* | 2003-09-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-09-04 | 2 | -2/+2 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * psx01/init.c, psx01/system.h, psx01/task.c, psx02/init.c, psx02/system.h, psx02/task.c, psx03/init.c, psx03/system.h, psx03/task.c, psx04/init.c, psx04/system.h, psx04/task1.c, psx04/task2.c, psx04/task3.c, psx05/init.c, psx05/system.h, psx05/task.c, psx05/task2.c, psx05/task3.c, psx06/init.c, psx06/system.h, psx06/task.c, psx06/task2.c, psx07/init.c, psx07/system.h, psx07/task.c, psx08/init.c, psx08/system.h, psx08/task1.c, psx08/task2.c, psx08/task3.c, psx09/init.c, psx09/system.h, psx10/init.c, psx10/system.h, psx10/task.c, psx10/task2.c, psx10/task3.c, psx11/init.c, psx11/system.h, psx11/task.c, psx12/init.c, psx12/system.h, psx12/task.c, psx13/main.c, psx13/test.c, psxcancel/init.c, psxfile01/main.c, psxfile01/test.c, psxhdrs/clock01.c, psxhdrs/clock02.c, psxhdrs/clock03.c, psxhdrs/clock04.c, psxhdrs/clock05.c, psxhdrs/clock06.c, psxhdrs/cond01.c, psxhdrs/cond02.c, psxhdrs/cond03.c, psxhdrs/cond04.c, psxhdrs/cond05.c, psxhdrs/cond06.c, psxhdrs/cond07.c, psxhdrs/cond08.c, psxhdrs/cond09.c, psxhdrs/cond10.c, psxhdrs/key01.c, psxhdrs/key02.c, psxhdrs/key03.c, psxhdrs/key04.c, psxhdrs/mutex01.c, psxhdrs/mutex02.c, psxhdrs/mutex03.c, psxhdrs/mutex04.c, psxhdrs/mutex05.c, psxhdrs/mutex06.c, psxhdrs/mutex07.c, psxhdrs/mutex08.c, psxhdrs/mutex09.c, psxhdrs/mutex10.c, psxhdrs/mutex11.c, psxhdrs/mutex12.c, psxhdrs/mutex13.c, psxhdrs/mutex14.c, psxhdrs/mutex15.c, psxhdrs/mutex16.c, psxhdrs/proc01.c, psxhdrs/proc02.c, psxhdrs/proc03.c, psxhdrs/proc04.c, psxhdrs/proc05.c, psxhdrs/proc06.c, psxhdrs/proc07.c, psxhdrs/proc08.c, psxhdrs/proc09.c, psxhdrs/proc10.c, psxhdrs/proc11.c, psxhdrs/proc12.c, psxhdrs/proc13.c, psxhdrs/proc14.c, psxhdrs/pthread01.c, psxhdrs/pthread02.c, psxhdrs/pthread03.c, psxhdrs/pthread04.c, psxhdrs/pthread05.c, psxhdrs/pthread06.c, psxhdrs/pthread07.c, psxhdrs/pthread08.c, psxhdrs/pthread09.c, psxhdrs/pthread10.c, psxhdrs/pthread11.c, psxhdrs/pthread12.c, psxhdrs/pthread13.c, psxhdrs/pthread14.c, psxhdrs/pthread15.c, psxhdrs/pthread16.c, psxhdrs/pthread17.c, psxhdrs/pthread18.c, psxhdrs/pthread19.c, psxhdrs/pthread20.c, psxhdrs/pthread21.c, psxhdrs/pthread22.c, psxhdrs/pthread23.c, psxhdrs/pthread24.c, psxhdrs/pthread25.c, psxhdrs/pthread26.c, psxhdrs/pthread27.c, psxhdrs/pthread28.c, psxhdrs/pthread29.c, psxhdrs/pthread30.c, psxhdrs/pthread31.c, psxhdrs/pthread32.c, psxhdrs/pthread33.c, psxhdrs/pthread34.c, psxhdrs/pthread35.c, psxhdrs/pthread36.c, psxhdrs/sched01.c, psxhdrs/sched02.c, psxhdrs/sched03.c, psxhdrs/sched04.c, psxhdrs/sched05.c, psxhdrs/sched06.c, psxhdrs/sched07.c, psxhdrs/sched08.c, psxhdrs/signal01.c, psxhdrs/signal02.c, psxhdrs/signal03.c, psxhdrs/signal04.c, psxhdrs/signal05.c, psxhdrs/signal06.c, psxhdrs/signal07.c, psxhdrs/signal08.c, psxhdrs/signal09.c, psxhdrs/signal10.c, psxhdrs/signal11.c, psxhdrs/signal12.c, psxhdrs/signal13.c, psxhdrs/signal14.c, psxhdrs/signal15.c, psxhdrs/signal16.c, psxhdrs/signal17.c, psxhdrs/signal18.c, psxhdrs/signal19.c, psxhdrs/signal20.c, psxhdrs/signal21.c, psxhdrs/signal22.c, psxhdrs/signal23.c, psxhdrs/sync01.c, psxhdrs/sync02.c, psxhdrs/sync03.c, psxhdrs/time01.c, psxhdrs/time02.c, psxhdrs/time03.c, psxhdrs/time04.c, psxhdrs/time05.c, psxhdrs/time06.c, psxhdrs/time07.c, psxhdrs/time08.c, psxhdrs/time09.c, psxhdrs/time10.c, psxhdrs/time11.c, psxhdrs/time12.c, psxhdrs/time13.c, psxhdrs/timer01.c, psxhdrs/timer02.c, psxhdrs/timer03.c, psxhdrs/timer04.c, psxhdrs/timer05.c, psxhdrs/timer06.c, psxhdrs/timer07.c, psxmsgq01/init.c, psxmsgq01/system.h, psxsem01/system.h, psxstat/main.c, psxstat/test.c, psxtime/main.c, psxtime/test.c, psxtimer/psxtimer.c, psxtimer/system.h: URL for license changed. | ||||
