Move implementation specific parts of timer.h and timer.inl into new
header file timerimpl.h. The timer.h contains now only the application
visible API.
for details.
PR 1589/build
psx13/Makefile.am, psx14/Makefile.am, psx15/Makefile.am,
psx16/Makefile.am, psxaio01/Makefile.am, psxaio02/Makefile.am,
psxaio03/Makefile.am, psxalarm01/Makefile.am,
psxautoinit01/Makefile.am, psxautoinit02/Makefile.am,
psxbarrier01/Makefile.am, psxcancel/Makefile.am,
psxcancel01/Makefile.am, psxchroot01/Makefile.am,
psxclassic01/Makefile.am, psxcleanup/Makefile.am,
psxcleanup01/Makefile.am, psxclock/Makefile.am,
psxcond01/Makefile.am, psxeintr_join/Makefile.am,
psxenosys/Makefile.am, psxfatal01/Makefile.am,
psxfatal02/Makefile.am, psxfchx01/Makefile.am, psxfile01/Makefile.am,
psxfile02/Makefile.am, psxfilelock01/Makefile.am,
psxgetrusage01/Makefile.am, psxid01/Makefile.am,
psximfs01/Makefile.am, psximfs02/Makefile.am,
psxintrcritical01/Makefile.am, psxitimer/Makefile.am,
psxkey01/Makefile.am, psxkey02/Makefile.am, psxkey03/Makefile.am,
psxmount/Makefile.am, psxmsgq01/Makefile.am, psxmsgq02/Makefile.am,
psxmsgq03/Makefile.am, psxmsgq04/Makefile.am,
psxmutexattr01/Makefile.am, psxobj01/Makefile.am,
psxpasswd01/Makefile.am, psxpasswd02/Makefile.am,
psxpipe01/Makefile.am, psxrdwrv/Makefile.am, psxreaddir/Makefile.am,
psxrwlock01/Makefile.am, psxsem01/Makefile.am,
psxsignal01/Makefile.am, psxsignal02/Makefile.am,
psxsignal03/Makefile.am, psxsignal04/Makefile.am,
psxsignal05/Makefile.am, psxsignal06/Makefile.am,
psxspin01/Makefile.am, psxspin02/Makefile.am, psxstack01/Makefile.am,
psxstack02/Makefile.am, psxstat/Makefile.am, psxsysconf/Makefile.am,
psxtime/Makefile.am, psxtimer01/Makefile.am, psxtimer02/Makefile.am,
psxtimes01/Makefile.am, psxualarm/Makefile.am, psxusleep/Makefile.am:
Remove obsolete optional manager capability.
* psx01/init.c, psx07/init.c, psx09/init.c, psx12/init.c,
psxclock/init.c, psxtimer01/psxtimer.c: Include "pritime.h".
Use PRIdtime_t to print time_t.
psx13/Makefile.am, psx14/Makefile.am, psxalarm01/Makefile.am,
psxcleanup/Makefile.am, psxcleanup01/Makefile.am,
psxclock/Makefile.am, psxcond01/Makefile.am, psxenosys/Makefile.am,
psxfatal01/Makefile.am, psxfatal02/Makefile.am,
psxfile01/Makefile.am, psxintrcritical01/Makefile.am,
psxitimer/Makefile.am, psxkey01/Makefile.am, psxkey02/Makefile.am,
psxkey03/Makefile.am, psxmount/Makefile.am, psxmsgq01/Makefile.am,
psxmsgq02/Makefile.am, psxmsgq03/Makefile.am, psxmsgq04/Makefile.am,
psxpasswd01/Makefile.am, psxrdwrv/Makefile.am,
psxreaddir/Makefile.am, psxrwlock01/Makefile.am,
psxsem01/Makefile.am, psxsignal01/Makefile.am,
psxsignal02/Makefile.am, psxsignal03/Makefile.am,
psxsignal04/Makefile.am, psxsignal05/Makefile.am,
psxstat/Makefile.am, psxsysconf/Makefile.am, psxtime/Makefile.am,
psxualarm/Makefile.am, psxusleep/Makefile.am: Revert accidentally
committed patch.
