* | Patch rtems-rc-20000118-2.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-01-31 | 1 | -1/+0 |
| | | | | | that contains cosmetical changes to the Makefile.ams below tests (removes old, now invalid comments from these Makefile.ams). | ||||
* | Patch rtems-rc-19991117-14.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1999-11-23 | 1 | -0/+39 |
| | | | | to convert the psxtests directory from Makefile.in to Makefile.am. | ||||
* | Updated copyright notice. | Joel Sherrill | 1999-11-17 | 2 | -4/+2 |
* | Modified output file to match seen output. Added comment to all ino | Jennifer Averett | 1999-11-16 | 1 | -306/+282 |
| | | | | values that they may change slightly on a processor basis. | ||||
* | Removed compiler warning. | Jennifer Averett | 1999-11-16 | 1 | -1/+1 |
* | The files in libcpu should not be directly dependent on any BSP. In | Joel Sherrill | 1999-11-04 | 1 | -0/+2 |
| | | | | | | | | | | | particular, using bsp.h, or getting information from the BSP which should properly be obtained from RTEMS is forbidden. This is necessary to strengthen the division between the BSP independent parts of RTEMS and the BSPs themselves. This started after comments and analysis by Ralf Corsepius <corsepiu@faw.uni-ulm.de>. The changes primarily eliminated the need to include bsp.h and peeking at BSP_Configuration. The use of Cpu_table in each BSP needs to be eliminated. | ||||
* | Modified to ease comparison of screen to target output. | Joel Sherrill | 1999-10-25 | 2 | -981/+981 |
* | Modified to reflect change in calling sequence of mount(). | Joel Sherrill | 1999-07-01 | 1 | -1/+1 |
* | Corrections by Jennifer. | Joel Sherrill | 1999-04-06 | 1 | -41/+57 |
* | Correctd name length to account for new IMFS max name length of 32. | Jennifer Averett | 1999-03-29 | 1 | -1/+3 |
* | Removed all ^M from the scn file. | Jennifer Averett | 1998-12-03 | 1 | -1253/+1253 |
* | Added tests in support of the file system infrastructure. | Joel Sherrill | 1998-11-23 | 3 | -0/+2127 |