* | 2003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-16 | 1 | -3/+3 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | Makefile.am: Reflect having moved automake. include/Makefile.am: Reflect having moved automake. psx01/Makefile.am: Reflect having moved automake. psx02/Makefile.am: Reflect having moved automake. psx03/Makefile.am: Reflect having moved automake. psx04/Makefile.am: Reflect having moved automake. psx05/Makefile.am: Reflect having moved automake. psx06/Makefile.am: Reflect having moved automake. psx07/Makefile.am: Reflect having moved automake. psx08/Makefile.am: Reflect having moved automake. psx09/Makefile.am: Reflect having moved automake. psx10/Makefile.am: Reflect having moved automake. psx11/Makefile.am: Reflect having moved automake. psx12/Makefile.am: Reflect having moved automake. psx13/Makefile.am: Reflect having moved automake. psxcancel/Makefile.am: Reflect having moved automake. psxchroot01/Makefile.am: Reflect having moved automake. psxfile01/Makefile.am: Reflect having moved automake. psxhdrs/Makefile.am: Reflect having moved automake. psxmount/Makefile.am: Reflect having moved automake. psxmsgq01/Makefile.am: Reflect having moved automake. psxreaddir/Makefile.am: Reflect having moved automake. psxsem01/Makefile.am: Reflect having moved automake. psxstat/Makefile.am: Reflect having moved automake. psxtime/Makefile.am: Reflect having moved automake. psxtimer/Makefile.am: Reflect having moved automake. | ||||
* | 2003-05-29 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-05-29 | 1 | -2/+5 |
| | | | | | | * psx02/init.c, psx04/init.c, psx13/test.c, psxchroot01/test.c, psxhdrs/pthread07.c, psxmsgq01/init.c, psxreaddir/test.c, psxtimer/psxtimer.c: Removed warnings. | ||||
* | 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-08-11 | 1 | -1/+1 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | * psx01/Makefile.am: Use .$(OBJEXT) instead of .o. * psx02/Makefile.am: Use .$(OBJEXT) instead of .o. * psx03/Makefile.am: Use .$(OBJEXT) instead of .o. * psx04/Makefile.am: Use .$(OBJEXT) instead of .o. * psx05/Makefile.am: Use .$(OBJEXT) instead of .o. * psx06/Makefile.am: Use .$(OBJEXT) instead of .o. * psx07/Makefile.am: Use .$(OBJEXT) instead of .o. * psx08/Makefile.am: Use .$(OBJEXT) instead of .o. * psx09/Makefile.am: Use .$(OBJEXT) instead of .o. * psx10/Makefile.am: Use .$(OBJEXT) instead of .o. * psx11/Makefile.am: Use .$(OBJEXT) instead of .o. * psx12/Makefile.am: Use .$(OBJEXT) instead of .o. * psx13/Makefile.am: Use .$(OBJEXT) instead of .o. * psxcancel/Makefile.am: Use .$(OBJEXT) instead of .o. * psxchroot01/Makefile.am: Use .$(OBJEXT) instead of .o. * psxfile01/Makefile.am: Use .$(OBJEXT) instead of .o. * psxhdrs/Makefile.am: Use .$(OBJEXT) instead of .o. * psxmount/Makefile.am: Use .$(OBJEXT) instead of .o. * psxmsgq01/Makefile.am: Use .$(OBJEXT) instead of .o. * psxreaddir/Makefile.am: Use .$(OBJEXT) instead of .o. * psxsem01/Makefile.am: Use .$(OBJEXT) instead of .o. * psxstat/Makefile.am: Use .$(OBJEXT) instead of .o. * psxtime/Makefile.am: Use .$(OBJEXT) instead of .o. * psxtimer/Makefile.am: Use .$(OBJEXT) instead of .o. | ||||
* | 2002-08-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-08-02 | 1 | -1/+1 |
