Add rtems_resource_rtems_api, rtems_resource_posix_api,
rtems_resource_snapshot, rtems_resource_snapshot_equal(), and
rtems_resource_snapshot_check().
This file contains the parts of <rtems/posix/psignal.h> that are only
necessary for the POSIX API implementation.
POSIX does not specify an error number in case the file system does not
support this call. Use the Linux value.
The work areas (RTEMS work space and C program heap) will be initialized
now in a separate step and are no longer part of
rtems_initialize_data_structures(). Initialization is performed with
tables of Heap_Area entries. This allows usage of scattered memory
areas present on various small scale micro-controllers.
The sbrk() support API changes also. The bsp_sbrk_init() must now deal
with a minimum size for the first memory chunk to take the configured
work space size into account.
This reverts commit cf42a6ea9dbb6ebee498ae8db319d3e475bcd6be.
According to POSIX the lseek() function shall not, by itself, extend the
size of a file.
Remove the size field of rtems_libio_t. A file has only one size but
may have multiple open file descriptors. Thus a file size field in the
file descriptor may lead to inconsistencies.
New default handlers rtems_filesystem_default_lseek_file() and
rtems_filesystem_default_lseek_directory().
for details.
The file header was moved over one space. These two were the only
files in the testsuite which did this.
o Make sure EROFS is indicated for write operations on a read-only file
system.
o Add error indication for read-only file systems in fchmod() and
fchown() according to POSIX.
o A new data structure rtems_filesystem_global_location_t was
introduced to be used for
o the mount point location in the mount table entry,
o the file system root location in the mount table entry,
o the root directory location in the user environment, and
o the current directory location in the user environment.
During the path evaluation global start locations are obtained to
ensure that the current file system instance will be not unmounted in
the meantime.
o The user environment uses now reference counting and is protected
from concurrent access.
o The path evaluation process was completely rewritten and simplified.
The IMFS, RFS, NFS, and DOSFS use now a generic path evaluation
method. Recursive calls in the path evaluation have been replaced
with iteration to avoid stack overflows. Only the evaluation of
symbolic links is recursive. No dynamic memory allocations and
intermediate buffers are used in the high level path evaluation. No
global locks are held during the file system instance specific path
evaluation process.
o Recursive symbolic link evaluation is now limited by
RTEMS_FILESYSTEM_SYMLOOP_MAX. Applications can retrieve this value
via sysconf().
o The device file system (devFS) uses now no global variables and
allocation from the workspace. Node names are allocated from the
heap.
o The upper layer lseek() performs now some parameter checks.
o The upper layer ftruncate() performs now some parameter checks.
o unmask() is now restricted to the RWX flags and protected from
concurrent access.
o The fchmod_h and rmnod_h file system node handlers are now a file
system operation.
o The unlink_h operation has been removed. All nodes are now destroyed
with the rmnod_h operation.
o New lock_h, unlock_h, clonenod_h, and are_nodes_equal_h file system
operations.
o The path evaluation and file system operations are now protected by
per file system instance lock and unlock operations.
o Fix and test file descriptor duplicate in fcntl().
o New test fstests/fsnofs01.
Replaced Allocate_majority_of_workspace() with
rtems_workspace_allocate(). Replaced Allocate_majority_of_heap() with
rtems_heap_greedy_allocate().
* psxconfig01/init.c: Create floating point tasks.
* psxmsgq04/init.c: Fixed allocation of second message queue.
* psxconfig01/init.c: Create more objects.
* psx07/init.c: Remove unused var "clock_allowed".
* configure.ac: Check for getrusage decl.
* psxgetrusage01/init.c:
Fix header file inclusion order.
Move configuration section up.
Apply HAVE_DECL_GETRUSAGE.
* psxconfig01/init.c: Fix due to alignment issue.
* psxconfig01/.cvsignore, psxconfig01/Makefile.am, psxconfig01/init.c,
psxconfig01/psxconfig01.doc, psxconfig01/psxconfig01.scn: New files.
* Makefile.am, configure.ac: Reflect changes above.
PR 1589/build
psx13/Makefile.am, psx14/Makefile.am, psx15/Makefile.am,
psx16/Makefile.am, psxaio01/Makefile.am, psxaio02/Makefile.am,
psxaio03/Makefile.am, psxalarm01/Makefile.am,
psxautoinit01/Makefile.am, psxautoinit02/Makefile.am,
psxbarrier01/Makefile.am, psxcancel/Makefile.am,
psxcancel01/Makefile.am, psxchroot01/Makefile.am,
psxclassic01/Makefile.am, psxcleanup/Makefile.am,
psxcleanup01/Makefile.am, psxclock/Makefile.am,
psxcond01/Makefile.am, psxeintr_join/Makefile.am,
psxenosys/Makefile.am, psxfatal01/Makefile.am,
psxfatal02/Makefile.am, psxfchx01/Makefile.am, psxfile01/Makefile.am,
psxfile02/Makefile.am, psxfilelock01/Makefile.am,
psxgetrusage01/Makefile.am, psxid01/Makefile.am,
psximfs01/Makefile.am, psximfs02/Makefile.am,
psxintrcritical01/Makefile.am, psxitimer/Makefile.am,
psxkey01/Makefile.am, psxkey02/Makefile.am, psxkey03/Makefile.am,
psxmount/Makefile.am, psxmsgq01/Makefile.am, psxmsgq02/Makefile.am,
psxmsgq03/Makefile.am, psxmsgq04/Makefile.am,
psxmutexattr01/Makefile.am, psxobj01/Makefile.am,
psxpasswd01/Makefile.am, psxpasswd02/Makefile.am,
psxpipe01/Makefile.am, psxrdwrv/Makefile.am, psxreaddir/Makefile.am,
psxrwlock01/Makefile.am, psxsem01/Makefile.am,
psxsignal01/Makefile.am, psxsignal02/Makefile.am,
psxsignal03/Makefile.am, psxsignal04/Makefile.am,
psxsignal05/Makefile.am, psxsignal06/Makefile.am,
psxspin01/Makefile.am, psxspin02/Makefile.am, psxstack01/Makefile.am,
psxstack02/Makefile.am, psxstat/Makefile.am, psxsysconf/Makefile.am,
psxtime/Makefile.am, psxtimer01/Makefile.am, psxtimer02/Makefile.am,
psxtimes01/Makefile.am, psxualarm/Makefile.am, psxusleep/Makefile.am:
Remove obsolete optional manager capability.
