test.
* Added once version of psxchroot01 test for user review.
* psxchroot01: New directory.
* psxchroot01/Makefile.am, psxchroot01/main.c, psxchroot01/test.c,
psxchroot01/psxchroot01.scn, psxchroot01/.cvsignore: New files.
* configure.in, Makefile.am: Modified to reflect above.
* psxfile01/test.c, psxfile01/psxfile01.scn : Added test case for
open, write, reopen, append twice from Andrew Bythell
<abythell@nortelnetworks.com> that tripped an initialization
problem in the IMFS.
* psx04/init.c, psx04/psx04.scn, psx07/init.c, psx07/psx07.scn,
psxfile01/psxfile01.scn, psxmsgq01/psxmsgq01.scn,
psxreaddir/test.c, psxstat/psxstat.scn, psxstat/test.c,
psxtime/psxtime.scn, psxtimer/psxtimer.scn:
Various adjustments so test output matches screens more reliably.
* psx01/psx01.scn: Corrected to reflect clock_getres() now working.
* psxstat/test.c, psxstat/psxstat.scn: Forced inode numbers
to remain consistant across platforms and bsps by forcing
a mount point in front of all paths.
2000-11-17 Jennifer Averret <jennifer@OARcorp.com>
* psxmount/test.c, psxmount/psxmount.scn: Improve output to report
expected error condition in one case.
* psxreaddir/test.c, psxreaddir.scn: Added test cases to exercise
readdir() of root of mounted filesystem. Also corrected the screen
file for some mistakes noticed in this effort.
* psxmount/psxmount.scn, psxmount/test.c: Correct spelling.
* psxtests.am: Remove DEFS.
* psxmount/test.c, psxstat/test.c: Include <imfs.h> to get IMFS_ops.
It was formerly incorrectly prototyped in <libio.h>.
psx13/Makefile.am, psxcancel/Makefile.am, psxfile01/Makefile.am,
psxhdrs/Makefile.am, psxmount/Makefile.am, psxmsgq01/Makefile.am,
psxreaddir/Makefile.am, psxsem01/Makefile.am, psxstat/Makefile.am,
psxtime/Makefile.am, psxtimer/Makefile.am: Include compile.am
psx10/Makefile.am, psx11/Makefile.am, psx11/Makefile.am,
psx12/Makefile.am, psxcancel/Makefile.am, psxmsgq01/Makefile.am,
psxsem01/Makefile.am, psxsem01/Makefile.am, psxtimer/Makefile.am:
Use AM_CPPFLAGS += instead of AM_CPPFLAGS =
cpuopts.h.
exec/configure.in, only.
quoting bugs in autoconf).
formating changes :)
were done by Joel.
were done by Joel.
must deal with a pending process oriented signal. Prior to the addition
of this testcase, sigtimedwait() did not return properly when a process
oriented signal was pending. The problem was reported by Wayne
Bullaughey <wayneb@cacdsp.com>.
an array sizing coding error.
<corsepiu@faw.uni-ulm.de>:
The patch below provides
before)
rtems-rc-19991123-rc-2.diff
Attention:
the opportunity to work with it.
in the previous commits.
to convert the psxtests directory from Makefile.in to Makefile.am.