| | | | | | | | | | | | | | | | | | | | | | | * Per PR47 add support for buffered test output. This involved adding defines to redirect output to a buffer and dump it when full, at "test pause", and at exit. To avoid problems when redefining exit(), all tests were modified to call rtems_test_exit(). Some tests, notable psxtests, had to be modified to include the standard test macro .h file (pmacros.h or tmacros.h) to enable this support. * include/pmacros.h, psx01/task.c, psx02/init.c, psx02/task.c, psx03/init.c, psx04/init.c, psx05/init.c, psx06/init.c, psx07/init.c, psx08/task3.c, psx09/init.c, psx10/init.c, psx11/init.c, psx12/init.c, psx13/Makefile.am, psx13/main.c, psx13/test.c, psxcancel/init.c, psxchroot01/Makefile.am, psxchroot01/main.c, psxchroot01/test.c, psxfile01/Makefile.am, psxfile01/main.c, psxfile01/test.c, psxfile01/test_cat.c, psxfile01/test_extend.c, psxfile01/test_write.c, psxmount/Makefile.am, psxmount/main.c, psxmount/test.c, psxmsgq01/init.c, psxreaddir/Makefile.am, psxreaddir/main.c, psxreaddir/test.c, psxsem01/init.c, psxstat/Makefile.am, psxstat/main.c, psxstat/test.c, psxtime/main.c, psxtime/test.c, psxtimer/psxtimer.c: Modified. | ||||
* | 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-03-28 | 1 | -1/+0 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * Makefile.am: Remove AUTOMAKE_OPTIONS. * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * psx01/Makefile.am: Remove AUTOMAKE_OPTIONS. * psx02/Makefile.am: Remove AUTOMAKE_OPTIONS. * psx03/Makefile.am: Remove AUTOMAKE_OPTIONS. * psx04/Makefile.am: Remove AUTOMAKE_OPTIONS. * psx05/Makefile.am: Remove AUTOMAKE_OPTIONS. * psx06/Makefile.am: Remove AUTOMAKE_OPTIONS. * psx07/Makefile.am: Remove AUTOMAKE_OPTIONS. * psx08/Makefile.am: Remove AUTOMAKE_OPTIONS. * psx09/Makefile.am: Remove AUTOMAKE_OPTIONS. * psx10/Makefile.am: Remove AUTOMAKE_OPTIONS. * psx11/Makefile.am: Remove AUTOMAKE_OPTIONS. * psx12/Makefile.am: Remove AUTOMAKE_OPTIONS. * psx13/Makefile.am: Remove AUTOMAKE_OPTIONS. * psxcancel/Makefile.am: Remove AUTOMAKE_OPTIONS. * psxchroot01/Makefile.am: Remove AUTOMAKE_OPTIONS. * psxfile01/Makefile.am: Remove AUTOMAKE_OPTIONS. * psxhdrs/Makefile.am: Remove AUTOMAKE_OPTIONS. * psxmount/Makefile.am: Remove AUTOMAKE_OPTIONS. * psxmsgq01/Makefile.am: Remove AUTOMAKE_OPTIONS. * psxreaddir/Makefile.am: Remove AUTOMAKE_OPTIONS. * psxsem01/Makefile.am: Remove AUTOMAKE_OPTIONS. * psxstat/Makefile.am: Remove AUTOMAKE_OPTIONS. * psxtime/Makefile.am: Remove AUTOMAKE_OPTIONS. * psxtimer/Makefile.am: Remove AUTOMAKE_OPTIONS. | ||||
* | 2001-09-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2001-09-19 | 1 | -1/+1 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | * psx01/Makefile.am: include leaf.am instead of leaf.cfg. * psx11/Makefile.am: include leaf.am instead of leaf.cfg. * psxcancel/Makefile.am: include leaf.am instead of leaf.cfg. * psx02/Makefile.am: include leaf.am instead of leaf.cfg. * psx13/Makefile.am: include leaf.am instead of leaf.cfg. * psxtime/Makefile.am: include leaf.am instead of leaf.cfg. * psxchroot01/Makefile.am: include leaf.am instead of leaf.cfg. * psx07/Makefile.am: include leaf.am instead of leaf.cfg. * psxmsgq01/Makefile.am: include leaf.am instead of leaf.cfg. * psxtimer/Makefile.am: include leaf.am instead of leaf.cfg. * psx10/Makefile.am: include leaf.am instead of leaf.cfg. * psx08/Makefile.am: include leaf.am instead of leaf.cfg. * psxhdrs/Makefile.am: include leaf.am instead of leaf.cfg. * psxfile01/Makefile.am: