Update #3818.
+ Modify POSIX thread create extension to ensure expected
initial signal mask is provided to system threads, initial
tasks and threads, and inheritied by tasks and threads.
+ Adds psxsignal07 to verify functionality when using a POSIX
Initialization thread and POSIX threads.
+ Adds psxsignal08 to verify functionality when using a Classic API
Initialization task and Classic API tasks.
Closes #3794.
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
* psx02/init.c, psx02/task.c, psx03/init.c, psx04/init.c,
psx04/task1.c, psx04/task2.c, psx04/task3.c, psx05/init.c,
psx05/task.c, psx05/task2.c, psx05/task3.c, psx06/init.c,
psx06/task.c, psx06/task2.c, psx07/init.c, psx08/init.c,
psx08/task2.c, psx08/task3.c, psx09/init.c, psx10/init.c,
psx10/task.c, psx10/task2.c, psx10/task3.c, psx11/init.c,
psx11/task.c, psx12/init.c, psxalarm01/init.c, psxbarrier01/test.c,
psxcancel01/init.c, psxchroot01/test.c, psxitimer/init.c,
psxkey01/task.c, psxkey02/init.c, psxkey03/init.c, psxmount/test.c,
psxmsgq01/init.c, psxmsgq03/init.c, psxmsgq04/init.c,
psxrwlock01/test.c, psxsem01/init.c, psxsignal01/init.c,
psxsignal01/task1.c, psxsignal02/init.c, psxsignal03/init.c,
psxsignal05/init.c, psxspin01/test.c, psxspin02/test.c,
psxstack01/init.c, psxstack02/init.c, psxualarm/init.c: Eliminate
double space after parenthesis on rtems_test_assert().
* include/pmacros.h, psx01/task.c, psx02/init.c, psx02/task.c,
psx03/init.c, psx03/task.c, psx04/init.c, psx04/task1.c,
psx04/task2.c, psx04/task3.c, psx05/init.c, psx05/task.c,
psx05/task2.c, psx05/task3.c, psx06/init.c, psx06/task.c,
psx06/task2.c, psx07/init.c, psx08/init.c, psx08/task2.c,
psx08/task3.c, psx09/init.c, psx10/init.c, psx10/task.c,
psx10/task2.c, psx10/task3.c, psx11/init.c, psx11/task.c,
psxcancel01/init.c, psxchroot01/test.c, psxclock/init.c,
psxfile01/test.c, psxfile01/test_cat.c, psxfile01/test_extend.c,
psxfile01/test_write.c, psxitimer/init.c, psxkey01/task.c,
psxkey02/init.c, psxkey03/init.c, psxmount/test.c, psxmsgq01/init.c,
psxmsgq03/init.c, psxmsgq04/init.c, psxreaddir/test.c,
psxstack01/init.c, psxstat/test.c, psxtime/test.c, psxualarm/init.c:
Use rtems_test_assert() consistently instead of system assert().
rtems_test_assert() is designed to integrate into the RTEMS test
suite infrastructure.
PR 1466/tests
* Makefile.am, configure.ac, psxclock/init.c, psxclock/psxclock.doc,
psxclock/psxclock.scn, psxkey03/init.c, psxsignal02/init.c,
psxsignal03/init.c, psxstack01/init.c: Remove usleep() from tests.
Add test specifically to test it since it is deprecated as of
POSIX.1-2008.
* psxusleep/.cvsignore, psxusleep/Makefile.am, psxusleep/init.c,
psxusleep/psxusleep.doc, psxusleep/psxusleep.scn: New files.
Add missing prototypes.
* psxclock/init.c, psxclock/psxclock.scn, psxenosys/init.c,
psxenosys/psxenosys.scn, psxsignal03/Makefile.am, psxsignal03/init.c,
psxsignal04/Makefile.am: Move test cases which needed to be executed
when POSIX is disabled to psxclock so they will be.
* psxsignal03/init.c, psxsignal03/psxsignal03.scn,
psxsignal04/psxsignal04.scn: Correct test numbers in macros so output
is right. Update both screens.
* Makefile.am, configure.ac, psxsignal03/Makefile.am,
psxsignal03/init.c, psxsignal03/psxsignal03.doc: Add new test
variation which focused on real-time signals rather than user
signals.
* psxsignal04/.cvsignore, psxsignal04/Makefile.am,
psxsignal04/psxsignal04.doc, psxsignal04/psxsignal04.scn: New files.
* Makefile.am, configure.ac: Add test to address cases where a thread
is waiting on a signal (sigwait) and we send it. Also address case
where there are too many queued signals.
* psxsignal03/.cvsignore, psxsignal03/Makefile.am, psxsignal03/init.c,
psxsignal03/psxsignal03.doc, psxsignal03/psxsignal03.scn: New files.