PR 1981/cpukit
* configure.ac: Remove checks for pthread_attr_getcputime,
pthread_attr_setcputime.
* psx07/init.c: Remove references to pthread_attr_getcputime,
* psxmsgq01/init.c: Introduce fatal_posix_mqd.
Replace fatal_posix_service_pointer_minus_one with fatal_posix_mqd.
* psxsem01/init.c: Introduce fatal_posix_sem.
Replace fatal_posix_service_pointer_minus_one with fatal_posix_sem.
* psxreaddir/test.c: Remove bogus casts.
Fix fprintf format strings.
* psxfile01/test.c: Remove local redeclaration of IMFS_dump.
* psxhdrs/pthread01.c, psxhdrs/pthread02.c, psxhdrs/pthread03.c,
psxhdrs/pthread04.c, psxhdrs/pthread05.c, psxhdrs/pthread06.c,
psxhdrs/pthread07.c, psxhdrs/pthread09.c, psxhdrs/pthread10.c,
psxhdrs/pthread11.c, psxhdrs/pthread12.c, psxhdrs/pthread13.c,
psxhdrs/pthread14.c, psxhdrs/pthread15.c, psxhdrs/pthread16.c,
psxhdrs/pthread17.c, psxhdrs/pthread18.c, psxhdrs/pthread19.c,
psxhdrs/pthread20.c, psxhdrs/pthread21.c, psxhdrs/pthread22.c,
psxhdrs/pthread23.c, psxhdrs/pthread24.c, psxhdrs/pthread25.c,
psxhdrs/pthread26.c, psxhdrs/pthread27.c, psxhdrs/pthread28.c,
psxhdrs/pthread29.c, psxhdrs/pthread30.c, psxhdrs/pthread34.c,
psxhdrs/pthread35.c, psxhdrs/pthread36.c, psxhdrs/pthread37.c,
psxhdrs/pthread38.c, psxhdrs/pthread39.c, psxhdrs/pthread40.c:
Let test() return values (avoid warnings).
* psxhdrs/cond01.c, psxhdrs/cond02.c, psxhdrs/cond03.c,
psxhdrs/cond04.c, psxhdrs/cond05.c, psxhdrs/cond06.c,
psxhdrs/cond07.c, psxhdrs/cond08.c, psxhdrs/cond09.c,
psxhdrs/cond10.c: Let test() return values (avoid warnings).
* psxhdrs/mutex01.c, psxhdrs/mutex02.c, psxhdrs/mutex03.c,
psxhdrs/mutex04.c, psxhdrs/mutex05.c, psxhdrs/mutex06.c,
psxhdrs/mutex07.c, psxhdrs/mutex08.c, psxhdrs/mutex09.c,
psxhdrs/mutex10.c, psxhdrs/mutex11.c, psxhdrs/mutex12.c,
psxhdrs/mutex13.c, psxhdrs/mutex14.c, psxhdrs/mutex15.c,
psxhdrs/mutex16.c: Let test() return values (avoid warnings).
* psxhdrs/proc01.c, psxhdrs/proc02.c, psxhdrs/proc03.c,
psxhdrs/proc04.c, psxhdrs/proc05.c, psxhdrs/proc06.c,
psxhdrs/proc07.c, psxhdrs/proc08.c, psxhdrs/proc09.c,
psxhdrs/proc10.c, psxhdrs/proc11.c, psxhdrs/proc12.c,
psxhdrs/proc13.c, psxhdrs/proc14.c:
* psxhdrs/sched01.c, psxhdrs/sched02.c, psxhdrs/sched03.c,
psxhdrs/sched04.c, psxhdrs/sched05.c, psxhdrs/sched06.c,
psxhdrs/sched07.c, psxhdrs/sched08.c:
* psxhdrs/signal01.c, psxhdrs/signal02.c, psxhdrs/signal03.c,
psxhdrs/signal04.c, psxhdrs/signal05.c, psxhdrs/signal06.c,
psxhdrs/signal07.c, psxhdrs/signal08.c, psxhdrs/signal09.c,
psxhdrs/signal10.c, psxhdrs/signal11.c, psxhdrs/signal12.c,
psxhdrs/signal13.c, psxhdrs/signal14.c, psxhdrs/signal15.c,
psxhdrs/signal16.c, psxhdrs/signal17.c, psxhdrs/signal18.c,
psxhdrs/signal19.c, psxhdrs/signal20.c, psxhdrs/signal21.c,
psxhdrs/signal22.c, psxhdrs/signal23.c:
* psxhdrs/key01.c, psxhdrs/key02.c, psxhdrs/key03.c,
psxhdrs/key04.c: Let test() return values (avoid warnings).
* psxhdrs/clock01.c, psxhdrs/clock02.c, psxhdrs/clock03.c,
psxhdrs/clock04.c, psxhdrs/clock05.c, psxhdrs/clock06.c:
