2016-06-16 | Add pthread_condattr_getclock() and pthread_condattr_setclock() | Joel Sherrill | 6 | -1/+170 | |
updates #2608. | |||||
2016-06-15 | psxtests/psx12: Use and print proper rounded ms | Sebastian Huber | 2 | -21/+26 | |
Update #2738. | |||||
2016-06-15 | posix: Fix poradic server initial CPU budget | Sebastian Huber | 2 | -14/+107 | |
2016-06-15 | psxtests/psx12: Use one file and simplify | Sebastian Huber | 5 | -134/+33 | |
2016-06-13 | posix: Add pthread_setschedprio() | Sebastian Huber | 1 | -0/+30 | |
Close #2734. | |||||
2016-06-13 | posix: Fix pthread_setschedparam() | Sebastian Huber | 1 | -0/+54 | |
Close #2735. | |||||
2016-06-13 | posix: Fix pthread_getschedparam() | Sebastian Huber | 1 | -0/+46 | |
Return the unmodified thread priority value according to POSIX. Close #2736. | |||||
2016-05-26 | posix: Fix sem_init() with too large initial value | Sebastian Huber | 1 | -0/+12 | |
Close #2721. | |||||
2016-05-26 | Fix semaphore post overflow status | Sebastian Huber | 1 | -0/+34 | |
Close #2720. | |||||
2016-05-25 | posix: Fix pthread_spin_unlock() error status | Sebastian Huber | 2 | -5/+11 | |
Close #2719. | |||||
2016-05-25 | cpukit, testsuite: Add rtems_printf and rtems_printer support. | Chris Johns | 1 | -3/+5 | |
This change adds rtems_printf and related functions and wraps the RTEMS print plugin support into a user API. All references to the plugin are removed and replaced with the rtems_printer interface. Printk and related functions are made to return a valid number of characters formatted and output. The function attribute to check printf functions has been added to rtems_printf and printk. No changes to remove warrnings are part of this patch set. The testsuite has been moved over to the rtems_printer. The testsuite has a mix of rtems_printer access and direct print control via the tmacros.h header file. The support for begink/endk has been removed as it served no purpose and only confused the code base. The testsuite has not been refactored to use rtems_printf. This is future work. | |||||
2016-05-24 | psxtests/psxmsgq01: Fix typo | Sebastian Huber | 1 | -1/+1 | |
2016-05-24 | score: Fix blocking _CORE_message_queue_Submit() | Sebastian Huber | 2 | -0/+78 | |
Close #2718. | |||||
2016-05-24 | psxtests/psxmsgq01: Enable test case | Sebastian Huber | 2 | -5/+4 | |
2016-05-20 | psxclassic01: Assume correct pthread_detach() | Sebastian Huber | 2 | -10/+31 | |
Update #2714. | |||||
2016-05-18 | psxtests/psxualarm: Avoid output in signal handler | Sebastian Huber | 2 | -14/+7 | |
Avoid output in signal handler to not disturb the timings which are checked in this test. Use asserts to ensure proper signal handler invocations. | |||||
2016-05-17 | posix: Fix return states of pthread_kill() | Sebastian Huber | 1 | -6/+2 | |
POSIX mandates that an error code is returned and not -1 plus errno. Close #2715. | |||||
2016-05-17 | psxtests/psxcancel: Add pthread_detach() tests | Sebastian Huber | 2 | -0/+87 | |
2016-05-17 | psxtests/psxcancel: Add resource check | Sebastian Huber | 1 | -8/+26 | |
2016-05-17 | posix: Fix return status of pthread_cancel() | Sebastian Huber | 1 | -2/+2 | |
POSIX recommends ESRCH in case no thread exists for the specified identifier. Close #2713. | |||||
2016-05-04 | rtems: Remove task variables | Sebastian Huber | 1 | -29/+0 | |
Update #2494. Update #2555. | |||||
2016-05-04 | confdefs.h: Fix named object size estimate | Sebastian Huber | 1 | -5/+5 | |
Account for the terminating null character. Use _POSIX_PATH_MAX instead of NAME_MAX according to _POSIX_Semaphore_Manager_initialization() and _POSIX_Message_queue_Manager_initialization(). | |||||
2016-05-02 | posix: Simplify message queues | Sebastian Huber | 2 | -6/+0 | |
The mq_open() function returns a descriptor to a POSIX message queue object identified by a name. This is similar to sem_open(). In contrast to the POSIX semaphore the POSIX message queues use a separate object for the descriptor. This extra object is superfluous, since the object identifier can be used directly for this purpose, just like for the semaphores. Update #2702. Update #2555. | |||||
2016-04-21 | score: Simplify _Objects_Initialize_information() | Sebastian Huber | 1 | -6/+2 | |
Remove unused supports_global parameter. Convert _Objects_Initialize_information() to a macro to avoid use of RTEMS_MULTIPROCESSING define for each caller. | |||||