include leaf.am instead of leaf.cfg. * psx05/Makefile.am: include leaf.am instead of leaf.cfg. * psx09/Makefile.am: include leaf.am instead of leaf.cfg. * psxmount/Makefile.am: include leaf.am instead of leaf.cfg. * psxstat/Makefile.am: include leaf.am instead of leaf.cfg. * psx12/Makefile.am: include leaf.am instead of leaf.cfg. * psxreaddir/Makefile.am: include leaf.am instead of leaf.cfg. * psxsem01/Makefile.am: include leaf.am instead of leaf.cfg. * psx03/Makefile.am: include leaf.am instead of leaf.cfg. * psx04/Makefile.am: include leaf.am instead of leaf.cfg. * psx06/Makefile.am: include leaf.am instead of leaf.cfg. | ||||
* | 2001-04-20 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2001-04-20 | 1 | -35/+35 |
| | | | | | | | | * psx04/init.c, psx04/psx04.scn, psx07/init.c, psx07/psx07.scn, psxfile01/psxfile01.scn, psxmsgq01/psxmsgq01.scn, psxreaddir/test.c, psxstat/psxstat.scn, psxstat/test.c, psxtime/psxtime.scn, psxtimer/psxtimer.scn: Various adjustments so test output matches screens more reliably. | ||||
* | 2000-11-17 Jennifer Averret <jennifer@OARcorp.com> | Jennifer Averett | 2000-11-20 | 1 | -13/+12 |
| | | | | | | | | * psxmount/test.c, psxmount/psxmount.scn: Improve output to report expected error condition in one case. * psxreaddir/test.c, psxreaddir.scn: Added test cases to exercise readdir() of root of mounted filesystem. Also corrected the screen file for some mistakes noticed in this effort. | ||||
* | 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-09-05 | 1 | -0/+1 |
| | | | | | | | | | | | * psx01/Makefile.am, psx02/Makefile.am, psx03/Makefile.am, psx04/Makefile.am, psx05/Makefile.am, psx06/Makefile.am, psx07/Makefile.am, psx08/Makefile.am, psx09/Makefile.am, psx10/Makefile.am, psx11/Makefile.am, psx12/Makefile.am, psx13/Makefile.am, psxcancel/Makefile.am, psxfile01/Makefile.am, psxhdrs/Makefile.am, psxmount/Makefile.am, psxmsgq01/Makefile.am, psxreaddir/Makefile.am, psxsem01/Makefile.am, psxstat/Makefile.am, psxtime/Makefile.am, psxtimer/Makefile.am: Include compile.am | ||||
* | 2000-08-31 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-09-01 | 1 | -1/+1 |
| | | | | | | | | | | * psx01/Makefile.am, psx02/Makefile.am, psx03/Makefile.am, psx04/Makefile.am, psx05/Makefile.am, psx06/Makefile.am, psx07/Makefile.am, psx08/Makefile.am, psx09/Makefile.am, psx10/Makefile.am, psx11/Makefile.am, psx11/Makefile.am, psx12/Makefile.am, psxcancel/Makefile.am, psxmsgq01/Makefile.am, psxsem01/Makefile.am, psxsem01/Makefile.am, psxtimer/Makefile.am: Use AM_CPPFLAGS += instead of AM_CPPFLAGS = | ||||
* | Merged from 4.5.0-beta3a | Joel Sherrill | 2000-06-12 | 2 | -14/+9 |
* | Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | Joel Sherrill | 2000-04-13 | 1 | -0/+2 |
| | | | | adds .cvsignore. | ||||
* | Patch rtems-rc-20000118-2.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-01-31 | 1 | -1/+0 |
| | | | | | that contains cosmetical changes to the Makefile.ams below tests (removes old, now invalid comments from these Makefile.ams). | ||||
* | Moved pmacros.h to include not support/include. | Joel Sherrill | 1999-11-23 | 1 | -1/+1 |
* | Patch rtems-rc-19991117-14.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1999-11-23 | 1 | -0/+44 |
| | | | | to convert the psxtests directory from Makefile.in to Makefile.am. | ||||
* | New files from Juan Zamorano Flores <jzamora@avellano.datsi.fi.upm.es> | Joel Sherrill | 1999-02-03 | 3 | -0/+445 |
that are part of the addition of POSIX timers. |
