* | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 2012-05-11 | 1 | -3/+0 |
* | 2009-11-11 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2009-11-12 | 1 | -0/+24 |
PR 1466/tests * Makefile.am, configure.ac, psxclock/init.c, psxclock/psxclock.doc, psxclock/psxclock.scn, psxkey03/init.c, psxsignal02/init.c, psxsignal03/init.c, psxstack01/init.c: Remove usleep() from tests. Add test specifically to test it since it is deprecated as of POSIX.1-2008. * psxusleep/.cvsignore, psxusleep/Makefile.am, psxusleep/init.c, psxusleep/psxusleep.doc, psxusleep/psxusleep.scn: New files. |