2016-04-21 | posix: Avoid Giant lock for mutexes | Sebastian Huber | 3 | -1/+48 | |
Delete _POSIX_Mutex_Get(). Use _POSIX_Mutex_Get_interrupt_disable() instead. Update #2555. | |||||
2016-04-21 | score: Fix _CORE_semaphore_Flush() | Sebastian Huber | 1 | -1/+51 | |
Use proper CORE_semaphore_Status for _CORE_semaphore_Flush() and _CORE_semaphore_Destroy() operations. Close #2696. | |||||
2016-04-14 | Add pthread_getconcurrency() and pthread_setconcurrency() | Joel Sherrill | 9 | -1/+186 | |
This is the very simple implementation specified by the Open Group for implementations with 1:1 kernel thread to user thread mappings. http://pubs.opengroup.org/onlinepubs/9699919799/functions/pthread_getconcurrency.html updates #2680. | |||||
2016-04-14 | posix: Run key destructors during thread restart | Sebastian Huber | 2 | -13/+100 | |
POSIX key destructors must be called during thread restart. Just like the POSIX cleanup handlers. This ensures that the TLS object destructors are called during thread restart for example. It is important for the global construction, which uses a thread restart to run the Init task in a clean environment. Close #2689. | |||||
2016-03-22 | psxtests/psxobj01: Fix for RTEMS_DEBUG | Sebastian Huber | 1 | -0/+7 | |
2016-03-18 | score: Add _Objects_Get_by_name() | Sebastian Huber | 6 | -67/+62 | |
Replace _Objects_Name_to_id_string() with _Objects_Get_by_name() since all users of this function are interested in the object itself and not the identifier. Use the object allocator lock to protect the search. Update #2555. | |||||
2016-03-04 | score: Replace watchdog handler implementation | Sebastian Huber | 1 | -1/+6 | |
Use a red-black tree instead of delta chains. Close #2344. Update #2554. Update #2555. Close #2606. | |||||
2016-02-22 | psxtests/psxualarm: Add test cases | Sebastian Huber | 1 | -38/+35 | |
Update #2344. | |||||
2016-02-22 | psxtests/psxalarm01: Add adjtime() test case | Sebastian Huber | 1 | -29/+19 | |
Update #2606. | |||||
2016-01-26 | psxtests: Disable POSIX only psxcleanup02 | Sebastian Huber | 1 | -1/+1 | |
2016-01-19 | psxtests: Fix link-time errors | Sebastian Huber | 6 | -93/+2 | |
Fix link-time errors introduced by e39cdb875ce7458787b0be173f2f7893a774a673. Update #2531. | |||||
2016-01-08 | score: Add fatal errors for NULL entry init tasks | Sebastian Huber | 1 | -2/+3 | |
This simplifies the global construction. Update #2514. | |||||
2016-01-05 | Filesystem: Remove superfluous permission checks | Sebastian Huber | 1 | -5/+0 | |
The permission is check by the upper layer. | |||||
2016-01-04 | Remove H8300 port | Joel Sherrill | 1 | -1/+1 | |
updates #2452. | |||||
2015-12-15 | psxtests/psxcleanup02: New test | Sebastian Huber | 7 | -0/+159 | |
2015-10-27 | CONFIGURE_IMFS_MEMFILE_BYTES_PER_BLOCK was undocumented and not error checked | Joel Sherrill | 1 | -2/+2 | |
closes #2431. | |||||
2015-10-26 | basdefs.h: Add and use RTEMS_UNUSED | Sebastian Huber | 1 | -3/+3 | |
2015-09-02 | posix: glibc compatibility | Sebastian Huber | 2 | -7/+7 | |
2015-09-01 | psxtests/psxcancel: Check return status | Sebastian Huber | 1 | -10/+24 | |
Update #2402. | |||||
2015-05-19 | psxualarm: Avoid endless signal handling | Sebastian Huber | 1 | -2/+2 | |
Increase the ualarm timer interval to avoid endless signal handling. | |||||
2015-04-14 | Add test assertion for allocator mutex being unlocked | Joel Sherrill | 2 | -19/+0 | |
The Allocator Mutex should not be locked outside a tested service call. In an SMP test or heavily multithreaded test, this is possible since another thread could have the lock for an extended period of time but this is not the norm for the tests. updates 2319. | |||||
2015-03-24 | psxconfig01/init.c: Correct pointer/integer size warning | Joel Sherrill | 1 | -1/+1 | |
2015-03-24 | psxtests/psx15/init.c: Correct printf() warning | Joel Sherrill | 1 | -1/+3 | |
2015-03-22 | testsuites/psxtests/psxsignal03/init.c: Fix line wrap | Joel Sherrill | 1 | -1/+5 | |
2015-03-20 | Replace www.rtems.com with www.rtems.org | Sebastian Huber | 1 | -1/+1 | |
2015-03-17 | tests misc: Disable deprecated method usage warning when intentional | Joel Sherrill | 1 | -4/+10 | |
These tests intentionally use the deprecated method. Eventually this code in the sections can be deleted. |