* Makefile.am, configure.ac, psx01/Makefile.am, psx02/Makefile.am,
psx03/Makefile.am, psx04/Makefile.am, psx05/Makefile.am,
psx06/Makefile.am, psx07/Makefile.am, psx08/Makefile.am,
psx09/Makefile.am, psx10/Makefile.am, psx11/Makefile.am,
psx12/Makefile.am, psx13/Makefile.am, psx14/Makefile.am,
psxalarm01/Makefile.am, psxautoinit01/Makefile.am,
psxautoinit02/Makefile.am, psxbarrier01/Makefile.am,
psxcancel/Makefile.am, psxcancel01/Makefile.am,
psxchroot01/Makefile.am, psxcleanup/Makefile.am,
psxcond01/Makefile.am, psxenosys/Makefile.am, psxfatal01/Makefile.am,
psxfatal02/Makefile.am, psxfile01/Makefile.am, psxfile02/init.c,
psxfile02/psxfile02.doc, psxfile02/psxfile02.scn,
psxualarm/Makefile.am, psxusleep/Makefile.am: Add test for fd greater
than number of file descriptors configured.
* psxtimer01/psxtimer.c: It is not necessarily an error for the time
remaining to not equal the period.
* psxtimer01/psxtimer.c: Actually pass the pointer we initialized.
* psxtimer01/psxtimer.c: Make sure we have null and not-null as return
parameter to timer_settime().
* psxtimer01/psxtimer.c: Modify so it passes in a NULL to
timer_settime() for previous value. We are not using the
value in this particular case and this path must be exercised.
* psxtimer01/psxtimer01.scn: Update so it matches output on sis.
* psxsem01/Makefile.am, psxsem01/init.c, psxsem01/psxsem01.scn,
psxtimer01/psxtimer.c, psxtimer01/system.h, psxtimer02/psxtimer.c:
Improved so coverage is better.
* psx01/init.c, psx01/task.c, psx02/init.c, psx02/task.c, psx03/init.c,
psx04/init.c, psx04/task1.c, psx04/task3.c, psx05/init.c,
psx06/init.c, psx07/init.c, psx08/init.c, psx09/init.c, psx11/task.c,
psx12/init.c, psx13/main.c, psx13/test.c, psxbarrier01/test.c,
psxcancel/init.c, psxcleanup/psxcleanup.c, psxenosys/init.c,
psxmsgq02/init.c, psxtime/main.c, psxtime/test.c,
psxtimer01/psxtimer.c, psxtimer02/psxtimer.c: Fix warnings.
* psxtimer01/psxtimer.c, psxtimer02/psxtimer.c: Obtain TOD with
clock_gettime() NOT by reaching into the SuperCore.
PR 1296/cpukit.
* psxtimer01/psxtimer.c, psxtimer01/psxtimer01.scn: POSIX timers use
incorrect repeat interval. This patch fixes the following problems in
the test.
(1) Adds test for value of it_interval.tv_nsec.
(2) Corrects test for absolute timer in past.
(3) Modifies test to use different initial and repeat periods.
(4) Updates psxtimer01.scn to match results.
* psx01/init.c, psxmsgq01/init.c, psxtimer01/psxtimer.c,
psxtimer01/psxtimer01.scn, psxtimer02/psxtimer.c:
* Makefile.am, configure.ac: Rename psxtimer to psxtimer01 to indicate
addition of second POSIX Timer test. Add initial version of
psxtimer02 to cover some conditions missed in psxtimer01. More cases
left to add.
* psxtimer01/.cvsignore, psxtimer01/Makefile.am, psxtimer01/psxtimer.c,
psxtimer01/psxtimer01.scn, psxtimer01/system.h,
psxtimer02/.cvsignore, psxtimer02/Makefile.am, psxtimer02/psxtimer.c,
psxtimer02/psxtimer02.scn, psxtimer02/system.h: New files.
* psxtimer/.cvsignore, psxtimer/Makefile.am, psxtimer/psxtimer.c,
psxtimer/psxtimer.scn, psxtimer/system.h: Removed.
